The BS Daycare but no build thread
Discussion in 'Other Builds' started by Kwikvette, Jan 18, 2022.
  1. Apr 4, 2022 at 6:21 PM
    #561
    Rezkid
    Rezkid Not a Well Known Member
    TJ
    WTX
    '08 DCSB TRD RT
    Little bit of this and that
    You'll like them, the Sports throw a ton of light! Annnnd then you'll be wondering what you're missing out on by not getting the Maxxes and it just snowballs from there.
  2. Apr 4, 2022 at 6:22 PM
    #562
    JKO1998
    JKO1998 Well-Known Member
    Utah
    But so convenient
  3. Apr 4, 2022 at 6:22 PM
    #563
    Kwikvette
    Kwikvette [OP] Well-Known Member Vendor
    Fresno County
    4 run, 2 don't
    Dammit! :rofl:
    I'll just have Shawn lead wherever we go.
    Rezkid[QUOTED] and Taco-Obsessed like this.
  4. Apr 4, 2022 at 6:24 PM
    #564
    JKO1998
    Utah
    Mount your switch right below the climate control panel in one of those blanks, if you usually keep your hand on the shifter anyway.
  5. Apr 4, 2022 at 6:26 PM
    #565
    Taco-Obsessed
    He can supass me now in some situations. I couldn't get past the last 200' of fremontia (black diamond); too much loose granite on a steeper climb. He got past it with his front locker, which I don't have. I could've winched, but it was end of day so I just took another way around. There may be obstacles I can get over in my bigger tires, but that front locker is huge on his truck.
    I almost rolled earlier that day and had to winch myself out. It was a good day, besides smashing my valve stem on a boulder and having to put on my spare to get home. Thinking of switching to rubber stems and loosing my TPMS.
    Kwikvette[QUOTED][OP] likes this.
  6. Apr 4, 2022 at 6:27 PM
    #566
    Kwikvette
    Fresno County
    4 run, 2 don't
    Truth be told, I wouldn't need one as I plan to run 2 sets of aux lights, max.
    Front fogs, and rear chase lights.
  7. Apr 4, 2022 at 6:28 PM
    #567
    JKO1998
    Utah
    Locker buttons?
  8. Apr 4, 2022 at 6:28 PM
    #568
    Kwikvette
    Fresno County
    4 run, 2 don't
    Awe shit I know you've got 35s but I forget you're only rear locked, damn.
    I just want to get some maintenance done and replace my coils to see what this solid axle setup in stock form can do.
    Taco-Obsessed[QUOTED] likes this.
  9. Apr 4, 2022 at 6:29 PM
    #569
    Kwikvette
    Fresno County
    4 run, 2 don't
    Tied to the factory rotary knob.
    But you're right to think that way :rofl:
    Really thinking about it, I shouldn't be too far from buying lockers if prices don't go up. We just got too much other shit to buy atm.
  10. Apr 4, 2022 at 6:31 PM
    #570
    JKO1998
    Utah
    Damn new house problems
  11. Apr 4, 2022 at 6:34 PM
    #571
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah, gives me anxiety just thinking about all the costs for new shit we'll need.
    Biggest cost items are - fridge, blinds, dining table (current one won't match), sofas (won't match), TV stand, dresser (won't match), artificial grass in the small back yard, and more.
    Yota X likes this.
  12. Apr 4, 2022 at 6:34 PM
    #572
    JKO1998
    Utah
    Just put a pool in like everyone else
    Yota X likes this.
  13. Apr 4, 2022 at 6:35 PM
    #573
    Taco-Obsessed
    Open them up, mountaing points above and below. They need to attach to something level. My bottom points are at an angle like 140-160 degrees or so. I could just L-bracket off the side 90 but I think it'll look janky. Might go that route first.
  14. Apr 4, 2022 at 6:36 PM
    #574
    Kwikvette
    Fresno County
    4 run, 2 don't
    :rofl:
    Naw, I've never been a fan.
    I love jumping in a lake or something like when we go camping in certain areas. But something about an artificial body of water...
    JKO1998[QUOTED] likes this.
  15. Apr 4, 2022 at 6:40 PM
    #575
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ooooh, I thought you meant level as in they'd leave your lights pointed up or down.
    You mean the mounting surface isn't parallel to the ground right?
    That makes more sense.
  16. Apr 4, 2022 at 6:42 PM
    #576
    Taco-Obsessed
    Yes. Hard to see in the photo where you circled but those attachment points aren't level with ground, at an angle.
  17. Apr 4, 2022 at 6:43 PM
    #577
    Kwikvette
    Fresno County
    4 run, 2 don't
    Fuck, well you know what that means.
    Part out your truck; dibs on your wheels and tires :burp:
  18. Apr 4, 2022 at 6:52 PM
    #578
    Taco-Obsessed
    Just put your 35s back on buddy.
  19. Apr 4, 2022 at 6:56 PM
    #579
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oh they were drrrrrrrrrry, they needed replacing.
    I wouldn't say no to an extra set of tires, some 35s, but not to daily drive on.
  20. Apr 5, 2022 at 5:42 PM
    #580
    Kwikvette
    Fresno County
    4 run, 2 don't
    Decided to finish up welding the bumper!
    Just needed some seams on the inside, the light brackets welded in, and the recovery plates.
    What's really nice is that Coastal Offroad offers not 1, but 2 positions for your light bracket depending on the type of lights you have.
    Since I'm running small 3" x 3" cubes, the closet position works best.
    What's interesting is how the recovery points are welded in; the bumper has a "recovery point" that's 3/16" thick just like the front plate.
    Except that it receives 2 more plates of the same thickness, on each side. This makes for a really beefy recovery point.
    Hope you guys enjoy the weld porn!
    Lights will get wired up once I get a switch I like. :D
