The Bullaculla 3 link SAS build (pic heavy)
Discussion in '2nd Gen. Builds (2005-2015)' started by bullaculla, Sep 2, 2013.
  1. Mar 5, 2017 at 4:00 PM
    #1041
    bullaculla
    bullaculla [OP] IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    So I can't do anything until I get the pan hard bar and tie rod, so I decided to work on my twin sticks. I wanted a clean way to seal the hole, and also decided to make the sticks work better.
    First thing i did was get rid of the nut and bolt because the instructions say to seal them with silicone of something after assemble, plus the diameter of bolts are usually pretty undersized so they were pretty sloppy. So I made a precision steel rod with a head, o-ring grooves to seal it, and a retaining clip groove. I also reamed out the aluminum body for a good seal.
    Now the sticks have very little side to side slop.
    Then I found a suitable shift boot that I thought would work (bought around 5 from eBay trying to find one that works) and then cut down the front range twin sticks base, and left a step in it that was just a little thinner than the shift boot thickness for some squeeze on the rubber, and made another plate to act as a clamp.
    When assembled, it's still the same height as the original lower plate.
    And here it is installed. The underside of the tunnel is pretty flat, and there is a little pressure against the underside of the body to form a decent seal, but I will probably seal it completely with mastic.
    Now I just have to cut and bend the sticks so I can put my console back together.
    I'm very happy with the results :cool:
    Nickel, jubei, Nate87 and 16 others like this.
  2. Mar 5, 2017 at 4:26 PM
    #1042
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    Sick!!!
  3. Mar 5, 2017 at 5:20 PM
    #1043
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    That looks really good
  4. Mar 5, 2017 at 5:27 PM
    #1044
    bullaculla
    Da big big island!
    Thanks guys! I'm actually gonna redo both the bottom base and clamp and make it a little wider so I get more bite on the rubber. I'm also gonna put a heavy top and bottom chamfer on the clamp so it'll be more gentle on the rubber.
  5. Mar 9, 2017 at 12:40 PM
    #1045
    Adventurous
    Adventurous Well-Known Member
    Colorado
    15 DCLB SR5
    Loving the progress! Keep up the good work mang, it's just as impressive to see the quality of the build as it is to see the neat little things you have turned out on the lathe.
    bullaculla[OP] likes this.
  6. Mar 9, 2017 at 1:06 PM
    #1046
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    And remember, Iven..........If you ever need something pounded with a big hammer, don't hesitate to call me. :rofl::anonymous:
    squint0241 likes this.
  7. Mar 9, 2017 at 1:53 PM
    #1047
    bullaculla
    Da big big island!
    I told you to come over twice already :rolleyes:
    deeezy[QUOTED] likes this.
  8. Mar 9, 2017 at 6:38 PM
    #1048
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    All talk and never puts out, huh? :rofl:
  9. Mar 10, 2017 at 10:59 AM
    #1049
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    Someone must be creeping this build thread.. :spy:
    TheTacoma, squint0241, Nickel and 2 others like this.
  10. Mar 10, 2017 at 11:06 AM
    #1050
    Vigo
    Vigo WFO
    '12 4 door
    stuff...
    Few more
    Bobcdn, Acerwin, squint0241 and 5 others like this.
  11. Mar 10, 2017 at 11:29 AM
    #1051
    bullaculla
    Da big big island!
    Great... that's perfect timing :rolleyes:
    Acerwin, Bobcdn, Nickel and 5 others like this.
  12. Mar 10, 2017 at 11:52 AM
    #1052
    THROTTLE231
    THROTTLE231 Well-Known Member
    Shane
    High Dez,Comifornia
    2011MGMDCSB6MT With Not So So Cool Shit...
    I LIKE BEER....
    X2:spy:
  13. Mar 10, 2017 at 12:55 PM
    #1053
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    I literally just laughed out loud here at work reading that comment. Thanks!
  14. Mar 10, 2017 at 12:57 PM
    #1054
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    Still good timing for me lol
  15. Mar 10, 2017 at 4:44 PM
    #1055
    bullaculla
    Da big big island!
    So I decided to make that new larger base for the twin stick.
    Messy! :eek:
    Here it is next to the original base. I went wider so there will be more bite on rubber boot.
    I also added a pretty good bevel on all the edges that will rub on the rubber.
    Has a step to fully seat the clamp without crushing the rubber.
    The clamp plate barely fits inside the bellows.
    I can't pull out the rubber at all when it's tightened down.
    No gap on the inside.
    Assembled with the FROR top block and my steel pin. Don't mind the hardware. It's just what I had laying around :oops:
    Now I'm really happy. I've had a few PMs asking about the block, so I am considering making a few more to retro fit the FROR twinstick, as well as the steel pivot pin.
  16. Mar 10, 2017 at 5:43 PM
    #1056
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    Bravo!:bowdown:
    Ya know Iven...you should start some kind of business...:rolleyes::rofl:
  17. Mar 10, 2017 at 6:02 PM
    #1057
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
  18. Mar 10, 2017 at 6:25 PM
    #1058
    Nate87
    Nate87 Well-Known Member
    Nate
    CONUS
    2013 AC TRD OR
    Nice! Put me down for one! Can't wait to see how this turns out. You're doing a hell of job with this build.
  19. Mar 13, 2017 at 11:05 AM
    #1059
    bullaculla
    Da big big island!
    I put a welder in my engine bay :D
    How's that reverse grip!
    Jesse @1uzrnr pretty much did all the work fitting up the steering box.
    @kumz and @squint0241 also hung out and watched Jesse work :rofl:
    Hard to tell, but we had to move the hole for the drag link forward 1/8" to keep the massive links from touching at full lock. I didn't snap any pics, but Jesse plug welded the hole, then ground it flat. I didn't have a 5/8" drill, so I had to setup the arm in the CNC mill and ran a quick hole pocketing program with a 3/8" carbide end mill. Worked great, hole is perfectly round and perpendicular.
    Gonna add a plate to double shear the pitman arm.
    Good progress yesterday :cool:
    jubei, Ugly Betty, Bobcdn and 16 others like this.
  20. Mar 13, 2017 at 11:33 PM
    #1060
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    You forgot to mention that I was eating all your food as well...:bananadance::dancingbacon::broccoli:
