The dreaded P0333 knock sensor code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jonah, Jan 19, 2025.
  1. Jan 19, 2025 at 7:17 AM
    Jonah
    Jonah [OP] Well-Known Member
    Joe
    Charleston, SC
    2014 TRD O/R 4x4
    I've read the numerous threads about this problem and am tempted to try the fix myself. Does anyone know if it's possible to get a borescope down into the bowels of hell prior to taking the intake manifold off? I'd like to verify if it's a chewed wire (as I suspect it is) before digging in with the disassembly.
    For those who have done it themselves, would you do it again? Any suggestions or encouragement? I'm not super excited about this job.
  2. Jan 19, 2025 at 8:02 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If you take the air filter housing off you have quite a bit of room to poke around under the intake with a borescope.
    Jonah[OP] likes this.
  3. Jan 19, 2025 at 7:34 PM
    Taco'09
    Taco'09 Well-Known Member
    Op, I've been in there and I believe that you can snake the camera from the very front of the engine along the water by-pass pipe. If need be, removing the air cleaner assy. considerably opens things up.
    Just for fun, if it is warmer tomorrow, I might take my boroscope to try this...
