The Correct Way To Drain/Fill the 4.0 Antifreeze
Discussion in '2nd Gen. Tacomas (2005-2015)' started by parfleet, Apr 21, 2010.
  1. Aug 12, 2014 at 5:22 AM
    #81
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    What is the interval for changing antifreeze in the Tacoma? My truck is a 2005/145k miles and I believe it still has the original pink stuff from the Factory. It seems to be cooling normal and has had no issues I don't see a reason to mess with a good thing. I have added a little distilled water to the reservoir on one or two occasions since I've owned the truck but other than that it's running flawless.
    Anybody know the lifespan of the Water pump? if that starts to fail then I'll replace the whole coolant along with the pump.
  2. Aug 12, 2014 at 6:09 AM
    #82
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Subbed. Would like to do this soon, replace water pump and thermostat as well.
  3. Aug 13, 2014 at 7:07 AM
    #83
    ecrepeau
    ecrepeau Well-Known Member
    100K so you are current 45K past when it should have been done. For some reason Toyota has it as 100K the first change and 50K after that which doesn't make sense to me as the fluid would be good for another 100K.
    Can't say I follow your logic on not changing it and just adding distilled water. Would you do this with your oil??? Nope because it breaks down and the same applies for coolant.
  4. Aug 14, 2014 at 4:53 AM
    #84
    empty hull
    empty hull Active Member
    Tim
    Baton Rouge, La
    Prerunner V6 SR5 TRD Off Road
    Adding distilled water will dilute the antifreeze ratio of 50/50. I would change the antifreeze out now. I may be wrong but I think it is 5 years or 100,000 miles. Mine was at 5 years with 71,000 miles on it. It still looked good but peace of mind doing it. Tim
  5. Aug 21, 2014 at 6:09 AM
    #85
    esse10
    Texas
    I said I added a little distilled water on one or two occasion not on a regular bases or weekly. Adding 3-4 ounces of distilled water to the reservoir once or twice in 8 years is really not that much to make a difference in the 50/50 ratio. I have seen guys use 60/40 ratio during the summer and then change it back during the winter months. I do all city driving so maybe that's why my coolant stays clean. I don't pull anything heavy or off-road either.
  6. Aug 22, 2014 at 6:30 AM
    #86
    ecrepeau
    Stays "clean"??? Well yeah it is a closed system so it doesn't matter if you drove on-road or off-road....The protective properties of the coolant breaks down over time. End of the story is you should change the coolant regardless of it being diluted or not as you are over the millage\time interval for this to occur.
  7. Aug 22, 2014 at 6:52 AM
    #87
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Could one just do the following:
    1. Siphon out what's in the reservoir (when cool) and replace exact amount
    2. Drive a bit & let cool
    3. Repeat a few times
    Wouldn't that replace most of the coolant after a few times much like the drain & refill process for the tranny fluid?
  8. Aug 22, 2014 at 7:16 AM
    #88
    Koollata
    Koollata Member
    2007 TRD Sport PreRunner
    The amount in the reservoir is significantly less than the amount of coolant in the rest of the system. You would be doing this a lot more than a few times. I'm also not sure how much, if any, cycling of fluid occurs between the radiator/engine block and the reservoir.
    If you refer to post 47, there is also no need to siphon from the reservoir. It would be much easier to just remove the rubber cap.
  9. Aug 25, 2014 at 4:55 AM
    #89
    esse10
    Texas
    I don't believe the system works that way where the coolant cycles through the reservoir all the time. On a 2011 year old truck I wouldn't worry about changing that coolant for a couple more years or 100+k miles, especially if you have that Toyota long life coolant/pink stuff. Now if you have mixed regular tap water or other different coolant in there than yea you need to replace the coolant asap.
  10. Aug 25, 2014 at 6:18 AM
    #90
    Sig45
    Mark
    Maine
    Thanks!
  11. Aug 26, 2014 at 6:46 AM
    #91
    ecrepeau
    What have you guys been doing to dispose of the used coolant? Here in NY it is state law for a service center to accept your used oil, not so much the case with used coolant.
  12. Oct 9, 2014 at 11:16 AM
    #92
    mak90
    mak90 Well-Known Member
    Central Coast, Ca.
    06 Tacoma 4x4 TRD Off Road 6 spd
    TRD Exhaust, TSB springs,Weathertech mats,Bed mat, Wet Okole seat covers, TRD Pro Suspension
    Sub'd
  13. Oct 9, 2014 at 12:04 PM
    #93
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I've yet to dispose of mine. Advance told me that the garbage facilities/dumps have arrangements to take care of it.
  14. Oct 9, 2014 at 12:33 PM
    #94
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    Local facilities here take it for recycle.
    10 years/100k miles is good enough. At that point, replace the upper/lower radiator hoses too. Don't think the block drain is necessary but it's your choice.
    @ 10 years, drain the radiator, 8 quarts out, replace two hoses, 8 quarts premixed OR 100 percent gallon with gallon of DISTILLED water ( use water from my dehumidifier (run thru a coffee filter). Prob easier for premix.
  15. Oct 9, 2014 at 2:32 PM
    #95
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Did you use the Zerex Asian Vehicle 50/50 mix?
  16. Oct 9, 2014 at 6:46 PM
    #96
    Sandman614
    Tim
    '06 SR5 Off Road
    Yessir!
  17. Oct 13, 2014 at 5:48 PM
    #97
    Crom
    Nick
    San Diego, CA
    Millions
    Same thing happened here. Put the Zerex Asain in. Going to run it and recheck. Just 5 years old and 50.2K on the clock. Cheap insurance. The drivers side block drain was a pain.
  18. Oct 13, 2014 at 7:22 PM
    #98
    Sandman614
    Tim
    '06 SR5 Off Road
    Pain to get to or pain otherwise? I think the whole piece unscrewed when I took one of them out. Worked it for a minute and oiled it and the drain screw came loose.
  19. Oct 13, 2014 at 7:31 PM
    #99
    Crom
    Nick
    San Diego, CA
    Millions
    Drivers side block drain was difficult to access. I had to feed a drain tube in through the wheel well, then from the top find by touch the hose barb, confirm from wheel well. Insert ratchet from wheel wheel, break bolt loose from top of engine bay. My ratchet with extension was at least 1/2" too long, so difficult to operate. With as little coolant that came out that side (I did that side last) I may skip it altogether next time I do it in 5 years. I think I maybe got 12oz out that side. All together I got almost 2 gallons out. To make matters more difficult, I used 3/8 fuel line as a drain hose (all i had), it works, but it drips from the barb too, so paper towels were mandatory.
  20. Oct 14, 2014 at 6:48 AM
    #100
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    While on the subject of coolant - getting trapped air out of the system comes to mind. For yrs. I would simply idle the motor once filled with new coolant and radiator cap off with a sock attached to the radiator neck. Heater on and running. Once at operating temp I would quickly depress gas pedal, wait a few secs and do this repeatedly. This causes the water pump to push coolant to the top, along with trapped air. The sock helps to keep things from getting too messy.
    Then I discovered this gadget from Lisle Tools. There are countless videos on how to use it on youtube.
    No more air in the cooling system and no more mess. The sock helps - but it still gets messy.
    http://www.lislecorp.com/divisions/products/?product=606
    TacomaCZman likes this.
