The Difference Between .223 and 5.56
Discussion in 'Guns & Hunting' started by wileyC, Sep 20, 2012.
  1. Sep 20, 2012 at 9:58 AM
    wileyC
    wileyC [OP] Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
  2. Sep 26, 2012 at 2:00 PM
    GWinstead
    GWinstead Well-Known Member
    Unreal how many AR owners don't have a clue about the differences.
  3. Sep 26, 2012 at 2:21 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Interesting read
  4. Sep 27, 2012 at 11:11 PM
    WizzyTRDTXPRO
    WizzyTRDTXPRO Well-Known Member
    William
    Nebraska
    TRD TX PRO 4x4
  5. Sep 27, 2012 at 11:18 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    And some think that "AR" in AR15 stands for "Assault Rifle" I don't know how many I asked and got that answer.
  6. Sep 28, 2012 at 6:40 PM
    wileyC
    Centerville, OH
    yep, a lot of misinformation has been spread by antis and the LSM morons... AR actually meant "armalite rifle", ...as eugene stoner's cutting edge new rifle (at the time) was initially produced by the armalite company... ;)
  7. Oct 11, 2012 at 11:21 PM
    Taco Erik
    Taco Erik Well-Known Member
    Erik
    Phoenix, ARIZONA 602
    2004 tacoma totalled, new 2005 Tacoma
    3" toytec coils with Bilstein 5100 shocks, camburg uca's, 1" AAL, Uws toolbox, 12" kicker sub system, flowmaster super 40s, more mods to come new build
    i heard a good thing to know is that you can shoot a .223 through a 5.56 chamber, but you cannot shoot a 5.56 through a .223 chamber.
  8. Oct 12, 2012 at 8:14 AM
    wileyC
    Centerville, OH
    yes, that is correct... however, we should expound upon whether a 5.56 stamped barrel is indeed safe, ...if you read article in my OP, the author states that after guaging a bunch of 5.56 stamped barrels from various big name manufacturers, they were not properly reemed for 5.56 - that is a bit worrysome... ;)
  9. Oct 12, 2012 at 8:29 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Rock river uses a .223 wylde chamber which is a happy medium between the two. Most commercial ammo even 5.56 is not hot enough to matter either way. I would think that any mil spec rifle marked 5.56 is within a tolerance to safley shoot military ammo. I have fired thousands of rounds of 5.56 from numerous countries and never had a problem of anykind. Just don't put any in a bolt rifle.
  10. Oct 12, 2012 at 8:40 AM
    wileyC
    Centerville, OH
    ..the chamber dimensions for 5.56 are different from that of .223, at the neck... this is for a good reason... read the article, and you may have a different take on it ;)
  11. Oct 12, 2012 at 10:51 AM
    TACO TX
    Kelly
    Denison ,Texas
    Neck demension is not different, free bore in front of neck is longer to facilitate the bullet being seated out further and the inside capacity of the case is less due to thicker military brass meaning more pressure. Outside case demensions are identical.
  12. Oct 12, 2012 at 6:48 PM
    wileyC
    Centerville, OH
    you may have caught me in a random overgeneralization (which happens often while multi-tasking...) :D
    i'm not familiar w/ the wylde chambered rifles, ...guess i'd only trust a 5.56 chamber to shoot 5.56, ...as much as i'd hate to have a kaboom w/ a handgun cartridge, i'd really really hate to have a kaboom w/ a rifle cartridge! :D
  13. Oct 12, 2012 at 7:06 PM
    TACO TX
    Kelly
    Denison ,Texas
    I here that, its no fun if its too dangerous, lol.
  14. Oct 12, 2012 at 7:15 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    I'm curious as to the thought here - is it because a bolt action would have tighter tolerances, or that most bolt actions are chambered for 223 and not 5.56? The giant locking lugs, steel construction and pressure vents make me think that something like a Rem 700 would be significantly less likely shear a lug and fail than an AR.
    Maybe I'm wrong? I haven't studies this.
  15. Oct 13, 2012 at 6:51 AM
    TACO TX
    Kelly
    Denison ,Texas
    Yes, because bolt rifles are chanbered for .223 and also they are not gas operated like a AR is.
  16. Oct 13, 2012 at 7:35 AM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    wow thats is a good read.
  17. Oct 13, 2012 at 7:39 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Good info
  18. Oct 13, 2012 at 7:54 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    If I recall correctly the EXTERNAL dimensions of the 2 calibers are the same. This is why you will not find a separate reloading die for .223 and 5.56. Now the wall thickness is greater on the 5.56 brass so I'm not sure about reloading .223 brass with 5.56 recipes. I personally would use a reloading recipe for a .223 unless you are sure you are using 5.56 brass. As others have mentioned, the 5.56 has greater internal pressures.
    I pretty much only shoot American Eagle XM193 5.56 mm out of my Stag 2T AR-15. This stuff has the good Lake City brass in case I decide to reload.
  19. Oct 13, 2012 at 8:03 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  20. Oct 13, 2012 at 8:21 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    There are very few true .223 caliber AR's out there as well - mostly purpose built target rifles. Most off the shelf AR's are chambered in .223 Wylde, which will handle 5.56 and .223.
