"The End's" 09 SAS re-build w/3-link and 1-tons
Discussion in '2nd Gen. Builds (2005-2015)' started by allenfab, Apr 21, 2016.
  1. Apr 21, 2016 at 5:43 PM
    allenfab
    allenfab [OP] I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Starting sort of a "rebuild" on @The End truck. Short backstory on it is that he dropped it off in February of 2014 to a local truck builder to have a 3-link front with coil-overs, Chevy 63" rear springs, Dana 60 front and 14 bolt rear installed. Tim told the builder exactly what he was going for with this build and the builder decided that he was going to do it his own way or no way. It pretty much sat out at the builders house/shop since then because of disagreements between the two. Fast forward to sometime last week, the truck was stolen from the builders house and ended up two hours away. It was recovered, and Tim went and picked it up and left it at my house for a complete tear-down and rebuild .
    The original plan was for me to take the truck quite some time ago, but life got in the way for both Tim and I.
    Literally everything the builder did will have to be removed and re-done. I am pretty much going to emulate some other 2nd gen 3-link builds and keep things very simple for now. The plan is to just get it road-worthy for now and then start doing other upgrades like gears, lockers, flat/tube bed, etc....
    I'll just let the pics do the talking...
    Photo Apr 21, 4 11 37 PM.jpg Photo Apr 21, 3 01 13 PM.jpg Photo Apr 21, 3 01 21 PM.jpg Photo Apr 21, 3 02 01 PM.jpg Photo Apr 21, 3 02 17 PM.jpg Photo Apr 21, 3 03 02 PM.jpg Photo Apr 21, 3 03 40 PM.jpg Photo Apr 21, 3 03 49 PM.jpg Photo Apr 21, 3 04 06 PM.jpg Photo Apr 21, 3 04 14 PM.jpg Photo Apr 21, 3 07 08 PM.jpg Photo Apr 21, 3 58 30 PM.jpg
  2. Apr 21, 2016 at 5:49 PM
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    I was wondering where Wyatt's old bumper went. Can't wait to see how this comes out.
    :popcorn:
  3. Apr 21, 2016 at 6:24 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    I feel like I should be embarrassed lol.
  4. Apr 21, 2016 at 6:27 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Well at least the welds look decent!!
    allenfab[OP] likes this.
  5. Apr 21, 2016 at 6:32 PM
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    What. The. Fuck.
  6. Apr 21, 2016 at 6:49 PM
    ChandlerDOOM
    ChandlerDOOM International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    utroda and Pirhett like this.
  7. Apr 21, 2016 at 7:16 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Damn shitty that it went like that. At least it's going to get done righ now!
    Ha no kidding! That is rough
  8. Apr 22, 2016 at 2:26 AM
    allenfab
    Todd
    Lakeland, FL
    Some do, some don't. I don't think he does his own welding though. I've seen his actual welds and they aren't pretty.
  9. Apr 22, 2016 at 6:52 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  10. Apr 22, 2016 at 3:13 PM
    allenfab
    Todd
    Lakeland, FL
    Going to post more bad before the good. I removed the Coilovers towers that were bolted to the frame along with the steering box. The builder had the bolts so tight that it slightly crushed the frame some, which isn't too big of a deal as the frame bounced back to its original form when removed. The steering box was not sleeved and had no frame plating on the inside of the frame, so essentially it was crushing the frame together as well. The builder also cut the frame plate/Coilover towers short so he spliced in an extra piece of plate for the steering box to mount to and didn't even bother to grind the weld down so the steering box could sit flat on the frame. If he would have tightened the steering box bolts any tighter, he could have snapped the ears clean off the steering box.
  11. Apr 22, 2016 at 3:23 PM
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Jeez. How did I know that none of those bolts were sleeved..
  12. Apr 22, 2016 at 3:41 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    What in the actual fuck
  13. Apr 22, 2016 at 3:45 PM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
  14. Apr 22, 2016 at 3:52 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
  15. Apr 22, 2016 at 4:09 PM
    allenfab
    Todd
    Lakeland, FL
    This same guy did an axle swap on my old Tundra back in 2007 and he did the same shit. He did most everything wrong on that truck but that's what got me into wrenching and welding.... fixing all his hacked together bs
    Bobcdn, DustStorm4x4, Jystr and 2 others like this.
  16. Apr 22, 2016 at 4:10 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    holy crickets batman that thing is jacked
  17. Apr 22, 2016 at 5:13 PM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Damn, too bad you couldn't warn Tim
  18. Apr 22, 2016 at 5:25 PM
    allenfab
    Todd
    Lakeland, FL
    He knew about the problems that I had but the builder was really putting out what appeared to be some quality work on multiple rigs since then. We both thought he could tackle this given that Tim told him exactly what he wanted. Tim wanted me to do it from the beginning but I was still living with my parents so it just wasn't practical to do that kind of build in their driveway. Oh well, lesson learned. I will guarantee that it will be done right this time though
  19. Apr 22, 2016 at 5:48 PM
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    :spy: can't wait to see what you do with it Todd
    allenfab[OP] and ChadsPride like this.
  20. Apr 22, 2016 at 7:44 PM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    :annoyed:
    Soul Surfer likes this.
