The Epic Wy/Co meet picture thread!!
Discussion in 'Trip Reports' started by Blackdawg, Aug 4, 2013.
  1. Aug 16, 2013 at 7:45 PM
    #161
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    As a whole trail. Not as hard. But it was the hardest obstacle. The two lander trails where harder in a whole.
  2. Aug 16, 2013 at 8:40 PM
    #162
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Oh man, I gotta go run that trail and make it up... just to make you come back down here to CO!
  3. Aug 16, 2013 at 8:44 PM
    #163
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea ill go back just for that. I'm certain I can do it open.
    But yea it would be fun to meet up!!
  4. Aug 16, 2013 at 9:52 PM
    #164
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    That trail was a lot of fun. The wall may have been the single most difficult obstacle of all three legs of the epic. I'm glad it was dry. It may be near impossible in the wet.
    Awesome video
    Joey, Ben and I made it up unassisted. Everyone else had to have a little tug. :rolleyes:
    I felt bad for Monte because he sheared the BJ bolts almost at the foot of the wall. We had no idea of how well the fix was going to hold up.
  5. Aug 16, 2013 at 9:57 PM
    #165
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Lockers for the win huh?
  6. Aug 16, 2013 at 10:01 PM
    #166
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    And let it also be noted that monte, myself and the city bus were the only ones to finish the Christina lake trail, which was pretty bad ass and fun weaving in those trees at night!
  7. Aug 16, 2013 at 10:31 PM
    #167
    Blackdawg
    Monte
    Wyoming/St. Louis
    No. I refuse to believe a locker is 100% needed. With enough rear travel and the right line. I am very confident I just needed a big bump at the base and then woulda been fine. The 2nd gen that got winched was locked too
    But like mike said. Was on a fresh repair and didn't want to risk it.
    Next time
    Damn right!! Was cool for sure!
  8. Aug 16, 2013 at 10:35 PM
    #168
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Eventually monte you will get to a point where a bump needed to get you up something is impossible and you will see the light
  9. Aug 16, 2013 at 10:36 PM
    #169
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have no doubt it'll make life easier. That's obvious.
    But it's like auto vs manual for me
    Open is more fun :D
  10. Aug 16, 2013 at 10:51 PM
    #170
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    And so is going in no condom. But then you forget to pull out, you have a kid and your life is fucked. That's what wheeling without a locker is like.
  11. Aug 16, 2013 at 10:54 PM
    #171
    Blackdawg
    Monte
    Wyoming/St. Louis
    Having a locker is like having a kid?
    Fuck that shit then.
  12. Aug 16, 2013 at 10:58 PM
    #172
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    No you tard. Having a locker is like having a condom. You can have fun till it gets serious, then you can play it safe and keep on rockin.
  13. Aug 16, 2013 at 11:01 PM
    #173
    Blackdawg
    Monte
    Wyoming/St. Louis
    I was just giving you shit haha
    I saw dual lockers fail though as well..
  14. Aug 16, 2013 at 11:07 PM
    #174
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Dude in Moab joe was going up this double ledge, and his words were "I'm gonna put on both lockers and make this look easy". He took twice as long to get up that stupid thing than me, know what killed him, wheel base lol
  15. Aug 16, 2013 at 11:19 PM
    #175
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well considering Cody's is a 1st gen..so same wheel base as you..still didn't make it. But that was due to tires.
  16. Aug 16, 2013 at 11:52 PM
    #176
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Whateva
  17. Aug 17, 2013 at 12:50 AM
    #177
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    so much awesome
    ...not your stupid debate
  18. Aug 17, 2013 at 3:17 AM
    #178
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Bro, I drive like a boss In would have made it up it hell or high water :p
    Knew that one was comnin! Ya I let out long strings of profanity at about the 2/3 mark. Ready to be done haha. But ya, I did get baby taco to "oh shit" a couple time on the way back.
    On that one 3 way rocky climb where you 3 wheeled and tipped monte, ya we did the same thing haha.
  19. Aug 17, 2013 at 7:30 AM
    #179
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    Picture thread fuckers, not bs thread :mad:
  20. Aug 17, 2013 at 11:37 AM
    #180
    wheresmikeys
    wheresmikeys Get Some
    Michael
    Red Lodge, Montana
    08 Tacoma SR5 V6 TRD Off Road
    ARB Bumper. Old Man Emu Suspension Dont leave home without it
    Just get fixed. Only uncomfortable for a couple of days. :D
