the damn corner lights wont come out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Radelix, Jan 6, 2009.
  1. Jan 6, 2009 at 6:10 PM
    Radelix
    Radelix [OP] Runs with Scissors
    Los Angeles
    Silver 05 PreRunner
    Debadged, Satoshi, and a light foot
    I am feeling kinda retarded today and I realized that I had a headlight out. So down to the autozone to pick up new ones and realize I am out both corners, a license plate light.
    How do they come out? Im guessing push and twist or something.
  2. Jan 6, 2009 at 6:15 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    I'm a little confused... you have the following lights out:
    1. Headlight
    2. License Plate Light
    3. Corner Lights (integrated in the heads)
    Is that right?
    I believe most of the lights twist & pull to get out other than the headlight which has the spring thingamajober holding it down. If you have that many out, did you check fuses?
  3. Jan 6, 2009 at 6:19 PM
    Radelix
    Los Angeles
    Silver 05 PreRunner
    as I said Im feeling a little retarded today. So lets ignore the headlights and the license plate. I replaced those already. The marker lights on the outside corner of the headlight I cannot seem to pop out. thats what Im aksing.
    Also yeah I checked the fuses I just drive with the lights on all the time. its a habit I got into when I started driving
  4. Jan 6, 2009 at 6:28 PM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    ahh gotcha... lol
    The corners twist and pull out (I'm 85% sure)... don't know which way but I remember doing it when I swapped headlights awhile ago...
  5. Jan 6, 2009 at 7:57 PM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    08, Double cab, 4WD, Off Road, Tow,
    I remember those when I did the BHLM. They were pretty tight and the "twist" part on the plug is rather small and hard to turn.
  6. Jan 6, 2009 at 8:07 PM
    05PreRunner
    05PreRunner "Living life in the FAST lane..."
    <-(714)-> SO-CAL
    TRD intake, JBA "shorty" headers, URD y-pipe
    hey loosen by turning them, once they're loose then just pull the wire/plug out. Just pull on bulb it will come out
