The Epic WY/MT/CO Adventure!!
Discussion in 'Off-Roading & Trails' started by Blackdawg, Feb 10, 2013.
I will be attending...
  1. Leg 1 only
    20.0%
  2. Leg 2 only
    12.0%
  3. Leg 3 only
    20.0%
  4. Legs 1 & 2
    16.0%
  5. Legs 2 & 3
    0 vote(s)
    0.0%
  6. Legs 1 & 3
    0 vote(s)
    0.0%
  7. All 3!!
    32.0%
  1. Jul 12, 2013 at 10:37 PM
    #2681
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    So Monte I've decided that I'm not concerned about Grizzlies this trip cause you'll be there to wrestle it down if necessary. :D
  2. Jul 12, 2013 at 10:38 PM
    #2682
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Exactly what I've been trying to tell people! I mean really..between my and my bro..we got this haha :p
  3. Jul 12, 2013 at 10:42 PM
    #2683
    Digiratus
    Roaming the PNW
    The RedHead
    who needs bear spray or shotgun pellets or whatever. :cool:
  4. Jul 12, 2013 at 10:46 PM
    #2684
    Digiratus
    Roaming the PNW
    The RedHead
    I'm hoping there will be public showers in ouray. not sure tho.
  5. Jul 12, 2013 at 10:49 PM
    #2685
    Digiratus
    Roaming the PNW
    The RedHead
  6. Jul 12, 2013 at 10:52 PM
    #2686
    Digiratus
    Roaming the PNW
    The RedHead
    Not in ouray but probably nearby. Have you looked at a map of the area. Look at one for Alpine Loop and you will see Ouray, Silverton and Telluride are all fairly close together.
  7. Jul 12, 2013 at 10:53 PM
    #2687
    Blackdawg
    Monte
    Wyoming/St. Louis
    You should be...you should be....
    And no idea for Ouray. I'm hoping to get my shower setup so we can all have a good rinse off...but other then that I'm not worried. No different then a week back packing haha
    I'd rather not stay in the towns if possible :eek:
    Damn straight :cool:
    Oooooooooo
  8. Jul 12, 2013 at 10:55 PM
    #2688
    Digiratus
    Roaming the PNW
    The RedHead
  9. Jul 12, 2013 at 11:00 PM
    #2689
    Digiratus
    Roaming the PNW
    The RedHead
    I think we are going to have to see how things develop. I suspect it will not be a "home base' type of thing as at least 2 of us have rtts. I figured we will be fine tuning the plan for leg 3 all the way up thru leg 2. :D
  10. Jul 12, 2013 at 11:05 PM
    #2690
    Blackdawg
    Monte
    Wyoming/St. Louis
    3. You me and Joey.
    I'm hoping just for spots along the trails..but might not be room for all of us..
  11. Jul 12, 2013 at 11:06 PM
    #2691
    Blackdawg
    Monte
    Wyoming/St. Louis
    You can refill at my house and at gas stations in wy. So after lander.
    And like I said. Should have ,y shower all setup too.
  12. Jul 12, 2013 at 11:08 PM
    #2692
    Digiratus
    Roaming the PNW
    The RedHead
    you worry too much. where's your sense of adventure. :p
  13. Jul 12, 2013 at 11:09 PM
    #2693
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ha! Funny guy :rolleyes:
    Shitll buff out haha
    Need a meeting spot picked out tho..
  14. Jul 12, 2013 at 11:10 PM
    #2694
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    I like this guy
  15. Jul 12, 2013 at 11:12 PM
    #2695
    Blackdawg
    Monte
    Wyoming/St. Louis
    Looks like some good restaurants. Wanna eat there?? Or just a gas station??
  16. Jul 12, 2013 at 11:16 PM
    #2696
    Digiratus
    Roaming the PNW
    The RedHead
    Downtown ouray is not very big, when 7 or 8 decked out Tacoma roll into town, we will be easy to spot. Hell, I'll bet a CB call will reach all the way across town.
  17. Jul 12, 2013 at 11:17 PM
    #2697
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lunch it is. I like trying local places anyways :D
    Timberline deli looks good. So does cost backstreet bistro or Ouray brewery.
  18. Jul 12, 2013 at 11:18 PM
    #2698
    Blackdawg
    Monte
    Wyoming/St. Louis
    Gonna be hilarious and awesome :cool:
    Since we will be coming from the north how about meeting the three others at the city park right before town. More parking there for the time being too. Then roll to a restaurant?
  19. Jul 12, 2013 at 11:20 PM
    #2699
    Digiratus
    Roaming the PNW
    The RedHead
    That sounds reasonable. But it also seems a bit early to pin that down as a "for sure' deal.
  20. Jul 12, 2013 at 11:23 PM
    #2700
    Digiratus
    Roaming the PNW
    The RedHead
