The Case of the Missing Oil Filler Cap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dmesser92, Oct 16, 2024.
  1. Jul 1, 2025 at 4:26 PM
    #81
    bmg88201
    bmg88201 Well-Known Member
    Brian
    Quitman, AR
    2022 Tacoma Limited
    It’s possible, the seal, when compressed a bit, may keep some tension on the cap and stop it from loosening. Also without the seal the cap may screw down too far and cause it to skip or strip a thread. But I still like the tether idea. Could drill a small hole in the raised handle of the cap and then fix a wire through it to a spot near the fill neck.
  2. Jul 1, 2025 at 11:20 PM
    #82
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    I'm sure you will see before you drill a hole but there isn't too much solid material to drill into on that cap handle.
    bmg88201[QUOTED] likes this.
  3. Jul 2, 2025 at 4:45 AM
    #83
    bmg88201
    Brian
    Quitman, AR
    2022 Tacoma Limited
    Very possible, I may not do anything at all since my cap has always been snug and never came off or been loose.
  4. Jul 2, 2025 at 8:37 AM
    #84
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    this thread got me to go look at my cap. i had a very hard time getting it off. it was me tightened it a year ago.
    i would have gone snug but not to the extent it was. needed channel locks to free it and was nervous about breaking it or filler pipe. so, i guess not a problem with loosening. there was even oil on the seal and neck that i wiped on to prevent sticking last year. more oil, less snugging this year.
    the tether sounds like a good idea and there seems to be plenty of room for a small hole in the finger grip of the cap. best use a drill press and small bit sized for chosen wire. i don't see a problem there but the many turns required to snug it down would cause the wire to bind up unless you got fancy with the anchor. Maybe a loose loop around the filler neck.
  5. Jul 2, 2025 at 8:47 AM
    #85
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    FWIW, My Husky chain-saw does the same thing. I have to get out the channel-locks to loosen it. It has little tooth marks on it from using them. A new cap and o-ring did the same thing. Next time I use it even when it's fully cold, the cap won't budge. It's like someone snuck in and used an impact wrench to tighten it down.
    Lawfarin[QUOTED] likes this.
  6. Jul 2, 2025 at 8:51 AM
    #86
    pdxTacoSR5
    PDX area
    lol. every chainsaw i have used has had that problem on gas and bar oil caps. some have a split handle on cap you can wedge the bar nut tool into for cranking on it to loosen...but really a pain sometimes.
    correction stihl has flip handles and have not had much problem with it.
    Williston[QUOTED] likes this.
  7. Jul 2, 2025 at 10:39 AM
    #87
    Ptteddy
    Ptteddy Member
    My cap was super tight. 17x oil changes. Everytime it was tighter than I expected. Sometimes had to get the crescent.
    Guys with loose caps, maybe try flipping the oring around.. whatcha got to lose?;) And report back after next refuel..
