The dreaded double whammy......
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Beavis5220, Feb 24, 2024.
  1. Feb 24, 2024 at 6:38 PM
    lavrishevo
    lavrishevo Well-Known Member
    2023 Trail Edition
    Sucks man, as you know 2016 is the most problematic. I’m not sure how mechanically inclined you are and maybe you have a buddy or something you spend some time researching the procedure get the tools and tackle it yourself. Also, I would double check with that dealer cause usually there’s some kind of guarantee least for like 30 days or something. Even used car dealers usually offer a month of protection.
  2. Feb 24, 2024 at 6:46 PM
    Beavis5220
    Beavis5220 [OP] Well-Known Member
    I did everything on my 4Runner for 18 years but this is beyond me.....honestly, it's $5k and it's just a band-aid.....it's not a part-upgrade, it's $5k for some sealant that might not even last. I didn't do enough research, mostly looked at recalls and saw there wasn't anything major so I went for the '16.....lesson learned. Will drive it for the summer then prob get rid of it.....
  3. Feb 24, 2024 at 6:48 PM
    SpeySquatch
    2016 TRD OR DCSB
    is your truck not under warranty? Just got my timing cover leak fixed no charge.
    Your leak looks way less worse than mine was. I’d hold and see how it goes. I went 10k on mine before fixing
  4. Feb 24, 2024 at 6:50 PM
    Beavis5220
    out of warranty at 64K.....agreed, the leak (let's call it a "seep") doesn't look too bad and as long as it's not staining the driveway I can deal with it.....I think
  5. Feb 24, 2024 at 7:03 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Take out the power steering pump bolts and pull the pump away so you have room . Clean the area really well . Wipe with alcohol and let it dry . Then apply gray permatex rtv sealant along the seam . Let it dry and the seep will be gone. There is no pressure there pushing the oil out . It’s just oil splash. Try it you may be pleasantly surprised.
  6. Feb 24, 2024 at 7:07 PM
    Beavis5220
    yes, I read about this....the zero-pressure was the deciding factor in me ignoring it......will give this a try, thanks!
  7. Feb 24, 2024 at 7:14 PM
    TruckGuy63
    Gilbert
    New York
    Take your time and really clean the area good , this will work, especially if you think about it, the cover is factory sealed with no gasket, so if you seal the outside seam it will stop leaking . Just make sure you let it dry overnight before you start the motor . It’s a great truck by the way don’t let this discourage you . By the way most dealerships when they fix it they don’t remove the motor any more .
    vivid02 likes this.
  8. Feb 24, 2024 at 7:14 PM
    4x4spiegel
    4x4spiegel Well-Known Member
    yes , deal with it with Permatex like many others before you
  9. Feb 24, 2024 at 7:16 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    Don't forget to always park on a piece of old carpet in your driveway
    daveeasa likes this.
  10. Feb 24, 2024 at 7:24 PM
    Beavis5220
    lol....did that earlier tonight
  11. Feb 24, 2024 at 7:25 PM
    Beavis5220
    makes total sense....thanks again
    auskip07 likes this.
  12. Feb 24, 2024 at 7:50 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K02 AT’s RCI skid Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    Man that sucks. Are these leaks an issue with the V6 & the 2.7 or just the V6?
  13. Feb 24, 2024 at 8:43 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    The leak/seep was there before they sold it to you. They washed it. Too shiny for 2016.
  14. Feb 24, 2024 at 8:44 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    This is spooky sh*t.
    Is there anything one could do to 'prevent' this from happening?
  15. Feb 24, 2024 at 8:45 PM
    #35
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    no, so dont even worry about it
    Canadian Caber likes this.
  16. Feb 24, 2024 at 8:49 PM
    #36
    DoubleB
    DoubleB Well-Known Member
    Bakersfield CA
    22 TRD Pro / 06 PreRunner
    My second gen has had the same leak for about 10 years and 90k miles. I got a couple of quotes to fix it and they were astronomical. If it dripped on the ground I would consider fixing it. Instead, I spray it with some degreaser and hose it every 5k miles when I change the oil.
    Hopefully I am luckier with my ‘22.
  17. Feb 24, 2024 at 9:17 PM
    #37
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    surrrre thats why you bought the 2.7 we will play along lol:rofl:
  18. Feb 24, 2024 at 10:00 PM
    #38
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Oils cheap and pressure was every now and then. You definitely aren't getting a reach around for the price they want.
  19. Feb 24, 2024 at 11:19 PM
    #39
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    My Tacoma is the first ride I've owned that I didn't keep a quart of oil stashed in it.
    Never needed it in any of the others, but just always kept a quart.
  20. Feb 25, 2024 at 3:00 AM
    #40
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    For the coolant pipe……be sure you get the updated piece. You don’t want the factory plastic piece reinstalled
