The Epic WY/MT/CO Adventure!!
Discussion in 'Off-Roading & Trails' started by Blackdawg, Feb 10, 2013.
I will be attending...
  1. Leg 1 only
    20.0%
  2. Leg 2 only
    12.0%
  3. Leg 3 only
    20.0%
  4. Legs 1 & 2
    16.0%
  5. Legs 2 & 3
    0 vote(s)
    0.0%
  6. Legs 1 & 3
    0 vote(s)
    0.0%
  7. All 3!!
    32.0%
  1. Jun 26, 2013 at 8:44 PM
    #2181
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Bro, you drive open, I drove open. You know lead foot is the only way to go!
  2. Jun 26, 2013 at 8:49 PM
    #2182
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Bump it up!
  3. Jun 26, 2013 at 8:57 PM
    #2183
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Access is 4 miles south of Ouray, its on the road to engineer pass.
    Yup, thats what you look like when you drive an unlocked heep with street tires. :rolleyes:
    Yeah, its a Lexus but without looking at the badging, you can't tell its not a land cruiser.
    That is what his info says. :notsure: Is probably eager to do morrison. :)
  4. Jun 26, 2013 at 8:59 PM
    #2184
    Blackdawg
    Monte
    Wyoming/St. Louis
    Good god..
    I better pm him..
    And hmm..so would be day one? I still don't know wtf is going on enough for the alpine loop haha
  5. Jun 26, 2013 at 9:41 PM
    #2185
    Digiratus
    Roaming the PNW
    The RedHead
    Working on that :cool:
    There are 2 trails we know for sure we want to do. Poughkeepsie Gulch is one and Black Bear pass is the other. Both can be built upon. For instance, depending on rig count and weather, Poughkeepsie should take a half day and from there we can explore California Pass and Animas Forks Ghost town. On another day, would do Black Bear and maybe explore Telluride, then finish by exploring Ophir Pass on the way back to Silverton. Black Bear road is one way so we can't go back the way we came even tho that would be awesome.
    Just that will consume at least 2 of the days we will be there.
    Poughkeepsie info: http://www.everytrail.com/guide/off-road-trail-maps-poughkeepsie-gulch-colorado
    black bear info: http://www.everytrail.com/guide/off-road-trail-maps-black-bear-pass-colorado
    Ophir pass info: http://www.everytrail.com/guide/ophir-pass-4x4-road-colorado
    edit: I think Imogene Pass is another way out of Telluride too. I think it heads back toe hiway 550 so Ouray or silverton are nearby.
    Imogene Pass info: http://www.everytrail.com/guide/off-road-trail-maps-imogene-pass-colorado
  6. Jun 26, 2013 at 9:46 PM
    #2186
    Blackdawg
    Monte
    Wyoming/St. Louis
    :bowdown:
    Thank you Mike!
    Okay cool. Your in charge then :p telluride from there we can do Imogene pass or is it engineer??
  7. Jun 26, 2013 at 9:53 PM
    #2187
    Digiratus
    Roaming the PNW
    The RedHead
    Imogene is an option.
    I added a link, see the edit.
  8. Jun 26, 2013 at 9:55 PM
    #2188
    Blackdawg
    Monte
    Wyoming/St. Louis
    Gotcha. So we do part of engineer to the glutch road..
    There are too many passes..haha
    So really we are only gonna do like half the loop
  9. Jun 26, 2013 at 10:04 PM
    #2189
    ZKuhl
    ZKuhl Expedition Montana
    zane
    MT
    2015 tacoma trd off road
    Iconstg 2, aal, 285/70/17 bfg's ko2 on 17x9 methods stampede deflector, auto vent visors, delta black diamond plate tool box pelfreybilt front bumper......?????
    you guys down with new bees im thinkin about leg 1 ive been up morrison before and goose lake trails before on a dirt bike that being said i woldnt be hitting the switch backs but everything else.last summer morrison switchbacks not in bad shape upper portion was rougher than ive seen in past years big loose rocks everywhere... once ur up the hill like a highway it would be cool to meet some new offroaders
  10. Jun 26, 2013 at 10:07 PM
    #2190
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes!
    Newbies welcome! I'd joint up with Lisa if you can. The you just run the top of Morrison and Gooselake. We will spot you over anything.
    Glad your not doing the switch backs yet. Ya the top is real loose and rough.
    Gonna be a challenge no doubt.
  11. Jun 26, 2013 at 10:08 PM
    #2191
    ZKuhl
    zane
    MT
    what day will u be going in sunday?
  12. Jun 26, 2013 at 10:16 PM
    #2192
    Blackdawg
    Monte
    Wyoming/St. Louis
    Do it!!!!
    Not have a girl friend should be enough for gas.. :p
  13. Jun 26, 2013 at 10:16 PM
    #2193
    Blackdawg
    Monte
    Wyoming/St. Louis
    Check out the OP. all explained there.
    But we start at the bottom of Morrison on Monday the 5th. Lisa leaves red lodge I believe the Friday before.
  14. Jun 26, 2013 at 10:17 PM
    #2194
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Welcome to to crew man!
  15. Jun 26, 2013 at 10:18 PM
    #2195
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well would be great.
  16. Jun 26, 2013 at 10:32 PM
    #2196
    ZKuhl
    zane
    MT
    thanks ill keep an eye on here hope to see u at the top
  17. Jun 26, 2013 at 10:34 PM
    #2197
    Blackdawg
    Monte
    Wyoming/St. Louis
    User name MTgirl. Shoot her a PM and she will get you all lined out..or she will PM you later I'm sure.
  18. Jun 26, 2013 at 10:47 PM
    #2198
    Digiratus
    Roaming the PNW
    The RedHead
    Yes, the poughkeepsie gulch trail branches off of the engineer pass road not far from the highway. So even though we access it that way, we are not going to engineer pass that day.
    I'm thinking we will have at least 3 full days to play around down there, right?. Certainly one day we can use to explore the rest of the alpine loop along with engineer pass.
    I would really like to spend a little time in Silverton too. Have heard it is worth checking out.
  19. Jun 26, 2013 at 10:50 PM
    #2199
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hmm..so how do you want to get from telluride to silver ton?!
  20. Jun 26, 2013 at 10:50 PM
    #2200
    Digiratus
    Roaming the PNW
    The RedHead
    Hey man, welcome. Are you long bed or a short bed, 4x4 or prerunner? Can't tell from your listed information.
