the differential oil seal leak
Discussion in 'Technical Chat' started by HECTOR COVARRUBIA, Oct 10, 2010.
  1. Oct 10, 2010 at 8:35 PM
    HECTOR COVARRUBIA
    HECTOR COVARRUBIA [OP] New Member
    i need information to how change
  2. Oct 11, 2010 at 1:35 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    What year/make/model?? I think you need to post more info... and in the correct forum and someone will help ya.
  3. Oct 12, 2010 at 5:58 PM
    HECTOR COVARRUBIA
    SORRY ABOUT THIS, I NEED CHANGE THE SEAL OF THE DIFFERENTIAL GEAR TACOMA 2007 TRD
  4. Oct 13, 2010 at 11:11 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Attempt this at your own risk. I am not responsible if something goes wrong. You'll either need to order a new toyota gasket which is made out of paper, or you can use the ultra black rtv gasket made by permatex. Either way, you're going to have to do the following:
    • unbolt the driveshaft
    • drain rear differential
    • jack up rear of vehicle
    • remove rear wheels
    • remove rear brakes
    • pull rear axles
    • unbolt the thrid member
    • clean ALL gasket material from the housing and the third member
    • apply new gasket material
    • reassemble
    make sure to torque everything correctly and you may need to replace the axle seals and o-rings at the same time. I recommend the 1 minute gasket from Napa. It's made by permatex but it's ready for use one minute after being applied to the surface. Still use the ultra black since it's the most oil resistant.
  5. Jun 10, 2011 at 1:39 PM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    Beaverton, OR
    SWB 05 Double Cab 4x4 TRD Off Road
    Bump of an old thread..my seal is leaking more than usual..
    Question..you said remove rear brakes..is it necessary?
  6. Jun 10, 2011 at 2:32 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I am experiencing this also in my 2010, gonna take it in and let the stealership take a look at.
  7. Jun 10, 2011 at 5:57 PM
    JoeTacoma02
    Beaverton, OR
    Lucky. Mine is an 05 with 72,xxx miles :(
  8. Jun 10, 2011 at 6:29 PM
    afd23a
    The Dynamo of Dixie
    If you want to pull the axles all the way out then yes. Alternatively, you can just pull them partially out until they clear the third member. However, be very careful and support them so that they don't rest on your axle seals. If they do then it can cause the axle seals to leak later on.
  9. Jun 10, 2011 at 6:32 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I can't believe how much work is required to do such a simple task. On my F-150 you simply remove the 10 or so bolts holding the diff cover on. Let the oil drain. Clean and apply gasket maker. Put the cover on. Done.
  10. Jun 11, 2011 at 5:09 AM
    afd23a
    The Dynamo of Dixie
    yep, the tradeoff is that setting up (or swapping out) a new ring and pinion is easier because you can do it on the bench instead of under the truck. It's not much of an advantage if you've got a leaking seal though.
