The Dometic CFX3 Mega Thread
Discussion in 'Dometic' started by Dometic, Jan 16, 2020.
  1. Jul 22, 2023 at 12:05 PM
    #901
    RGRJoe
    RGRJoe Member
    Joe
    Good find, yep, I can turn the light on and off with a magnet…now I’ll see if there is a way to adjust the clearance.
    maybe Dometic would send me a new lid. The thought of boxing up and sending this cooler out doesn’t really appeal to me.
    Toycoma2021 likes this.
  2. Jul 22, 2023 at 3:27 PM
    #902
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    When I had to do my exchange, they shipped me a new fridge, then I used that box and their shipping label for the return.
  3. Jul 22, 2023 at 5:14 PM
    #903
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
  4. Jul 24, 2023 at 9:35 AM
    #904
    Dometic
    Dometic [OP] Well-Known Member Vendor
    2016 Tacoma
    As others have mentioned, it sounds like the magnet isn't contacting correctly or is faulty. To address this we can send you a replacement lid.
    Sending you a PM :thumbsup:
    DOMETIC
    mobile living made easy
    dometic.com
    2Toyotas likes this.
  5. Jul 28, 2023 at 9:11 AM
    #905
    RGRJoe
    RGRJoe Member
    Joe
    Well, I'm happy to report that @Dometic has stepped up and fixed my lid issue. Great customer service, guys! I was put in contact with Bryan Rush who is the Territory Development Manager who got me a new lid. Seamless, no crazy questions, no drama, just a new lid FedEx'd to me in about 3 days. Easy enough to swap out and now she works as advertised. Thanks for the great support!!!
  6. Jul 28, 2023 at 12:45 PM
    #906
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    ----The sound of clapping -----
    Great news
  7. Jul 29, 2023 at 9:10 AM
    #907
    Dometic
    2016 Tacoma
    Glad to hear the new lid got everything sorted out :thumbsup:
    DOMETIC
    dometic.com
  8. Aug 16, 2023 at 12:03 PM
    #908
    CA-Taco
    CA-Taco Well-Known Member
    Santa Cruz Mountainss
    1999 PreRunner TRD
    1999 PreRunner TRD 5VZ 3.4 V6 AutoTrans 4x4 Swap ADS Coilovers w/adjusters New OEM Bushing UCA and LCA @210k Mi Stock LCA, SPC UCA REH5108 Coilbucket Gussets Total Chaos Spindle Gusset DuroBump Front Bump Stop Alcan Springs +800 lbs +2" ADS w/adjusters Rear Shocks U-Bolt Flip-Durobump DuroBump 4.25” Bump Stops Custom Shock Relocation 4.88 Yukon Gears Eaton Front Locker SCS Ray10 16x8 Bronze 255/85R16 Cooper Discoverer S/T Maxx Dakota Digital SGI-100BT Speedometer Interface Stock Front Bumper with Custom Hidden Winch Warn M8 w/Synthetic Rope w/Factor55 Flatlink E Nguyen Works Bumper w/Dual Swing Outs (Greasable KP Off-road LCA Bolts for Swing Out Bearings) BAMF Sliders 4x Innovations Front and Transmission Skid Plates Dometic CFX 55im Fridge/Freezer Big 4 wiring Mod Singer 128.5MM Denso hairpin style (6 phase) 180 A (200 A Max, 150 A Idle) X2Power AGM Group 35 Battery Renogy Deep Cycle AGM 12 Volt 100Ah Battery Renogy 20A DC to DC Battery Charger Victron Energy SmartShunt 500 amp Battery Monitor BlueSea Bus Bar on Custom Engine Bay Mount Victron Energy SmartSolar MPPT 20 amp Solar Charge Controller Renogy 100 Watt Eclipse Foldable Solar Panel Osram Super Bright 100/90w 2900 lumen H4s Headlight Services Harness 13WL Brake Calipers Braided Steel Brake Lines OBDLink MX+ OBD2 Bluetooth Scanner & OBD Fusion App Kenwood DMX958XR Soundproofed Cab - Dynamat and Second Skin Wet Okole Seat Covers Rebuilt Engine when Head Gasket Failed (215k Mi) Hayden 699 Transmission Cooler (Replaced B&M 70264 Cooler) Magnetic Inline Transmission/Power Steering Filter 4 x 4 Conversion w/Yota1 Rebuilt AT, ECGS Rebuilt Front Diff, '99 Taco TC, Manual Hubs GFC Camper V2 LSPV Delete Funky Home Made Mud Flaps and Hangars (1/4” Conveyor Belt Material; 12” x 18”)
    @Dometic , I bought a CFX3 55IM in May of 2021. It has worked flawlessly up until early last month, when it started running continuously, freezing everything in the cooler. There were no error codes. I brought it to the local Dometic service representative. They ran diagnostics that generated error codes. They also indicated that the compressor would not turn on. After conferring with Dometic, they concluded the cooler could be fixed by replacing a part. The part is on backorder with no indication of when it might become available. I have been without a cooler for 6 weeks now. Is this normal customer service? Can you help?
