The dreaded headlight haze
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shwaa, Dec 29, 2016.
  1. Dec 29, 2016 at 12:07 PM
    Shwaa
    Shwaa [OP] Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    I am just now starting to see signs of the haze starting to creep in along the inside top ridge of the headlights on my 13', What do you guys do to keep this at bay? Or do you just wait until its bad enough then open up the assembly and clean the inside?
  2. Dec 29, 2016 at 12:21 PM
    r.shackleford
    r.shackleford ...
    polish and wax regularly
    once they start to peel the best fix is to remove all of the UV coating by wetsanding and polishing and the have a professionally applied automotive clear coat to protect
  3. Dec 29, 2016 at 12:23 PM
    Shwaa
    Bay Area, CA
    stupid question maybe but what will polish and wax do if the haze is forming on the inside?
  4. Dec 29, 2016 at 12:27 PM
    WebberLander
    WebberLander Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    If it's on the inside there isn't much you can do unless you separate the lenses from the body of the light. Then do what's needed to clean them up (wet sand, polish etc).
    I'd pick up a set here on the for sale forum as there are plenty I've seen in good condition for a good price. Might be worth doing as it will save time and possibly money over doing all the above described work.
  5. Dec 29, 2016 at 12:36 PM
    Shwaa
    Bay Area, CA
    Oh it's hardly noticeable at this point. Just a tiny bit. Headlights still look great, but maybe when I get to that point someday down the road I can do that. Thanks
  6. Dec 29, 2016 at 1:35 PM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    Yep just separate the lens from the housing then hit it with some wet 1500 then down to 2000 grit.
    Funny story I blew a headlight in my CBR and the bulb caught on fire briefly causing some white powder residue on the inside. Instead of cleaning it with a rag I sprayed some carb cleaner on the inside and it instantly hazed up. I spent a couple of hours wet sanding to get it clear again.
  7. Dec 29, 2016 at 1:51 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Maybe a silly question; are you sure it's forming on the inside and not just an optical dillusion?
    My 06 has the haze that started at the top and is working its way down. I plan on replacing rather than refinishing. I think it'll be quicker and I'd pull them out anyway to refinish them. My OCD will want them perfect.
  8. Dec 29, 2016 at 1:55 PM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    I use Turtle Wax headlight restore kit, it really does a nice job. It last about 6 weeks, after that they begin to haze again so I clean and polish the headlight lense once every 6-8 weeks.
    Mush Mouse likes this.
  9. Dec 29, 2016 at 2:52 PM
    WebberLander
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Believe it or not, the wipe new head light restoration kit works wonders and lasts a long time (over a year). A friend of mine has a chevy Silverado who used the turtle wax kit to refresh the lenses and then used the wipe new kit to seal them. I believe their product contains some sort of ceramic property as it left a coating on the lenses when he was done that stuff was 100% transparent. I was actually really impressed with that stuff for being a "as seen on TV product". Might wanna give it a shot next time you polish the lenses, it might prevent you from having to do it so often.
    1Shifter[QUOTED] likes this.
  10. Dec 29, 2016 at 3:14 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    Old detailer trick for internally fogged/dirty headlamp housings: Fill the lamp housing with water with a bit of dishwashing liquid added--and quite a few ice cubes and larger bits of crushed ice. Shake the housing for several minutes, them rinse and repeat 'til its as good as it's goIng to get. The ice behaves as a very mild abrasive that will not scratch up the reflector or lens.
    Here's a before-and-after shot of my '98 SL500 (I buffed out the plastic surround)...
  11. Dec 29, 2016 at 3:20 PM
    frejil
    frejil Well-Known Member
    Andrew
    2006 Prerunner
    Depo headlights
    No matter what I did I could not clean mine up. Just bought new ones altogether
    bluezzy likes this.
  12. Dec 29, 2016 at 3:21 PM
    Castle
    Castle Well-Known Member
    SF Bay Area
    2012 DCLB SR5
    Bumpers,lockers, gears, lift...
    1Shifter likes this.
  13. Dec 29, 2016 at 3:21 PM
    2DaMtns
    2DaMtns Well-Known Member
    2011 TRD Sport DCLB in MGM
    Lift, tires, stuff
    Hit a deer at 50+mph right smack in the front end and have the insurance buy new ones. But make sure you bugger up both of them. Otherwise you get the stupid look I got with one new light and one hazy one.
    Mattatonic likes this.
  14. Dec 29, 2016 at 3:31 PM
    WebberLander
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    This is awesome!!!!! Nice trick!!!!
  15. Dec 29, 2016 at 4:45 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I just bought one of the kits from an auto parts store. Took about 30 minutes with a cordless drill. I won't say it looks like new, but pretty close. It's been about 1 1/2 years and mine still look good.
    austinrauh likes this.
  16. Dec 29, 2016 at 4:48 PM
    nobescare
    nobescare Well-Known Member
    Mark
    43.5448° N, 80.2482° W
    2019 Highlander SE
    My 2005 prerunner had frame failure Aug 2024
