The Bullaculla 3 link SAS build (pic heavy)
Discussion in '2nd Gen. Builds (2005-2015)' started by bullaculla, Sep 2, 2013.
  1. Jan 30, 2016 at 5:39 AM
    #681
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Been meaning to sub to this!
  2. Jan 30, 2016 at 5:41 AM
    #682
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    That's all I own haha
    deeezy[QUOTED] likes this.
  3. Jan 31, 2016 at 11:16 PM
    #683
    bullaculla
    bullaculla [OP] IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    So! These arrived this past week! I decided to skip the Moogs and OEM bushings to replace my bad bushings, and went for the TC LCAs and cam tab gussets since one of mine was flattened out.
    So sexy! :drool:
    Stock LCAs are easily removed by pulling the cam bolts, and then removing the two ball joint bolts at the bottom of the spindle.
    Next step is popping of the flimsy cam tabs, and they are only held on by tiny spot welds. Luckily there were small dimples where they were welded, which made them easy to drill. Just make sure you don't go too deep! :eek: Drill them and then pop them off with a big screwdriver or chisel.
    Paint removed for welding. you can see where I went a little too deep with the drill. More paint was removed prior to welding. Some of the flared corner had to come off to fit the TC tabs.
    I had my pipe fitter friend from work TIG weld the TC tabs before hand to save time. They get welded from the back first, then he welded the sides, and wrapped the corners for strength.
    Nice having your own sandblast cabinet :D
    On to the cam bolts! And they looked worse than I had hoped... :puke:
    Fortunately they cleaned up nicely on the lathe with a wire brush. But when we were fitting the tabs on the truck, we realized that the pairs of cams were slightly different sized. I think the rear cam on the front was bigger, and the front cam on the rear was bigger? :confused:
    Not too much of a problem when you have a mill :cool:
    After opening a few of them, they rotated smoothly.
    So with the tabs fitted, my welder went to town. I think TIG would be the only way unless you remove the axle. Its pretty tight in there. Sheet on the sliders were to give a draft free environment. And don't worry, there are 4 jackstands under the front of the truck, and its in a flat garage.
    Luckily shipyard pipefitters are used to working in tight spots. He said it wasn't too bad! He was in a half crunch most of the time and controlling the foot pedal with the side of his knee...
    Badass! :headbang:
    Not bad :D Fully welded.
    Painted. I realized the fully welded tabs would hold water that could enter the gap, and the cut at the top for indicating position. So I decided to stuff everything with grease :oops:
    Recruited some help from my daughter! She screwed in the grease nipples, tapped in the poly bushings with a soft mallet, greased the ID of the bushings, and then I showed her how to press in the steel sleeves with a C clamp and some aluminum blocks.
    Coated the LCA hardware with some dry moly spray.
    Decided to cut some 6061 on the lathe. The TC LCA requires a spacer to lengthen the bumpstop, and the kit included a steel puck that needs to be welded to the frame.
    I had enough of welding things to my frame and decided to make my own out of aluminum and planned to get longer bolts for the superbumps.
    Unfortunately, there are no m10x1.25 socket cap screws anywhere on this island!
    So I took the steel pucks I was gonna toss in the trash, skimmed off 0.200" from the face so the bumpstop bolts would be long enough temporarily, and then cut flats to make them easy to remove once the LCA is installed.
    My Little Machine Shop machines aren't used to cutting steel, but they both did great!
    Longer bolts are on order, but this should be fine for a bit.
    Now we were getting close and I realized how big the socket cap screw for the uni ball was. I didn't have a 5/8" hex wrench of any kind, so back to the mill! Made an adapter out of some 1" mild steel round bar. It was a nice opportunity to show my daughter what I do at work nearly everyday. Which is solve problems, make cool stuff that nobody else can make, and then gloat about how awesome it is to be a machinist :rofl:
    And of course it worked perfectly and the large size is 7/8" and is long enough to bottom out my socket wrench. Even tho its mild steel, I still decided to torch and quench it because I thought my daughter would get a kick out of it.
    And its assembled! Beautiful rusty springs! :laughing:
    I filled the TC logo with silicone because it would hold water and get between the plates where the powdercoating probably couldn't get and rust it out. They look incredible tho! And super beefy! Definitely gonna solve my knocking problem.
    Gave it a quick eyeball alignment and drove around the block real quick. Drove nice but steering wheel is a little off. But I left it. I plan on getting an alignment ASAP.
    Then a good pressure wash. Anytime you grind on your truck, wash it well to get all the fallout off.
