The BS Daycare but no build thread
Discussion in 'Other Builds' started by Kwikvette, Jan 18, 2022.
  1. Mar 8, 2022 at 8:14 PM
    #341
    Kwikvette
    Kwikvette [OP] Well-Known Member Vendor
    Fresno County
    4 run, 2 don't
    @xtremewlr
    May be picking up some Toyo Open Country III tires, on the very wheels you're running. Less than 1k miles and still have those little nipples on them, and a date code from a few months ago
    285/70/17 so I'll be back down to 33s.
    xtremewlr and jubei like this.
  2. Mar 8, 2022 at 9:57 PM
    #342
    02hilux
    Planet: EARTH
    Why not 343/85/17 :anonymous:
  3. Mar 9, 2022 at 6:49 AM
    #343
    Kwikvette
    Fresno County
    4 run, 2 don't
    You'll just need to come over everytime I need to get my wheels off then :burp:
  4. Mar 9, 2022 at 6:56 AM
    #344
    02hilux
    Planet: EARTH
    DEAL :cheers:
    They weigh 45lbs...... :D
    Kwikvette[QUOTED][OP] likes this.
  5. Mar 9, 2022 at 6:57 AM
    #345
    Kwikvette
    Fresno County
    4 run, 2 don't
    Awe fuck thats light!
    Damn Coopers on 4R wheels weighed over 80lbs+ each
  6. Mar 9, 2022 at 3:23 PM
    #346
    Kwikvette
    Fresno County
    4 run, 2 don't
    So, I went on a quick short drive...
    Picked up a few passengers...
    And introduced them to the current set.
  7. Mar 9, 2022 at 3:27 PM
    #347
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    Which tig you get?
  8. Mar 9, 2022 at 3:29 PM
    #348
    Kwikvette
    Fresno County
    4 run, 2 don't
    PrimeWeld TIG 225X
    Does AC and DC, has high-frequency, and has pulse as well as a ton of other features.
    Arrives Friday, and apparently my gas lens and clear cup kit arrived today.
  9. Mar 9, 2022 at 3:32 PM
    #349
    Yota X
    NW New Jersey
    1st gen
    Damn, that thing has a lot of knobs on it. What are you using it for?
  10. Mar 9, 2022 at 3:33 PM
    #350
    Kwikvette
    Fresno County
    4 run, 2 don't
    Got it strictly for aluminum, but it'll come in handy if I'll ever need to do sheet metal of any sort.
    Yota X[QUOTED] likes this.
  11. Mar 9, 2022 at 3:38 PM
    #351
    Yota X
    NW New Jersey
    1st gen
    They are nice for aluminum. Used to have a miller dynasty. Bought it to make an intake plenum for the evo. Never made it but it was fun as shit to use.
  12. Mar 9, 2022 at 3:41 PM
    #352
    Kwikvette
    Fresno County
    4 run, 2 don't
    Aluminum sure is temperamental as fuck; it just loves to soak up heat, and retain it.
    I've been good at school to not burn or melt my coupons, but others can't say the same.
    I'm using a collet body at school and apparently a gas lens is supposed to make a huge difference, especially with fillet welds. We'll see though.
  13. Mar 9, 2022 at 4:23 PM
    #353
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Yota X
    Weldmonger kit arrived :angrygirl:
    Das it mang and Yota X like this.
  14. Mar 9, 2022 at 4:30 PM
    #354
    Yota X
    NW New Jersey
    1st gen
    Their presentation is on point!
  15. Mar 9, 2022 at 4:34 PM
    #355
    Kwikvette
    Fresno County
    4 run, 2 don't
    This kit should hold me over for awhile.
    Gas lens vs collet body; gas lens direct shielding gas directly at the weld which means it's used more efficiently.
    You can turn down your shielding gas to about 15psi vs the 30psi on a collet body. With a collet body, you run the risk of getting some porosity with air entering due to the turbulence it causes.
  16. Mar 9, 2022 at 4:45 PM
    #356
    Yota X
    NW New Jersey
    1st gen
    That's nice! I got my dynasty from some guy on CL and it had everything. I never had to mess around with combos. It basically worked real nice when I got it. Im starting to learn that knowing what does what is what and the effects is really makes you a good welder. Thats the hardest part. Im a certified MASTER GRINDER though!
    Wulf and Kwikvette[QUOTED][OP] like this.
  17. Mar 9, 2022 at 4:47 PM
    #357
    Kwikvette
    Fresno County
    4 run, 2 don't
    On another note; holy shit the new 33's feel so much smoother and are significantly quieter!
    I know the Coopers were due for replacement, mainly because of how hard the rubber was on them. But you can't even hear the Toyos at all.
    Gas mileage should improve some as well being that they're lighter.
    xtremewlr, Wulf and Yota X like this.
  18. Mar 9, 2022 at 4:49 PM
    #358
    Yota X
    NW New Jersey
    1st gen
    Are you running the sequoia wheels too?Have a pic?
  19. Mar 9, 2022 at 4:53 PM
    #359
    Kwikvette
    Fresno County
    4 run, 2 don't
    Sold the Sequoia wheels for labor cost to dismount 8 tires, and mount and balance 4.
    The wheels would've required 1" spacers and though I've ran spacers before, I didn't want to on such a large vehicle.
    So I got the tires mounted on my Raceline's which are the wheels I plan to keep on anyway.
    The Toyos ars E load so you know I'll be airing down like a mofo :mudding:
    Wulf and Yota X[QUOTED] like this.
  20. Mar 9, 2022 at 4:58 PM
    #360
    Kwikvette
    Fresno County
    4 run, 2 don't
    @0xDEADBEEF
    I see you peeking
    How far in school is your girlfriend?
    0xDEADBEEF, Das it mang and Yota X like this.
