The damage is done!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AF_Gunner, May 17, 2017.
  1. Jul 8, 2017 at 12:17 PM
    #61
    AF_Gunner
    AF_Gunner [OP] Well-Known Member
    South Jersey
    Debadged 2017 Super White Double Cab/Off-Road/Short Bed
    5100'S/ OME 887 Coils/ Headstrong Progressive AAL/ SPC Light Racing UCA's/ Clamshell bushing upgrade/ 30" Rough Country LED light bar
    Sounds like you'll be good to go.
    Yeah, the spacer came in the kit I bought. I never really noticed a huge lean prior. But it's on there anyway
  2. Jul 8, 2017 at 12:41 PM
    #62
    Gjr003
    Gjr003 Well-Known Member
    Why is this needed? For all trucks or just lifted trucks?
  3. Jul 8, 2017 at 12:43 PM
    #63
    jeffkimkp
    jeffkimkp Well-Known Member
    2017 silver tacoma sr
    none
    looks good I would recommend adding the pics to the first page =)
    AF_Gunner[OP] likes this.
  4. Jul 8, 2017 at 12:51 PM
    #64
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    It replaces the weaker needle bearing with a more robust clamshell bushing. Failure of the needle bearing can occur in stock trucks and can be expedited in lifted trucks.
    Since you have the front end disassembled during the lift install it makes sense to install the beefier part instead of having to go back later and disassemble everything to find out your needle bearing has now failed.
    If it fails in a stock truck Toyota will replace it with the same weak needle bearing so there is potential for it to fail again.... or you can just pony up for the better bushing for $60.
    AF_Gunner[OP] and Gjr003[QUOTED] like this.
  5. Jul 8, 2017 at 1:03 PM
    #65
    cabo wabo
    cabo wabo Well-Known Member
    billy
    virginia
    2019 dbc short bed trd sport
    Nice :thumbsup:
  6. Jul 8, 2017 at 3:28 PM
    #66
    TRDandGlocks
    TRDandGlocks Well-Known Member
    Angel
    2021 TRD Off Road DCSB 4x4 Manual
  7. Jul 8, 2017 at 4:07 PM
    #67
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    Think I am going to go the same route on my SR5, just waiting for my factory tires to wear out but your setup is what I Have been looking at for awhile, minus the uca's..and the same tires on my factory rims since I really like them..looks great man..
    AF_Gunner[QUOTED][OP] likes this.
  8. Jul 8, 2017 at 4:18 PM
    #68
    blackcloud08
    blackcloud08 Well-Known Member
    WNC
  9. Jul 9, 2017 at 3:30 AM
    #69
    AF_Gunner
    South Jersey
    Thanks man! You won't be disappointed with it
  10. Jul 10, 2017 at 12:15 PM
    #70
    AF_Gunner
    South Jersey
    I am not 100% thrilled with my tire stance. It's trivial, but it bothers my that the tires sit in from the factory fender flare. Can I make adjustments without rubbing? Small spacers? Little wider tire? @smitty99 did you encounter the same issue? Was it even an issue for you?
  11. Jul 12, 2017 at 7:54 AM
    #71
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Wheel spacers or a wider tire. The stance does not bother me. I don't want rocks, mud and sand shooting up along the sides of my truck. Been there done that on previous vehicles.
  12. Jul 22, 2017 at 10:59 AM
    #72
    Bugmanbrian
    Bugmanbrian Well-Known Member
    Brian
    2018 sport
    Looks good