  9. Aug 16, 2023 at 12:10 PM
    #909
    Naveronski
    Fort Worth
    I had the same problem. They shipped me a new fridge and had me return the old one.
    Contact them directly, not the retailer, not on TW, and start a claim.
  10. Aug 16, 2023 at 12:16 PM
    #910
    CA-Taco
    1999 PreRunner TRD
    @Naveronski Thanks for input. I started out by going to Dometic directly (800.544.4881). They referred me to the local service rep. Will try again. You wouldn't still have the number you called?
  11. Aug 16, 2023 at 12:24 PM
    #911
    Naveronski
    Fort Worth
    I didn't call, I did it all online. CustomerSupportCenter <customersupportcenter@dometic.com>
  12. Aug 16, 2023 at 12:59 PM
    #912
    Dometic
    2016 Tacoma
    Sending you a private message as well :thumbsup:
    DOMETIC
    shop.dometic.com
  13. Aug 29, 2023 at 10:16 AM
    #913
    Kohan21n
    Kohan21n A caffeine dependent life form
    Nazareth, PA
    2016 DCSB MGM 6MT
    Maybe a noob question here, but can you plug these into the back of the Tacoma bed? Will it drain the battery overnight?
  14. Aug 29, 2023 at 10:32 AM
    #914
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Good question. Someone else will know.
    I use a Jackery.
  15. Aug 29, 2023 at 11:23 AM
    #915
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    The 120vac jack in the bed is only active/live when the ignition/engine is on. Are you going to leave the engine on all night?
  16. Aug 29, 2023 at 11:53 AM
    #916
    Naveronski
    Fort Worth
    If he does, he won't have to worry about draining the battery.
    Kohan21n and Toycoma2021[QUOTED] like this.
  17. Aug 29, 2023 at 2:23 PM
    #917
    Kohan21n
    Nazareth, PA
    2016 DCSB MGM 6MT
    haha, no I don’t plan on leaving the truck on. I’ve never used that plug before or a fridge. That’s why I said noob question. Thanks.
    Toycoma2021[QUOTED] likes this.
  18. Sep 5, 2023 at 9:21 AM
    #918
    Afiftynine
    Afiftynine New Member
    Alex
    2017 Dark Grey Toyota Tacoma TRD Off-road
    Just checking to see if you ever got this fixed? and how?
  19. Sep 5, 2023 at 10:05 AM
    #919
    Naveronski
    Fort Worth
    Nope. That issue was never fixed, and Dometic stopped responding to my emails.
    Despite having a serial number that proved the unit was still under warranty, Dometic refused to honor their warranty without the original proof of purchase.
  20. Sep 5, 2023 at 10:33 AM
    #920
    Toycoma2021
    At times I have been able to go back to the store I purchased from and ask them for a copy. This works best when they can search their records for an amount similar to what I believe I purchased at the time. The cost of one of these refrigerators is high enough it puts it into a higher sale amount that is easily recognizable.
