The Correct Way To Drain/Fill the 4.0 Antifreeze
Discussion in '2nd Gen. Tacomas (2005-2015)' started by parfleet, Apr 21, 2010.
  1. Dec 19, 2015 at 3:00 PM
    #121
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    Correct. Tap water has minerals in it that can corrode parts of the cooling system. If you insist on flushing it, you can used distilled water. It's cheap for a few gallons.
  2. Dec 31, 2015 at 8:27 PM
    #122
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    You are probably right. However, I am changing mine at 60k. Since I bought it used I like knowing what fluid I have in my truck. Thanks for assuring me that this fluid can last to the 100k interval.
  3. Jan 1, 2016 at 12:20 AM
    #123
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    You should read about electrolysis corrosion.
    You are potentially damaging the insides of your cooling system, unless you have added a neutralizing agent.
    Here is the moral to the story, "... if the corrosion inhibitors in the coolant are worn out because the coolant has not been changed in years, or there are stray electrical currents that are flowing through the coolant because of missing, loose or corroded engine ground straps, electrolysis can eat away at the heater core, radiator and any other aluminum parts in the system (including the water pump and passageways in aluminum intake manifolds and cylinder heads).
    http://www.aa1car.com/library/cooling_system_electrolysis_corrosion.htm
    Norton, Biscuits and Crom like this.
  4. Feb 8, 2016 at 9:06 PM
    #124
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
  5. Feb 9, 2016 at 5:50 AM
    #125
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    For some reason post #124 got me to thinking about a member here who turned 300K recently. Transmission fluid had never been changed.
    TacomaCZman likes this.
  6. Feb 9, 2016 at 8:09 PM
    #126
    Chuy
    Lakeside, CA
    Silver Taco
    The person that smokes and lives to a hundred is the exception, not the rule.
  7. Mar 13, 2016 at 3:40 PM
    #127
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    :thumbsup:. This got me thinking. It may last 100k mi and many years but you got to check it periodically. I just checked mine and the res is empty :eek:. All this long lasting stuff in these trucks has made me complacent. But you have to change the spark plugs at 30K? I did that and they looked like they could go another 30k easily. No more ignoring my truck. Time to get some of that super long life coolant and top it off. :(
  8. May 29, 2016 at 1:13 PM
    #128
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Ok so I did my 60,000 mile spark plug change and noticed that my coolant is sitting about a quarter inch above the 'low' line. Is ok to just add coolant or do I need to actually drain and flush and refill with all new coolant?
  9. May 29, 2016 at 2:00 PM
    #129
    TrdSurgie
    TrdSurgie revised
    Oahu
    You can either add some distilled water, coolant, do a drain and fill, or nothing.
  10. May 29, 2016 at 2:36 PM
    #130
    Chuy
    Lakeside, CA
    Silver Taco
    ^^^ What he said, except for the nothing part. Check hoses and radiator and under water pump to see if you may have a leak. Keep an eye on the level.
    BulletToothTony likes this.
  11. May 29, 2016 at 2:55 PM
    #131
    BulletToothTony
  12. May 29, 2016 at 3:59 PM
    #132
    NMPatronis
    NMPatronis Well-Known Member
    Nick
    Plainfield Illinois
    2012 MGM DCSB TRD Off Road.
    Working on it!
    Anyone running waterless coolants?
  13. Jul 23, 2016 at 1:25 PM
    #133
    LSUTaco
    LSUTaco Well-Known Member
    Jax
    11 DC TRD sport
    So I noticed the passenger side line also drained the reservior tank..is this normal the way the coolant drained? otherwise, the entire process went relatively smooth. I only put in 2 gallons hoping it doesn't need a 1/4 more. Thanks to all who shared their knowledge and experience.
  14. Oct 1, 2016 at 7:41 PM
    #134
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    I just drain the radiator and refill it once a year with toyota long life
    a400ryan likes this.
  15. Oct 2, 2016 at 2:57 AM
    #135
    DrFunker
    DrFunker Well-Known Member
  16. Oct 2, 2016 at 8:29 AM
    #136
    whipper
    whipper Well-Known Member
    2007 PreRunner
    Biscuits and DrFunker like this.
  17. Oct 2, 2016 at 8:32 AM
    #137
    DrFunker
    Biscuits and Larzzzz like this.
  18. Jan 1, 2017 at 7:39 PM
    #138
    Tjoe12
    Tjoe12 Active Member
    2012 taco trd off road 4x4
    Okay, definitely an old thread but I just drained all of my coolant out. Used all 3 drains but now I can't get all of the coolant back in. I've put in 2 gallons so far and ran it, let it cool down, ran it and let it cool down and still nothing has changed. Any ideas? I'm assuming air is trapped but what's the easiest way to release it. Ive got a 2012 4.0 liter trd. Also does it matter if you use the toyota brand coolant or not? I used a coolant that works for all vehicles and it has the same specs as what the book said to use
  19. Jan 1, 2017 at 8:14 PM
    #139
    Chuy
    Lakeside, CA
    Silver Taco
    Engine was probably not warm enough for the thermostat to open fully. Just keep driving and refilling the reservoir as needed until the coolant level stops dropping. Universal coolant to top off a quart or so should not be a problem. Anymore, you should replace the coolant with same type coolant throughout to avoid gelling. I replaced the OEM coolant at 100K with universal coolant (SuperTech). Did complete flush to get out the OEM stuff. Have done this to all my vehicles. Never had cooling problems with universal coolants. OEM coolant is overrated in my book.
  20. Jan 1, 2017 at 8:23 PM
    #140
    Tjoe12
    Okay thanks, I flushed out as much of the old coolant as I could with distilled water. After the first gallon of coolant I put in I opened the engine drains until I only saw the new coolant come out so I'm assuming I got all the old out, if I'm wrong I won't leave it in long. As for the filling I'll keep checking like you said. This may sound weird but once my engine was at operating temperature I could hear the water almost gurgling from inside the cab. No over heating or anything like that just not sure if that's normal