    So I will get some better pics and review later. One day I want to get their +2" long travel kit, and I figured these would be easy to sell. I just didn't want to mess with pressing in new bushing that will probably go bad in a few years again. At least these are rebuildable and should increase strength and performance.
    BTW! Big shout out to @YotaDan at wheelers off road for getting the total chaos LCAs, cam tabs, ext brake lines, and superbumps to me. We usually get screwed when shipping large of heavy items to Hawaii, but wheelers was great!
    I hope some of this helps someone, or was atleast an interesting read!
    Thanks for looking! :cheers:
    Bobcdn, \000/, madsand and 18 others like this.
  4. Feb 1, 2016 at 12:07 AM
    #684
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    holy shit your cam bolts looked like fucked playdough turds
    stlntaco likes this.
  5. Feb 1, 2016 at 12:12 AM
    #685
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    All I can say is sweet! Loved the write-up! Lmao!
  6. Feb 1, 2016 at 6:39 AM
    #686
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    @bullaculla That looks great and you did a fantastic job with all the custom fabbing and all. I'm a little surprised with all that beef that you haven't done any spindle gussets
  7. Feb 1, 2016 at 7:01 AM
    #687
    bullaculla
    Da big big island!
    That's probably next. The cheap stuff :D
    Thanks BTW :cheers:
  8. Feb 1, 2016 at 8:04 AM
    #688
    BWS
    BWS Well-Known Member
    Kapolei HI
    2014 DCSB TRD OFFROAD 4X4 6SPEED
    Kings All Around, LR UCA, Allpro leafs, BHLM
    Those LCA's looks sick.
  9. Feb 1, 2016 at 8:05 AM
    #689
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    I hate you... not really but definietly admiring your skill set.... I wish I could fab up all that cool stuff....
    Oh the LCAs are nice too..... lol..lol
  10. Feb 1, 2016 at 8:14 AM
    #690
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Yeah no kidding. Nothing compared to those UCA's and LCA's! I just figured since you knew someone that can TIG weld
  11. Feb 1, 2016 at 9:09 AM
    #691
    bullaculla
    Da big big island!
    Hahaha! Thanks Neil. Only problem now is that my wife wants those for her 4Runner :facepalm:
    squint0241 likes this.
  12. Feb 1, 2016 at 9:12 AM
    #692
    bullaculla
    Da big big island!
    They cleaned up pretty good tho. Looked great with the dry moly coat.
  13. Feb 1, 2016 at 9:15 AM
    #693
    bullaculla
    Da big big island!
    I plan on tigging the spindles myself actually. At least those are out in the open. My buddy used all my equipment for everything. I'm just not comfortable welding on the frame, especially in tight spots.
  14. Feb 1, 2016 at 1:03 PM
    #694
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Cool. I had my buddy TIG mine but I have an extra set and they were off the truck
  15. Feb 1, 2016 at 9:37 PM
    #695
    bullaculla
    Da big big island!
    So I had to unbolt the spindle and uniball joint today to access the large bolt.
    I didn't have the right socket to properly torque the nut.
    You need a 1 1/8" thin wall socket to get into this pocket. I had to buy one and then neck it down on the lathe.
    Torquing it to over 100ft lbs was no problem with specialty tools :D
    Also, I got an alignment today running 4.8 degrees of caster. Rides really smooth. Steering feels better than before. But I soon realized that I no longer have the stock steering stops, and my tire can turn far enough to rub my pretty new LCAs :(
    But I still love it. Just gotta keep an eye on how far I steer. Especially while off road. Now that I have these arms, I want the long travel kit even more! :cool:
  16. Feb 1, 2016 at 9:45 PM
    #696
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    You think those LCA's allow for a little more caster?
  17. Feb 1, 2016 at 9:50 PM
    #697
    bullaculla
    Da big big island!
    It seems like it. I looked at the cam bolts and it looks like more could be added. The most I got out of the stockers was 4.2.
  18. Feb 2, 2016 at 4:26 AM
    #698
    polekasta
    polekasta Well-Known Member
    Wahiawa, Oahu, Hawaii
    06 4x4 long bed
    add a leaf, Bilstein 5100's
    I feel so left out now. :( No moolah to buy anything. Tax return check can't come fast enough.
  19. Feb 2, 2016 at 7:41 AM
    #699
    deeezy
    Dana
    Hawaii
    Awesome! Now I just have to blow up my stock lower control arms so I have a good reason to purchase some aftermarket lowers.
    Sacrifice likes this.
  20. Feb 2, 2016 at 5:00 PM
    #700
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    :popcorn:
