The Correct Way To Drain/Fill the 4.0 Antifreeze
Discussion in '2nd Gen. Tacomas (2005-2015)' started by parfleet, Apr 21, 2010.
  1. Mar 8, 2014 at 6:36 AM
    #61
    morelia
    morelia Well-Known Member
    conroeeee
    k&n intake. hid kit sound system
    I just thought that I might save me some $ and buy 2gal instead of 3.
  2. Mar 8, 2014 at 6:47 AM
    #62
    tony2018
    tony2018 Well-Known Member
    Thanks for the write up, I laughed when you said "they are wrong".
  3. Mar 8, 2014 at 11:25 AM
    #63
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    yup, i wasn't able to drain out the full capacity either. Not a big deal. I kept the extra jug as a spare. Yes, save your monies and purchase just 2 gal., you can always go back and buy more.
  4. Mar 8, 2014 at 11:46 AM
    #64
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    So what is the correct mileage intervals ? I to find it hard to be leave that it should go 100k .:confused:
  5. Mar 8, 2014 at 12:39 PM
    #65
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    dealer told me I was scheduled to do mine at 130,000km (about 80k miles) When I looked it up in the owner's manual it stated 160k km = 100k miles.
    Mine was still pink, with no particles or anything that would suggest its gone bad. I don't know what the used pH was at or anything so appearance isn't everything.
  6. Mar 8, 2014 at 1:17 PM
    #66
    tacoma guy
    Joe
    Phoenix Az.
    Yeah I'm not sure what to think. I know that my 99 Tacoma it was every 60k. I live in Arizona and the heat in the summer is rough on them. I was reading a thread a while back that guys where having issues after they did the tranny fluid. So yeah don't know what to think.
    asuchemist likes this.
  7. Mar 8, 2014 at 1:22 PM
    #67
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    compared to fuel cost per year, fluid changes are relatively cheap. Type of use the truck goes through ie towing, running hot, etc. counts for a lot. Changing fluids sooner does no harm, and likely could prolong the life of the mechanicals. Only harm is to the wallet. Take this as my opinion though; I'm not a mechanic.
  8. Mar 8, 2014 at 1:24 PM
    #68
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    Do you guys know if I can simply add some OEM coolant to what I have without replacing all the fluid? Probably have 20k miles since last flush, and it's getting to "low." I simply want to throw more pink into pink.
  9. Mar 8, 2014 at 2:02 PM
    #69
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Yes, that is what you would do. The question is 'is there a leak'? Check your carpets inside the front cab, in case there is a leak on the heater core. Usually you smell it if it is leaking in the cab.
  10. Mar 8, 2014 at 2:07 PM
    #70
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Cool, thanks. You suggesting there may be a leak? I assumed it evaporated or was used up. I live in Los Angeles, so my ac is often on.
  11. Mar 8, 2014 at 2:15 PM
    #71
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Coolant system is a closed loop system, that has pressure in it when running. Coolant doesn't get used up unless there was a head gasket leak into the cylinder. (Exhaust would blow white smoke - steam if there is a head gasket leak.) I understand the reservoir draws fluid into the system, when the system cools down and there is a vacuum in the system. It should not evaporate, from my understanding. Are you talking about just the reservoir tank, or is the fluid actually low in the radiator when you check?
  12. Mar 8, 2014 at 2:22 PM
    #72
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Just in the reservoir tank. I almost lost the engine at 6k miles due to mud in the radiator, and $5k here we are. Noticed last week that the coolant was almost at "low" when the truck wasn't running. Haven't noticed it at other times, though. Haven't popped the cap to check the radiator either.
  13. Mar 8, 2014 at 2:35 PM
    #73
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    I gather what you mean is the outside of the radiator was plugged with mud versus mud mixing in with the coolant, and the engine got hot. Overheating an engine can lead to warped heads and head gasket failure. From what you are describing, with there still being fluid in the reservoir, you probably don't have a problem. Do check out the level in the rad, when the engine is cold.
  14. Mar 8, 2014 at 2:40 PM
    #74
    carcharias
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Yeah, sorry, I should've been more clear. The radiator was plugged, and the engine overheated massively. Could barely get it home - waited until nightfall and stopped often to dump more coolant in. Toyota said the block was fine, but needed to replace the gasket as well as tear everything apart and get the mud off. Thanks for your help, Rob!
  15. Mar 15, 2014 at 3:37 PM
    #75
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    What's the concensus on Non-OEM fluid such as this Zerex Asian Vehicle 50/50 mix?
  16. Mar 18, 2014 at 7:17 PM
    #76
    Sandman614
    Tim
    '06 SR5 Off Road
    Between opening both block drains and the radiator drain I only got about 2 gallons out (spilt some). I can't even get 2 full gallons back in it. Gonna run it tomorrow to work and check the coolant level again.
  17. May 13, 2014 at 11:05 AM
    #77
    AnotherSilverTaco
    AnotherSilverTaco Well-Known Member
    South Texas
    2006 Double Cab 4x4
    CBI trailrider rear bumper, CBI Front Receiver, Warn M8000 Receiver Winch in Warn Multi-mount cradle
    Did this today. Once you know where the engine drains are you don't really even need to crawl under the truck. Turn your wheel right and you can easily see the drivers side plug through the wheel well. Next time I do this I will just use a mirror to view the drains. If you paid the dealer to do this you are nucking futs!
    TacomaCZman likes this.
  18. Jul 9, 2014 at 8:45 AM
    #78
    ecrepeau
    ecrepeau Well-Known Member
    No reason not to use it.
    Also, you could use Beck/Arnley Red Concentrate or the Pre-mix Pink Extended from them. Red Concentrate is good to 100,000 miles mixed with distilled water and the pre-mixed Pink Extended is good to 150,000 if a complete flush is done. Not sure about the Zerex, but the Beck/Arnley is certified to not void the Toyota warranty.
  19. Aug 8, 2014 at 5:49 AM
    #79
    FFMast
    FFMast Custom Dude
    North Florida
    13 TRD Off Road 4x4
    Bilstein 5100's . Add-a-Leaf. Interior LED's. Husky floor mats. Thule rack. Various little things...
    sub'd
  20. Aug 11, 2014 at 2:52 AM
    #80
    empty hull
    empty hull Active Member
    Tim
    Baton Rouge, La
    Prerunner V6 SR5 TRD Off Road
    I just changed my antifreeze using this thread as a guide and would like to say thanks to all who contributed to it. The driver side was very very tight and had to remove the tire to get enough room to drain it. It took me 2 gallons to do it. I have a 2009 Tacoma Off Road and have 71K on it now. Fluid looked good. Tim
