The Epic WY/MT/CO Adventure!!
Discussion in 'Off-Roading & Trails' started by Blackdawg, Feb 10, 2013.
I will be attending...
  1. Leg 1 only
    20.0%
  2. Leg 2 only
    12.0%
  3. Leg 3 only
    20.0%
  4. Legs 1 & 2
    16.0%
  5. Legs 2 & 3
    0 vote(s)
    0.0%
  6. Legs 1 & 3
    0 vote(s)
    0.0%
  7. All 3!!
    32.0%
  1. Jun 29, 2013 at 11:51 PM
    #2301
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yes looks like there are 1 or 2 turns on blackbear that need spotted. But not like every one like Morrison. I also think people find it freaky just caus the illusion of how high up you are with the town 10,000' or whatever below in the distance haha
    It doesn't appear to be a bad as Morrison. Joey said it wasn't bad.
  2. Jun 29, 2013 at 11:54 PM
    #2302
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    ill help find your nipple...
  3. Jun 29, 2013 at 11:57 PM
    #2303
    Blackdawg
    Monte
    Wyoming/St. Louis
    I would..pretty rock section..
    This part here will be fun for you. I'm not sure ill try it. Jon did it last year and had to nail it to get up it. I bet you locked guys won't have too much an issue. I went down it here.
    08ca3b0a642ff8a40af2c1d43a7cb475_zps8321_1aa238179a20ea0a65bdec38178d5cfcd0fb39d6.jpg
    Jon going up it. He made it up but I had to out the camera down to spot him lol he caugh big air too haha was awesome
    You'll have fun with em I think. They are great trails. Shoshone just beats up you and the rig is all.
  4. Jun 29, 2013 at 11:58 PM
    #2304
    Blackdawg
    Monte
    Wyoming/St. Louis
    I ordered all of them from the dealer. Wasn't even that expensive.
  5. Jun 30, 2013 at 6:32 AM
    #2305
    Blackdawg
    Monte
    Wyoming/St. Louis
    It's an easy mod. Doesn't take long.
    Where you gonna mount it if not in the gas cap?
  6. Jun 30, 2013 at 8:22 AM
    #2306
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I'm just going to zip tie it somewhere up on the frame
  7. Jun 30, 2013 at 1:34 PM
    #2307
    Blackdawg
    Monte
    Wyoming/St. Louis
    Why? Gas cap is higher up..
  8. Jun 30, 2013 at 2:17 PM
    #2308
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nonsense. Almost had it that high just last week haha
  9. Jun 30, 2013 at 5:13 PM
    #2309
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I just don't feel like drilling a hole is all. I can zip tie it to the filler neck if I want, just don't feel like drilling a hole. Waste of time.
    Also Ben if we are taking about extending things? Might want to to think about the e locker breather. That only goes as high as the frame and if you did get water that high wouldn't want it sucking it in
  10. Jun 30, 2013 at 5:36 PM
    #2310
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Zip tie it to the filler tube. As hi as the gas cap but no drilling. What I did.
  11. Jun 30, 2013 at 7:21 PM
    #2311
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well depending on run off this year..Christina lake could have a big river crossing..I doubt it'll be worse then last time I was there.
  12. Jun 30, 2013 at 7:34 PM
    #2312
    NativeTaco
    NativeTaco Mountain Man
    Travis
    Fort Collins, CO
    '08 DCLB
    ARB, OME, BAMF, ATO, Rigid, more... Mountain Man Limousine
    I put mine in the driver side storage cubby in the bed. Had to drill but did not have to take out the little cubby over the wheel well. It's on my build. Page three or something...
  13. Jun 30, 2013 at 7:34 PM
    #2313
    Blackdawg
    Monte
    Wyoming/St. Louis
    :woot:
    First BBQ donation received!
  14. Jun 30, 2013 at 7:35 PM
    #2314
    Blackdawg
    Monte
    Wyoming/St. Louis
    We don't have cubbys haha
  15. Jun 30, 2013 at 7:37 PM
    #2315
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thanks man.
    Doesn't have to be money either. If you just bring something for everyone that is fine too :cool:
    Just let me know. :)
  16. Jun 30, 2013 at 7:44 PM
    #2316
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    Oh yeah, duh.
  17. Jun 30, 2013 at 7:46 PM
    #2317
    Blackdawg
    Monte
    Wyoming/St. Louis
    Most of em ya. Not all I think.
    Plus poughise glutch if whatever.
    Why? Worried or excited?
  18. Jun 30, 2013 at 7:55 PM
    #2318
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    Been outta town camping....got some reading to catch up on. Anything important I missed?
  19. Jun 30, 2013 at 8:12 PM
    #2319
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not a ton I think..still ironing out CO
    Nice LED bars btw. My dad just bought a 10" rigid one for his hood scoop
    Ha! Nice lol
    And I think so. The guy I went a saved up in the bear tooths this year did the alpine loop last fall. He said they did it all in 3 days easy. Said if you reall went for it could do it in 2 or less. Most of it looks pretty easy. Just beautiful and fun.
  20. Jun 30, 2013 at 8:17 PM
    #2320
    Infra
    Az
    Nice, I'll catch up on the thread tonight. Thanks...the bars are nice and bright! I couldn't justify the price of a Rigid, they are damn spendy!!!! I love both my OKLED light bars!
