The Drifter - Specs and FAQ
Discussion in 'Tonneau Covers, Caps and Shells' started by Iggy, Mar 26, 2018.
Thread Status:
Not open for further replies.
  1. Mar 26, 2018 at 12:22 PM
    Iggy
    Iggy [OP] Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    BEGIN YOUR ADVENTURE
    We are pleased to introduce “The Drifter”. The all aluminum construction and lightweight camper built for whatever you can throw at it! It’s sized perfectly for mid-sized trucks, providing space and comfort without compromising weight or drivability.
    From concept to reality, establishing our business, setting up our new shop, and securing a patent pending design – we have made many refinements over the last year of beta testing and are incredibly excited to launch Vagabond Campers.
    FEATURES & SPECS
    Standard Features
    • Patent Pending.
    • Aluminum construction.
    • One-piece lid design.
    • Insulated ceiling.
    • Standing/sitting room and access to lower level with sleeping platform fully extended.
    • Entire truck bed is unobstructed when sleeping platform extension is retracted.
    • Concealed lift struts.
    • Waterproof tent with 3 windows.
    • Cab drop-down window and rear glass hatch.
    • High-density 2 piece mattress with cover.
    • Lower interior light with switch.
    • LED third brake light and wiring.
    • Concealed wire tray.
    • Adjustable & lockable stainless steel latches.
    • Three stainless steel hinges.
    • Camper attachment clamps and bulb seal gasket.
    Options
    • Sliding cab window.
    • Side Windows and Doors
    • Additional interior and ceiling lighting.
    • 12v power port and USB outlets.
    • 14" Fantastic Fan.
    • Powder Coating in white, grey, black.
    • Additional bed extension.
    • Roof mounted L-Track.
    • Lower side panel insulation.
    DETAILS
    Body
    Laser cut & CNC bent 1/8” 5052 aluminum sheeting.
    TIG welded, stainless steel bolts & nuts, and mil-spec aluminum rivets.
    Sealed panel connections.
    Attaches to truck bed with aluminum clamps and double bulb seal.
    Roof
    Single piece design reinforced with aluminum extruded awning tube.
    Insulated with durable ceiling panel.
    Lift struts are concealed and protected with roof in travel position.
    Three heavy- duty stainless steel hinges.
    Stainless steel adjustable draw hasps.
    Tent
    Waterproof, durable, 18 oz. polyester- coated vinyl.
    Large zippered side and rear window.
    Durable screen fabric.
    Clear vinyl side windows.
    Mesh and blackout curtains on three sides.
    Attached with Keder rope and extruded awning track for water, wind, and dust resistance.
    Sleeping Platform
    Extension panel retracts to cab wall for full use of living space.
    48"x80", 3” thick high-density 2 piece foam mattress with waterproof cover.
    PRICE
    $7250 for the base model+options
    Vagabondoutdoors.com
    Instagram.com/vagabond_outdoors
    Contact us: https://vagabondoutdoors.com/contact/
  2. Mar 26, 2018 at 12:22 PM
    Iggy
    Northern CA
    Check out the build
    FAQ
    What side window options do you offer?
    We have several! Here are pictures of each with pricing. And a long description here.
    Slider w/ Screen $350
    Glass Windoor $400
    Solid Windoor $450
    Solid Frontrunner (Really Popular) $800
    Glass Frontrunner $850
  3. Mar 26, 2018 at 12:22 PM
    Iggy
    Northern CA
    Check out the build
  4. Mar 26, 2018 at 12:22 PM
    Iggy
    Northern CA
    Check out the build
    Reserved
    Anderson likes this.
  5. Mar 26, 2018 at 12:24 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
  6. Mar 26, 2018 at 12:27 PM
    Iggy
    Northern CA
    Check out the build
    More details to follow, the first post will be updated as we move along!
  7. Mar 26, 2018 at 12:31 PM
    Porter707
    Porter707 Well-Known Member
    James
    Ohio
    2020 F-250 Powerstroke
  8. Mar 26, 2018 at 12:32 PM
    Iggy
    Northern CA
    Check out the build
    Depends on the truck. If it's a 3rd gen it might fit, if its a 2nd, there's not enough room.
  9. Mar 26, 2018 at 12:42 PM
    blackradon
    blackradon Well-Known Member
    james
    YEG, Canada
    2014 sky silver metallic
    Looks awesome! Can top handle any weight?
    Anderson and Iggy[OP] like this.
  10. Mar 26, 2018 at 12:45 PM
    anomalyTRD
    anomalyTRD Well-Known Member
    Oakland, CA
    2019 Ford F150
    VO Nomad
    Yes, they posted some photos in Iggy's other thread of people sitting on the front of the camper overhang and there was clearly very minimal deflection. I'm guessing the roof is fine to have a 200lb person walking on it semi-regularly.
    Anderson, Overlanerd and Iggy[OP] like this.
  11. Mar 26, 2018 at 12:47 PM
    sandsnek
    sandsnek Member
    You can have my money after you post up some interior shots.
    SR-71A, Chipskip, Anderson and 7 others like this.
  12. Mar 26, 2018 at 12:48 PM
    916TacoTruck
    916TacoTruck BallzDeep is how I go
    Inyo mom
    2019 Rapturd
    Former 2013 TRD OR. Sickass edition
  13. Mar 26, 2018 at 12:49 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Manfred, 12TRDTacoma, taijai and 10 others like this.
  14. Mar 26, 2018 at 12:50 PM
    blackradon
    james
    YEG, Canada
    That’s good, being able to mount/carry some gear up there is key.
  15. Mar 26, 2018 at 12:50 PM
    anomalyTRD
    Oakland, CA
    2019 Ford F150
    VO Nomad
    @Iggy will you support Anderson plugs for power?
  16. Mar 26, 2018 at 12:51 PM
    JasonLee
    15 TRD OffRoad
    Someone is going to ask, so I'll save you time.
    ohcaltexscar, BRFab, Manfred and 9 others like this.
  17. Mar 26, 2018 at 12:56 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Good to know more info on these.
    Concealed lift struts and adjustable latches! - Minor details that I'm glad you guys thought of! I'm glad the latches are adjustable in order to accommodate extra linens/pillows and weather (I imagine cold days to be a PITA with fixed latches). Also the concealed lift struts is major so that debris is minimized which should equate to longer life expectancy of the struts.
  18. Mar 26, 2018 at 1:05 PM
    Bentrodder
    Bentrodder PeeRunner Fanboy
    Peter
    Cotati, CA.
    2015 DCLBFTMFW TRD Sport
    Kings and a TW DECAL!!!
    Congrats guys! Super excited!
    Anderson, Gply, Porter707 and 3 others like this.
  19. Mar 26, 2018 at 1:12 PM
    Iggy
    Northern CA
    Check out the build
    Yes! It’s not something we recommend anyone doing, but we did it to prove the strength of the one piece design. Here’s a pic of Phil standing right in the middle of it and there’s no deflection.
  20. Mar 26, 2018 at 1:13 PM
    Iggy
    Northern CA
    Check out the build
    You got it! Get that wallet ready ;)
Thread Status:
