The d00kie Build (and a dingleberry)
Discussion in '2nd Gen. Builds (2005-2015)' started by dan0mite, Feb 2, 2016.
  1. Nov 14, 2016 at 3:58 PM
    #241
    dan0mite
    dan0mite [OP] #NOTNORM
    Dan
    SC
    d00kie
    Check The Build Thread
    Awesome, thanks! It so happens that I'm passing through twice tomorrow...but both times at 30,000'.
    :plane:
    Please hold on to them for me and I'll grab them next time I drive. :cheers:
    scottalot and TacoFMS[QUOTED] like this.
  2. Nov 14, 2016 at 3:59 PM
    #242
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    Yay! I'm finally getting a peepee touch!
  3. Nov 14, 2016 at 4:01 PM
    #243
    dan0mite
    Dan
    SC
    d00kie
    Definitely no issues out of the rear setup. Limiting factor is the leaf pack instead of the shocks since I went with the longer ones. The hydraulic air bumps take some getting use to because there's no rubber to absorb the strike so they make a loud knock/clack.
    scottalot likes this.
  4. Nov 14, 2016 at 4:01 PM
    #244
    dan0mite
    Dan
    SC
    d00kie
    Just don't forget my butt squeeze!
  5. Nov 14, 2016 at 4:04 PM
    #245
    TacoFMS
    Justin
    Louisa County, VA
    I will never forget that for you!
  6. Nov 14, 2016 at 4:52 PM
    #246
    duvinclunk
    duvinclunk Well-Known Member
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    And you just have their off the shelf shocks? Not custom spaced right?
  7. Nov 14, 2016 at 5:12 PM
    #247
    dan0mite
    Dan
    SC
    d00kie
    No, they're custom built. Icon does have a stock number for them though because they're built enough for the Dakar pack.
    Their off the shelf rears would've worked fine according to Metal Tech (who I purchased through) with no issues...but I wanted the peace of mind that the longer shocks gave me.
    SC2SC and scottalot like this.
  8. Nov 14, 2016 at 6:32 PM
    #248
    duvinclunk
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    Shoot. That's what I'm stuck on now. I've got the off the shelf remote reservoir Icons with Icon AAL and the rear sags too much. Need to beef it up a bit but really don't want to buy new shocks as these ones have been installed for two months.
  9. Nov 15, 2016 at 2:56 AM
    #249
    dan0mite
    Dan
    SC
    d00kie
    You should be ok. I spoke to Metal Tech, who sells both Icon and OME, about this very concern. They told me the off the shelf Icon shocks are the same length as the OME shocks that would be paired with the Dakar pack.
    On the first page of this thread I have a pic of both shocks side by side.
  10. Nov 15, 2016 at 1:59 PM
    #250
    duvinclunk
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    You're right. I reached out to Icon to ask about use of the off the shelf shocks with the Dakar pack and they quickly recommended against it. Said I should really have custom shocks made for that spring. So I asked them what to do and they said to contact OME for the measurements they recommend for that leaf pack. ARB responded and gave me almost the identical measurements to the Icon off the shelf shock. Seems odd.
    What were the measurements that you made your shock around?
  11. Nov 15, 2016 at 2:08 PM
    #251
    dan0mite
    Dan
    SC
    d00kie
    Yeah...when I spoke to Icon, the guy told me the same thing and eluded to the fact that their off the shelf shocks were built for and tuned to their AAL. Anything more than that, they'd rely on somebody else telling them the build specs (OME for example).
    I never measured because I trusted Metal Tech based on my experience with them from when I owned the FJ; however, I did do a bunch of research and came across the Icon stock number they use for the longer shocks I have. I only went with the longer ones because I was able to selll my AAL and OTS shocks for what I had into them (they never got installed on my truck).
    I'll see if I can find the stock number for you so you can look into them...
  12. Nov 15, 2016 at 2:10 PM
    #252
    dan0mite
    Dan
    SC
    d00kie
    @duvinclunk CB2036 is the custom built longer shock from icon for the Dakar pack.
  13. Nov 15, 2016 at 2:42 PM
    #253
    duvinclunk
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    Nice, thanks. I'll have to give it some thought as what to do. Those mentioned shocks have almost 2 inch more when extended. I'd just rock the current ones if I wasn't so damn anxious about over extending, ruining, and then not being able to use/sell them.
  14. Nov 16, 2016 at 12:14 PM
    #254
    dan0mite
    Dan
    SC
    d00kie
    @Acerwin SEO is having a 20% off Black Friday sale right now on ARB, OME, and Safari. Now is the time to get that twin compressor...it's a better deal than what I got on mine (18%).
    Acerwin likes this.
  15. Nov 16, 2016 at 12:40 PM
    #255
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Yeah it's very tempting.
  16. Nov 17, 2016 at 1:34 PM
    #256
    dan0mite
    Dan
    SC
    d00kie
    @TacoFMS I'll be passing through this Saturday and again the following Saturday or Sunday.
    If you're not going anywhere for Thanksgiving and will be in the area, let me know if either works for you to grab those leafs.
    Thanks bud!
    Acerwin likes this.
  17. Nov 17, 2016 at 2:27 PM
    #257
    TacoFMS
    Justin
    Louisa County, VA
    Just let me know what time frame you are looking to be around and I will see what I can do.
    dan0mite[QUOTED][OP] likes this.
  18. Nov 17, 2016 at 2:44 PM
    #258
    dan0mite
    Dan
    SC
    d00kie
    Will do. I'll shoot you a text on Saturday when I know more. Also let me know what you want for them.
    :cheers:
    TacoFMS[QUOTED] likes this.
  19. Nov 17, 2016 at 3:13 PM
    #259
    TacoFMS
    Justin
    Louisa County, VA
    Thought we already discussed the payment. :wink:
  20. Nov 17, 2016 at 3:28 PM
    #260
    dan0mite
    Dan
    SC
    d00kie
    :ohsnap:
    :jerkoff:
    :woot:
