The Correct Way To Drain/Fill the 4.0 Antifreeze
Discussion in '2nd Gen. Tacomas (2005-2015)' started by parfleet, Apr 21, 2010.
  1. Oct 23, 2017 at 9:35 PM
    #181
    Mudman
    Mudman Well-Known Member
    Cerritos
    08 4X4 TRD Sport
    Okay, I was wondering about that. Most people don't seem to be flushing at all.
  2. Nov 16, 2017 at 9:32 PM
    #182
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
  3. Nov 17, 2017 at 1:44 PM
    #183
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
  4. Dec 30, 2017 at 7:59 AM
    #184
    Ncskeeter
    Ncskeeter Well-Known Member
    North Carolina
    2005 Silver Tacoma Prerunner DCSB SR5
    Mostly stock
    I did this PM yesterday. A few observations I made.
    1. The passenger side engine block drain tube was clogged with what looked like a mud dauber nest. I tried to break it up as best as I could. Then I thought water pressure would push the rest out when I opened the drain. Not true. I ended up taking the drain plug all the way out. What a mess. Way more coolant came out then I was prepared to catch. As far as I know the drain tube is still clogged. I didn't want to risk pushing the crap back into the engine cooling passages.
    2. I easily found the drivers side drain, but quickly decided it's not worth messing with. I exchanged around 7 quarts without touching this drain.
    3. I expected the radiator to start draining after a quarter turn. It took a couple of turns before it started to drain.
    4. After 13 years and 102k miles, the coolant looked brand new still.
    5. It doesn't seem that I ended up with much air in the system. I burped the hoses and didn't get many air bubbles out. Truck warmed up to normal temperature just as before.
    PzTank and sioux like this.
  5. Dec 30, 2017 at 7:35 PM
    #185
    crx7
    crx7 1997 FZJ80 Triple Locked
    Grand Junction Colorado
    Wow, that driver's side is impossible. At no point did I actually see it, just felt around for where I thought it should be from the videos.
  6. Dec 31, 2017 at 5:29 AM
    #186
    Ncskeeter
    North Carolina
    Mostly stock
    I could easily see it though the wheel well. I have a Prerunner though. The front driveshafts might obstruct the view on a 4x4.
  7. Dec 31, 2017 at 5:39 AM
    #187
    Ricky B
    Ricky B Well-Known Member
    Arkansas
    1998 XCAB
    If you take your front tires off they are easy to find. One of mine was stopped up from mud and a small pick was used to clean it out. Mine had almost 200,000 miles and I flushed it with white vinegar. Previous owner did nothing but change the oil.
  8. Dec 31, 2017 at 5:42 AM
    #188
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    a
    lo2hi and Crom like this.
  9. Dec 31, 2017 at 3:41 PM
    #189
    Ricky B
    Arkansas
    1998 XCAB
    Clarification after white vinegar which I ran in Tacoma for 30 min. I flushed with distilled water.
  10. Dec 31, 2017 at 8:53 PM
    #190
    Ricky B
    Arkansas
    1998 XCAB
    If I would have purchased my Tacoma new I would have never use vinegar either. The trucks coolant had been in there for 10 years and had built up scale in the radiator. Seems like I read it somewhere and was optioned based on neglected radiators so I decided to do it. Now that it's done will probably drain radiator and refill once every year.
  11. Jan 2, 2018 at 8:24 AM
    #191
    Ricky B
    Arkansas
    1998 XCAB
    Always a good idea to watch your reservoir after doing a flush or change. I noticed I added to my reservoir after a week of driving and then all has been good since.
    PzTank likes this.
  12. Feb 11, 2018 at 2:03 PM
    #192
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Did this today, drivers side drain plug was a bitch to get to. Thanks to @Koollata if he's still around. His pictures were a help.
    b_r_o likes this.
  13. Feb 19, 2018 at 9:11 AM
    #193
    ndub86
    ndub86 Well-Known Member
    Neal
    Dallas, TX
    '13 Double Cab 4X4 TRD Sport
    Subbed (doing it within the next month)
  14. Mar 4, 2018 at 7:57 PM
    #194
    2006 yoda boy
    2006 yoda boy Member
    2006 Toyota Tacoma prerunner
    So I wasn’t thinkin an I topped off my tacoma with reg green Prestone anti freeze. I drained it back out the reservoir. But I still have a little in the radiator will this be a problem? Should I drain an flush it immediately? Or can I get the pink 50/50 an just top it off an fill the reservoir?
  15. Mar 4, 2018 at 10:19 PM
    #195
    roadking1
    n.j.
    I have OCD and would have to drain everything and start over. Hopefully someone on here with chemistry knowledge will know the answer.
  16. Mar 6, 2018 at 8:41 PM
    #196
    crx7
    Top it off with Pink should be fine.
  17. Mar 7, 2018 at 6:40 AM
    #197
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    just an FYI......this stuff @ Walmart....$12 gallon & its red.....
  18. Mar 7, 2018 at 6:46 AM
    #198
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
  19. May 6, 2018 at 12:32 PM
    #199
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    Wouldn't 9 quarts be 1.75 gallons?
    O'Reilly told me it takes 10.3 quarts.
  20. May 6, 2018 at 12:38 PM
    #200
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    No.....7 Qts would be 1.75 gallons
    Norton likes this.
