The Dashtop Multi Mount - 4G taco edition.
Discussion in '4th Gen. Tacomas (2024+)' started by FreshMexicanTaco, Oct 28, 2024.
  1. Oct 28, 2024 at 3:06 PM
    FreshMexicanTaco
    FreshMexicanTaco [OP] The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    There is so much stuff I want to talk about related to the idea, prototyping development, features and final production of this mount. It’s too much and too unnecessary so I’ll save it for a different time/post.
    For now, here are some pictures, and some facts.
    • Billet aluminum construction
    • 26 accessory mounting points
    • Cable pass through
    • Optional USB ports
    • 100% BOLT-ON and reversible
    • Designed and Manufactured in-house
    • Mostly invisible
    • ROCK SOLID!
    • 2 Billet ball mounts included
    IMG_0255.jpg IMG_0256.jpg IMG_0257.jpg IMG_0258.jpg IMG_0259.jpg IMG_0260.jpg IMG_0261.jpg IMG_0262.jpg IMG_0263.jpg IMG_0264.jpg IMG_0265.jpg IMG_0266.jpg
    First production batch is already made and waiting for ALL BLACK anodize.
    A Pre-production batch will be available at the same time. That batch will have a slightly modified center plate with small, cosmetic imperfection but no functional difference.
    I am not taking any payments or pre orders until I have the parts ready to ship out which should be in about 2 weeks, HOWEVER, I want to try to start a list of people who are interested so that I know if I have to make more right away or not because these are not cheap to make.
    So, if you think you want in on this first batch, just reply and let me know which batch you'd be interested in and I will add you to the list. Regular price at the initial low volume will be $250, I know its high, I am hoping I can lower that after production ramps up.
    First production batch $200
    1.
    2.
    3.
    Pre-production
    (same same but cheaper with cosmetic imperfections on center plate) $125
    1. @Vidman
    2.
    3.
    Rover31, JollygreenFE, sogtr and 9 others like this.
  2. Oct 28, 2024 at 3:58 PM
    FreshMexicanTaco
    AJ
    San Diego
    Saved for updates
    JollygreenFE and SnuggleTruck like this.
  3. Oct 28, 2024 at 4:59 PM
    Vidman
    Vidman Protected by Sig
    Rick
    central Mass
    2024 Trailhunter
    Not Enough
    Looks like a very well made piece..what colors are they being done in. I would be interested in a pre-production piece if it is for the 14 inch screen
  4. Oct 28, 2024 at 6:56 PM
    Poot Klopp
    Poot Klopp Well-Known Member
    Ben
    New Jersey
    2024 Bronze Oxide TRD OR
    I'm assuming you're using the screen bolt in points to hold everything on? I've been waiting for someone to make something like this since I saw the trim get removed.
    Any chance of a more basic rail type system in the future?
  5. Oct 30, 2024 at 3:11 PM
    FreshMexicanTaco
    AJ
    San Diego
    As of now, this will only be made in a black finish. And yes this is going to work for the 14” screen.
    Vidman[QUOTED] likes this.
  6. Oct 30, 2024 at 3:15 PM
    FreshMexicanTaco
    AJ
    San Diego
    yes it bolts into the 4 screen bolts, right now I don’t have plans for a more basic system. What I might do, is sell the center piece alone, but I REALLY, don’t think that is as useful. Having those ball mounts on the side of the screen really makes a difference
  7. Oct 30, 2024 at 4:57 PM
    Poot Klopp
    Ben
    New Jersey
    Makes sense, are the holes AMPS patterned in the plates? I just already have a nice phone holder with a carbon fiber arm with a ball mount.
  8. Oct 30, 2024 at 9:13 PM
    FreshMexicanTaco
    AJ
    San Diego
    you should still be able to use the holder and arm with out mount, I am personally now a fan of the standard, not because of anything inherently bad about it, but rather because it tends to be on the bulkier side of the spectrum. Starting with out 3rd gen taco DMM the idea was always to make things as unobtrusive and low profile as possible.
    The amps pattern and bases did not fit into that philosophy. We do use the 1” (25mm) ball standard though, so any other accessories that you have should be compatible if they too use that standard.
  9. Oct 31, 2024 at 4:13 AM
    bctaco21
    bctaco21 Well-Known Member
    Look well designed.
    How much clearance is there between the ball mount and screen to accommodate ram mount arms? It looks quite tight to allow for much articulation of an arm although hard know from the photo.
    Thanks!
  10. Oct 31, 2024 at 5:06 AM
    Racebrick
    Racebrick Member
    2024 sr mt
    I would like a production piece. Are the balls black for the production model? In the pictures thery are different colors.
    PUMPKINKING likes this.
  11. Nov 2, 2024 at 5:04 PM
    PUMPKINKING
    PUMPKINKING Member
    Very cool! Looking forward to seeing installed pics. Will you have a version for the 8'' screen?
    y2todd likes this.
  12. Nov 12, 2024 at 5:01 PM
    vrobc
    vrobc New Member
    Hello, will these be available soon? I would like one of the production batch.
  13. Nov 13, 2024 at 11:51 AM
    Iqudayo
    Iqudayo Well-Known Member
    Antonio
    Toyota Tacoma
    Sounds interesting
  14. Nov 13, 2024 at 2:52 PM
    Bucci
    Bucci Well-Known Member
    MB
    2024 Tacoma Pre Runner
    Baja Design Squadron Sport LED lighting . Factory made, backup light kit. operated from stock wiring plug and play through trailer hitch connection.
    I would also like a preproduction part. Please let me know when you anticipate the product to be ready and I could Apple Pay you or send money via Zelle.
    Marc
  15. Nov 17, 2024 at 10:47 AM
    Phantom100
    Phantom100 Active Member
    New York
    2024 TRD OR black
    Can I get the first production batch?
    shooting my shot here
    thanks
  16. Nov 17, 2024 at 2:04 PM
    ridetime
    ridetime Well-Known Member
    Oklahoma
    2024 Celestial Silver Tacoma Limited
    It looks like the clearance for the ball mount is pretty tight (close to the edge of the screen)? It could be the angle of the photos.
  17. Nov 17, 2024 at 5:29 PM
    sogtr
    sogtr Well-Known Member
    2024 Tacoma Trailhunter Ice Cap
    you are right, it is close from what i can tell. Not sure if my attachment will fit. Im very interested though if there is more space
  18. Dec 3, 2024 at 7:56 AM
    JollygreenFE
    JollygreenFE Member
    KC
    DFW
    24 Blue Crush Taco
    ICOM ID52 and Uniden SDS100 added
    I'm in for an early release version.
  19. Dec 4, 2024 at 6:42 AM
    JollygreenFE
    JollygreenFE Member
    KC
    DFW
    24 Blue Crush Taco
    Howdy Fresh Mex! Any updates by chance?
  20. Mar 12, 2025 at 2:45 PM
    Rover31
    Rover31 New Member
    2024 SR5 Black/Black/Black
    axel dump, dash/phone holder mods, rear 60 seat removal, Rough Country Flares,
    Any updates? I'm interested if it will fit behind my small screen.
