The Death Trap - Street Build TRD Supercharged 2011 SR5
Discussion in '2nd Gen. Builds (2005-2015)' started by Athlaos, May 14, 2018.
  1. Oct 23, 2018 at 10:03 AM
    #361
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Thanks buddy! I just changed it up recently. It had been the same one for quite a while
    Athlaos[QUOTED][OP] likes this.
  2. Oct 23, 2018 at 11:38 AM
    #362
    ThomasMore66
    Dallas/Fort Worth & Durango
  3. Oct 23, 2018 at 11:44 AM
    #363
    Athlaos
    Athlaos [OP] Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I have run across this, as well as the Carbinite coating. I was going to go one of those routes if the rip slots hadn’t worked.
  4. Oct 23, 2018 at 6:46 PM
    #364
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    I've looked into the Carbonite coating prior to doing the rip mod. The consensus seems to be that they cause alot of belt dust that leads to premature wear. Pricing of $99 I believe isn't bad tho. If nothing else works then it maybe its worth trying. But I think with the combination of the rip mod, shorter belt, and your version of the belt wrap mod you should be fine.
  5. Oct 23, 2018 at 7:18 PM
    #365
    Athlaos
    Leigh
    Edmonton
    Yeah, carbinite looked pretty good, I did almost go that route. But although they advertised that it was for daily driven cars as well as race cars, it still seemed better suited for race.
    O.o and SnozzCumber like this.
  6. Oct 23, 2018 at 7:22 PM
    #366
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have reason to believe that I still slip, because while I do see 11 psi fairly regularly I don't see it as much as I should and I know this 2.3 should be hitting about 12 or so because I have seen 11.7psi before. Maybe now that I pulled out the jet again I'll see more consistent boost. Yeehaw.
  7. Oct 23, 2018 at 7:33 PM
    #367
    Speedwaytacotuesday
    Calgary, Alberta
    You being at nearly sealevel I wouldn't doubt if you slightly are, as I'm seeing those numbers at 3600 feet with no cats.
  8. Oct 23, 2018 at 7:36 PM
    #368
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah even with the RIP mod, the gates fleetrunner belt and the pulley belt wrap mod I see semi inconsistent boost pressures. Sometimes on the higher end of the spectrum and sometimes the lower. The new billet tensioner I got coming from Thump should alleviate those issues. HOWEVER, if it does not I will perform a double wrap pulley mod to the current Roostfactor mod I have in place. One way or another I will realize full boost power!
  9. Oct 23, 2018 at 7:44 PM
    #369
    Speedwaytacotuesday
    Calgary, Alberta
    if your issues are actually realized then I can't be too different or far off or atleast for much longer. The only variable between us being only the age of our belts. Which also means @Athlaos is surely slipping.
    12TRDTacoma[QUOTED] likes this.
  10. Oct 24, 2018 at 3:05 PM
    #370
    Athlaos
    Leigh
    Edmonton
    Oh, probably. I'm just happy it's slipping way less now. I've got my new tensioner in the mail... that might help.
    O.o, SnozzCumber and 12TRDTacoma like this.
  11. Oct 24, 2018 at 3:07 PM
    #371
    Athlaos
    Leigh
    Edmonton
    I have always noticed that ambient conditions will cause boost to vary slightly too. Could also be that?
  12. Oct 24, 2018 at 3:15 PM
    #372
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Not really. It will cause boost to change, but it wont be inconsistent. It will just cause lower or higher overall boost output. Like right now I am hitting less than 11.4- 11.7psi that I was seeing in the previous month or two when it was warmer out at night and am more stable around 10.4- 10.8 psi because of the fact that the air is denser so there is more engine output despite the fact the boost is less because of that same denser air.
  13. Oct 24, 2018 at 3:20 PM
    #373
    Athlaos
    Leigh
    Edmonton
    I see, so the inconsistency you see is more like, on the same drive.
  14. Oct 24, 2018 at 3:26 PM
    #374
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah, absolutely. That's how I know there is some mild slip still present.
    My new billet aluminum, double bearing pulley equipped tensioner should alleviate those issues though. ;)
    If it does not, then I can run an inch shorter belt and not have to worry about tensioner breakage. :D
  15. Oct 24, 2018 at 3:29 PM
    #375
    Athlaos
    Leigh
    Edmonton
    Or... you could do both!
    SnozzCumber likes this.
  16. Oct 24, 2018 at 3:40 PM
    #376
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I could but that would require further investigation into the proper part number for a fleetrunner belt.
    Luckily it wouldn't have to be exact at that point and I could play with different sizes without dire consequences being a factor. ;)
  17. Oct 24, 2018 at 7:38 PM
    #377
    12TRDTacoma
    Rob
    Concordia
    Boosted
    So... about that inch shorter Fleetrunner belt 68".. I found it. Lol.
    Athlaos[OP] likes this.
  18. Oct 24, 2018 at 7:59 PM
    #378
    Athlaos
    Leigh
    Edmonton
    That's awesome. Looking forward to knowing what kind of results you get.
  19. Oct 24, 2018 at 8:05 PM
    #379
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'll let you know how this all fares out! Tensioner shipped out today and should be here before Halloween.
  20. Oct 24, 2018 at 8:14 PM
    #380
    Speedwaytacotuesday
    Calgary, Alberta
    You both order the exact tensioner you've mentioned earlier @12TRDTacoma. And how much did it run you guys if you don't mind me asking?
