The Correct Way To Drain/Fill the 4.0 Antifreeze
Discussion in '2nd Gen. Tacomas (2005-2015)' started by parfleet, Apr 21, 2010.
  1. Jul 9, 2018 at 8:18 PM
    #221
    Tacolvr79
    Tacolvr79 Well-Known Member
    Ben
    Missouri
    09 TX TRD Pro 6sd with 12+ conversion
    Complete interior and exterior led conversion, TRD short shifter, 12+ interior upgrades (steering wheel etc) aftermarket double din touch screen, marbled Sickspeed shift knob, blacked out headlights, taillights, and 3rd brake light, painted pinch welds, taco bed mat, taco all season mats, tonneau cover, charcoal filter delete, towing plug relocation bracket, '12 baja suspension, 12+ front end conversion, 30" led lightbar in lower grille, Meso interior lights, more to come...
    Um no i dont think so! Im gonna use the green. I know its not corrosive! Go troll somebody else!
  2. Jul 9, 2018 at 8:20 PM
    #222
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Then by all means - use green coolant and while you are at it use 10W-30 in your automatic transmission and 3-in-1 oil in your differential.
  3. Jul 9, 2018 at 8:21 PM
    #223
    Tacolvr79
    Ben
    Missouri
    You sir are an idiot
    Rambo54 likes this.
  4. Jul 9, 2018 at 8:22 PM
    #224
    Lester Lugnut
    Whatever you say...Troll
  5. Jul 9, 2018 at 8:23 PM
    #225
    Tacolvr79
    Ben
    Missouri
    Haha you calling me a troll is the pot calling the kettle black lol
    Rambo54 likes this.
  6. Jul 10, 2018 at 12:26 AM
    #226
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I'm not sure if you're being serious. But in case you are....your truck came from the factory with a HOAT pink formula. That's exactly what you should replace it with....either Toyota’s own LLC, SLLC, or some other HOAT formula. The pink/red color will prevent the mess created by mixing 2 different colors.
    You can use green coolant as long as it's ideally a HOAT formula. But it would be best to completely flush the system of the pink coolant first.
    But that's not necessary if you do 2 or 3 drain and fills over the course of a few days with the proper pink coolant
    Rambo54 and Sig45 like this.
  7. Jul 10, 2018 at 4:47 AM
    #227
    Tacolvr79
    Ben
    Missouri
    Yes im serious. Ive talked to my local toyota dealer and they told me that they had run into several things that had been "ate up" because of how corrosive the pink antifreeze is. I work at a dealership as well so we have rhe flushing machine there to do it right. Of course ive been told that it will have to be flushed very well because if any of the 2 different coolants mix it will gell up
  8. Jul 10, 2018 at 5:19 AM
    #228
    Plain Jane Taco
    USA
    Are you insinuating that Toyota’s own formulas are corrosive? If that's the case, you're losing credibility quickly. There are millions upon millions of Toyota vehicles running around on the factory fill LLC and SLLC that have never been flushed with 200, 300k+ miles on them, with zero issues with the cooling systems.
    The Zerex and Valvoline with Zerex pink formulas are silicate-free HOAT mixes that are not corrosive
    Norton, Rambo54 and Sig45 like this.
  9. Jul 10, 2018 at 7:04 AM
    #229
    Tacolvr79
    Ben
    Missouri
    Im not insinuating anything. Im going with the advice of my toyota dealer from what they have seen real world.
  10. Jul 10, 2018 at 7:07 AM
    #230
    Lester Lugnut
    I would love to know the name of the Toyota dealer that claims Toyota SLLC is corrosive. Please post it.
    Norton, BillsSR5 and Plain Jane Taco like this.
  11. Jul 10, 2018 at 7:42 AM
    #231
    Plain Jane Taco
    USA
    I agree. As a PSA for the rest of us...we need to know the name so we can avoid that service department altogether.
    Norton likes this.
  12. Jul 10, 2018 at 9:26 AM
    #232
    Tacolvr79
    Ben
    Missouri
    Lou Fusz Toyota
  13. Jul 10, 2018 at 9:29 AM
    #233
    Tacolvr79
    Ben
    Missouri
    All i know is that is what i was told. Hell from what you all are saying, they are wrong and after doing several searches on it i believe you all are right. I wont be going there again.
    sioux and Plain Jane Taco like this.
  14. Jul 10, 2018 at 9:43 AM
    #234
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
  15. Jul 14, 2018 at 6:45 AM
    #235
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    OP thanks for the write up! this post helped me drain and flush my coolant system.
    Process was very easy for any first timers.
    Based on peoples input I only drained from radiator and passenger side of block.
    I would recommend starting with passenger side drain first when engine is cold.
    I started with radiator and flushed with distilled water 3 times.
    On final drain i pulled the passenger plug.
    2 problems occurred.
    1st: it is extremely difficult to get to 10mm stud with hot engine / headers.
    2nd: since i followed service manual interval (100,000 miles) my drain cock was fully seized up.
    I ended up un-threading the whole unit to drain. I did NOT anticipate how much hotter the fluid in the block would be or how much would come out of larger hole.
    I drove the truck around a fews minutes after each flush and was amazed at the drop in operating temps.
  16. Jul 15, 2018 at 12:18 PM
    #236
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Just did mine for the second time. Dain/fill and new thermostat. Took right at 10 quarts of antifreeze. The driver side drain plug was a pain as usual. I forgot how hard it was to reach the back nut on the thermostat. That was worse than the driver drain plug. It definitely was time, the antifreeze was dark pink.
  17. Jul 31, 2018 at 6:21 AM
    #237
    dnaTRD
    dnaTRD Well-Known Member
    Couple questions here....I've read just about everything on this thread but want to be sure....
    I have a 2013 TRDOR V6 4.0 at 63K, haven't flushed the coolant yet.
    Is "draining the entire system" method the same as the "flushing it through the engine" method?? I've seen both methods done...just want to make sure it's doing the same thing.
    I would like to do the draining method...Will i need a fluid pump?
    Do you guys recommend changing any hoses while I'm changing the coolant? I assume the dealer is the best place to purchase these...
    Thanks guys!
  18. Jul 31, 2018 at 6:37 AM
    #238
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Mine has the OEM coolant in it. Never flushed or changed. Running well with 194,600 miles and using the original sparkplugs too.
    Want to flush it?
    Run a garden hose through it and idle engine for a while until clear
    Flush with distilled water twice or more ( buck a gallon at supermarket)
    add in the pure coolant (1/2 of system capacity) and then add your distilled water to the top
  19. Jul 31, 2018 at 7:23 AM
    #239
    Lester Lugnut
    Draining the entire system consists of emptying out the radiator and both sides of the block. Some would say you also need to clean out the heater core. It's my opinion that cleaning out the heater core is not necessary if you have stayed on top of maint from the get-go.
    Flushing - do the drain and fill mentioned above and then use garden hose as mentioned above. In order to flush more of the block you would remove the thermostat and put it's cover back on; then flush - but again - if that's all you do - the contents of the heater core remain - not a TOTAL flush.
    Personally - I just drain radiator and both sides of block and refill because I change fluids more often than the mfg. schedule calls for.
    Countless opinions on what should be done. Pick a card.
    dnaTRD likes this.
  20. Jul 31, 2018 at 7:54 AM
    #240
    dnaTRD
    Awesome...thanks for the input. I think I'll be doing the same with mine...drain the radiator, both sides of the block, and refill.
    TacomaCZman likes this.
