The defenition of "I had to trim"
Discussion in 'Wheels & Tires' started by maxpower29, Jul 28, 2012.
  1. Jul 28, 2012 at 8:12 AM
    maxpower29
    maxpower29 [OP] Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    When you guys say you have to trim when you put 285's on your trucks, what exactly do you mean? Did you have to trim just to be able to drive the truck? Did you trim for when your wheeling? Did you trim because the wheel couldn't be cut/turned all the way without touching? Or did you trim because it hits over small bumps?
    I'm just trying to gauge what I'm fully getting myself into with the new tires and there doesn't seem to be an exact reference
  2. Jul 28, 2012 at 8:22 AM
    Faryota
    Faryota Well-Known Member
    Mic
    Ridgefield, WA.
    13, 4x4, long bed, Sport, Debad
    6" BDS lift in front, warn winch, AFE cold air intake & exhaust, Body Armor Rear bumper, Tuffy in bed storage box, DZ bed mat, ARB front bumper & Warn winch w/light kit, Husky floor mats, dash mat,
    I used a saw-zall with a metal bit/blade and cut a bit off the front plastic drain fender sleeve....I cut maybe 2" off & I cut at an angle a bit of the fender flare off too. I don't think anyone will notice by looking at it. I still rub a little in reverse sometimes...
  3. Jul 28, 2012 at 8:26 AM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    When I put my spacers on the front for the stock wheels it's going to rub on the cab mount so, that will have to be cut and a new plate welded in it's place. I've also been told that I will most likely hit on a piece of the front side of the fender flare. Either way though with spacers of new wheels it will be the same because of the back spacing of the wheels. I'm needing to put the spacers on because I rub on the front of my UCA when turning at full lock. (only on the passenger side though).
  4. Jul 28, 2012 at 8:31 AM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    Trimmed plastic on the front and rear of the fender well. And a small bit of the fender flare on the front and rear ( the very end of the flare. only noticable if you know how the flare is supposed to look exactly and you are looking for it)
    I rubbed when turning if i was getting onto/ off of a hill. flat road driving, i only rubbed in reverse while turning (hit the front inner fender plastic that sticks down)
  5. Jul 28, 2012 at 8:34 AM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    usually, for 285's, the trimming is so you dont rub while wheeling. other times, depending on wheel offset/backspacing/width, the trimming is to prevent rubbing while turning in forward or reverse.
    if you are going to put on 285's, you will at least need to remove your front mudflaps and you may find that a small amount of plastic from the inner fender well needs to be trimmed.
  6. Jul 28, 2012 at 8:39 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
  7. Jul 28, 2012 at 8:44 AM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
  8. Jul 28, 2012 at 1:23 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    thanks guys, I really want to get the 285s but I want to make sure I get the right rims spec too. The 17x8 pro comp 7089's with 4.75 backspace should be fine right?
  9. Jul 28, 2012 at 1:30 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    that will work fine with alil triming
  10. Jul 28, 2012 at 2:53 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    How much more would that stick out though?
  11. Jul 28, 2012 at 2:58 PM
    KPT
    09 Prerunner
    1.75" more than stock
  12. Jul 28, 2012 at 3:04 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    sweet man, I think I might even go with the 4.5 then for 1.5 over stock because I dont want to be TOO far out. Seems like you know your stuff about these things too, TW is lucky to have such knowledgeable people IMO
  13. Jul 28, 2012 at 3:16 PM
    KPT
    09 Prerunner
    4.5 bs would stick out more than 4.75
  14. Jul 28, 2012 at 3:18 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    ......god dammit.....I hate this
  15. Jul 28, 2012 at 3:19 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Whats the actually specs of the TRD wheels then?
  16. Jul 28, 2012 at 3:21 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    :laugh:
    like a boss man
  17. Jul 28, 2012 at 3:23 PM
    KPT
    09 Prerunner
    7" wide, 5.25" bs. Thought you had base wheels, so subtract 0.25 from the how much they will stick out I previously said
  18. Jul 28, 2012 at 3:26 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    ok cool so the 4.5 backspace ones would be 1.75 more then the TRD sports right?
  19. Jul 28, 2012 at 3:38 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I though Sport alloys were 5.5 BS
  20. Jul 28, 2012 at 3:49 PM
    KPT
    09 Prerunner
    Sports= 5.5" bs, 7.5" wide
    Offroads= 5.25 bs, 7" wide
    Sorry for the confusion I'm on my phone
