The case of the missing oil drain plug washer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hook78, Nov 25, 2018.
  1. Nov 26, 2018 at 7:00 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Don’t tell anyone, but, I’m still using the original crush washer. Almost 100,000 miles.
    Edit; 100,000 miles now.
  2. Nov 26, 2018 at 7:05 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I prefer a fumoto valve so I never have to worry about that again. Install the supplied washer, and you’re good. Makes oil changes so easy and it’s only about $30
    TheDevilYouLove and ChadsPride like this.
  3. Nov 26, 2018 at 7:11 AM
    Clearwater Bill
    Billy
    Largo Florida
    Never replaced a crush washer (unless missing or broken on first change)
    Never used tape
    Never used a torque wrench
    Never had a drain plug leak
    Have no clue how many dozens of oil changes I've done over dozens of vehicles and decades of time.
    Dirtridercrf250, Jimmyh and fixer5000 like this.
  4. Nov 26, 2018 at 8:31 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    If I found out my washer was missing I’d drive the truck straight to the junkyard!!
  5. Nov 26, 2018 at 10:02 AM
    Hook78
    Hook78 [OP] Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    I'm very glad I started this thread because some have pointed out that they don't believe there's a flange on the pan. I may have double washered it. I don't understand why folks question why a thread was started if it's useful to others.
    whatstcp likes this.
  6. Nov 26, 2018 at 10:04 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    For all those who state that there's no flange on the pan, now you have me wondering if the crush washer just stuck to the pan. I really don't think so though, and I also think there must be a flange, because the bottom of the oil pan is not flat. The photo someone posted looks like the pan but without the threaded drain hole. But you're making me question myself now. I'm going to call the dealership and see if anyone has any worthwhile opinions, maybe I can also find a youtube video that would show it well enough. Checking will be expensive.
  7. Nov 26, 2018 at 10:07 AM
    eon_blue
    Azusa, CA
    Could just drain the new oil out into a clean container then put it back in, lol
    I know for a fact my oil pan isn't flanged but i have a 1st gen, so it might be different for you guys, I'm not sure
    blm likes this.
  8. Nov 26, 2018 at 10:08 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I never used to torque the oil drain plugs on any of my vehicles, and never had a problem. I found this spec for my Tacoma about 5 years ago, and I have been torquing the oil drain plug to 28 lb-ft ever since. I figured there is no reason not to... but you give me a reason just now.
    Is this real? I mean, 100% for sure? I don't recall anyone mentioning this before. If it is real, does this follow the same 15-20% torque reduction, as when using anti-seize on spark plug threads?
  9. Nov 26, 2018 at 10:11 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Great point on recycling the oil through.
    From the few decent pictures I can find online, it looks like there is indeed a flange. I remember looking at it closely with a flashlight and it was shiny, flat metal. I don't think the crush washer would look even remotely like that. I think I'll just check the oil level more often than usual and check for leaks from time to time.
  10. Nov 26, 2018 at 10:13 AM
    eon_blue
    Azusa, CA
    yeah honestly it if isn't leaking then you're probably good, just keep an eye on it. It's not as potentially dangerous as ending up with a double seal on your oil filter if the old one sticks...that can be catastrophic quick (always check to make sure that hasn't stuck on, not as likely to happen but it can). You'd know pretty quickly though when oil starts to spew everywhere lol. Thats why they say you should always run the engine in park for 5-10 minutes after an oil change to make sure all is well.
  11. Nov 26, 2018 at 10:15 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    I replaced my washer at 190k mIles or so. Box of filters came with them. Not changing it again until it leaks. Pain to get that damn thing off the plug .
  12. Nov 26, 2018 at 10:19 AM
    zjcas
    zjcas Well-Known Member
    Zach
    Hooksett
    2012 DCSB TRD Sport
    Fox 2.0 COs, Fox 2.0 Resi's, Wheeler's Prog. AAL.
    My friend...As maaaaaany folks have been saying that "flange" was a stuck crush washer. I'd bet money on it. If you aren't leaking I guess it's not the end of the world but my first oil change on this truck I had that same "huh where's the washer" moment and then said oh shit it's seized on the oil pan, had to pry it off with a flat head. I use a Fumoto now, may change the washer out after my 3rd/4th oil change with it just for shits and giggles but it's the same reason I always check to make sure I didn't lose the O-Ring off my filters, cuz sometimes that shit sticks.
    Again...if you aren't leaking oil I don't see this being the end of the world, just running the risk of it happening over time
  13. Nov 26, 2018 at 10:21 AM
    hemmjo
    hemmjo Well-Known Member
    Central Ohio
    2005 Access Cab 4wd, TRD, Off Road, Tow Package
    If your oil drain plug is leaking enough to damage your engine due to lack of oil, you will notice a spot under your truck, before it shows up in the dipstick. Unless.... you change your oil then take off on a cross country trip. You should notice just a few drops on the ground. There are almost 15,000 drops in a quart.
    Pour a 1/2 quart of oil (7,500 drops) on the ground and see how far it spreads.....
  14. Nov 26, 2018 at 10:29 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    yup, most of the time i have to give the stuck washer a whack to remove it. I think it is a flat surface, so that flange was prob the washer.
    Oh, and teflon tap on straight threads will only slow a leak, not stop one
  15. Nov 26, 2018 at 10:40 AM
    #35
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    I remember a commercial one time where someone got peanut butter on another persons chocolate. That turned out ok, though past results do not ensure future outcomes. ....think i saw that on a different commercial.....
    racerX969 likes this.
  16. Nov 26, 2018 at 10:52 AM
    #36
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    You know things are slow in TW when there's two pages on a missing drain plug washer...:D
    racerX969, Lester Lugnut and eon_blue like this.
  17. Nov 26, 2018 at 10:58 AM
    #37
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Watched a few videos and what I thought was the flange has to have been the washer. There's no flange. Shit. I'm too OCD to just leave it as is :( And I'm so OCD I'd probably put in a new 5 quarts after fixing the washer situation. Even worse.
  18. Nov 26, 2018 at 11:10 AM
    #38
    Titanx85
    Titanx85 Well-Known Member
    AJ
    Between Lexington, VA and Richmond, VA
    2006 Red Tacoma crew cab long bed
  19. Nov 26, 2018 at 11:13 AM
    #39
    Hook78
    Eastern NC
    2015 DCSB TRD OR
  20. Nov 26, 2018 at 11:17 AM
    #40
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Yeah this is happening at my next oil change.
    EatSleepTacos[QUOTED] likes this.
