The Epic WY/MT/CO Adventure!!
Discussion in 'Off-Roading & Trails' started by Blackdawg, Feb 10, 2013.
I will be attending...
  1. Leg 1 only
    20.0%
  2. Leg 2 only
    12.0%
  3. Leg 3 only
    20.0%
  4. Legs 1 & 2
    16.0%
  5. Legs 2 & 3
    0 vote(s)
    0.0%
  6. Legs 1 & 3
    0 vote(s)
    0.0%
  7. All 3!!
    32.0%
  1. Feb 15, 2013 at 1:51 PM
    #261
    sander1036
    sander1036 Well-Known Member
    Snack Food Capital of the World
    02 SR5 TRD Double Cab 4x4
    THULE Roof Rack, Color matched grille w/ GrilleCraft, Toytec Ultimate, 33 x 12.5 Duratracs, Bushwacker Cut Out Flares, Cvt Mt Shasta, Cvt Awning, LEER Cap
    Hey Monte!!!
    Ohh you know just dreaming.... :cool:
  2. Feb 15, 2013 at 1:53 PM
    #262
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    LOL :D
    I would think the outside front tire..since its the widest part or the turn..
    Ya know..you could come here..instead of moab..haha :p
    jk. Go to Moab. Epic there.
  3. Feb 15, 2013 at 1:56 PM
    #263
    sander1036
    theres always next year :D
  4. Feb 15, 2013 at 2:00 PM
    #264
    Blackdawg
    Monte
    Wyoming/St. Louis
    lol
    Im going to moab next year again :anonymous:
  5. Feb 15, 2013 at 2:05 PM
    #265
    sander1036
    :angrygirl:
    maybe I'll decide to not come back from moab :cookiemonster:
  6. Feb 15, 2013 at 2:06 PM
    #266
    BradyT88
    BradyT88 Well-Known Member
    Front outside tire. Just googled it:D Since my rig is Just over 6ft wide that means every turn is at least a 12 foot diameter:p Should be fun:D haha
  7. Feb 15, 2013 at 2:12 PM
    #267
    Blackdawg
    Monte
    Wyoming/St. Louis
    HA! perfect! lol
    Bam!
    and yes..you and my dad will have it rough haha
  8. Feb 15, 2013 at 2:13 PM
    #268
    MTgirl
    Weesa
    Bob's secret mod lair
    Hopefully, if my plan works, I will already be at the top and can spot for everyone. Or if you're mean to me I will push boulders down on your heads :spy:
  9. Feb 15, 2013 at 6:12 PM
    #269
    Madjik_Man
    Colorado Front Range
    Throw me down as an overall lurker.
    The job situation is dicey as of now so I have no clue about the ability to get time off. I won't have a new lift and my suspension is sagging worse than my grandma... and I'm running 31 in tires.
    btw - the switchbacks in one of those first videos are hellacious
  10. Feb 15, 2013 at 7:52 PM
    #270
    C2T
    C2T Well-Known Member
    Richard
    Helena Montana
    Yes...it's a JEEP!
    35" Tires, AEV front recovery bumper, 2.5" AEV lift, Certified Mall Crawler sticker, Warn 9500 winch, Hi-Lift, Air compressor.
    I found the decent to be harder that going up. (isnt that always the case?) I came in from the other side and went down first, then back up to camp at the top. I had some switchbacks which required I jog back and forth as many as 10-11 times in my 4 door JK. My buddy (and guide) did about the same in his FJC. He had a slightly shorter rig and I had a slight edge in turning radius. I only used a spotter on a few of the SBs... mostly to help me get as close as I could to the edge or wall safely to minimize the jogs.
  11. Feb 15, 2013 at 8:42 PM
    #271
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    FIFY
    If there were just going to be two or three rigs, it might go better. Sounds like that number will be much higher.
    I just regeared just so I can go even slower. :cool:
    Sketchy
  12. Feb 15, 2013 at 8:49 PM
    #272
    Blackdawg
    Monte
    Wyoming/St. Louis
    Did you watch the vid of the trail on top? It is rough. I don't want you to be uncomfortable.
    It'll be awesome.
    And no I won't be locked...least..I don't THINK so..could happen. But I think if I buy a locker I'd get 4.88 gears f/r and just a rear arb for now..so what..like 1500 bucks ish? +/- 400. So ifi do that ill have no gas money most likely for this trip.
    But..who knows..
    If anything ill get a winch by then.
    Dang man sorry to hear at :eek: hope you can make it as I would enjoy meeting you!
    Thanks rich.
    How long did it take you guys?
  13. Feb 15, 2013 at 8:58 PM
    #273
    Digiratus
    Roaming the PNW
    The RedHead
    I suspect that a locker will be enough of a hindrance to turning sharply, that things will go better without one.
    I am toying with the idea of being able to use only the front one (leaving the rear open) after mostly clearing the turn to help pull the front of the truck around the rest of the way. Not really sure it is possible or even necessary. The front tires might be too sharply turned at that point, putting too much pressure on the front CVs if I use the locker.
    Sketchy
  14. Feb 15, 2013 at 9:00 PM
    #274
    farmerjon
    farmerjon Hailing from the land of bucking broncos...
    farmerjon
    Rugged Rockies
    '98 4Runner SR5, 4WD, V6, 3.4L.
    ARB, sleeping platform, Husky liners.
    You made me promise earlier not to kill anyone (for pictures) and now you're throwing boulders on people? :eek:
    lol, I'll help out.:p
  15. Feb 15, 2013 at 9:05 PM
    #275
    Blackdawg
    Monte
    Wyoming/St. Louis
    I wouldn't use a front locker on this unless you know you can drive almost straight. But I can see how that logic could work quit nicely.
    But I d think a rear locker will be nice or any locker. But when to turn iron and off will be important.
    And sketchy and fun haha
  16. Feb 15, 2013 at 9:07 PM
    #276
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'm confident in the fact either of you could pick up a boulder :p haha
  17. Feb 15, 2013 at 9:12 PM
    #277
    Digiratus
    Roaming the PNW
    The RedHead
    I keep having to fix these for you guys. :rolleyes:
  18. Feb 15, 2013 at 9:17 PM
    #278
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lol well I'm glad your here doing it :p
  19. Feb 15, 2013 at 9:21 PM
    #279
    BradyT88
    I think the front locker will just hinder turning... even more so than the rear locker. Now if we had a rear driveline disconnect then a front dig would be reasonable. Just set the e-brake and see if the front end can drag you around unlocked and if not, then lock it and give it a try:D
  20. Feb 15, 2013 at 9:29 PM
    #280
    Digiratus
    Roaming the PNW
    The RedHead
    No question it will hinder turning. In fact both will.
    I was thinking only turning it on coming out of the turn, as my right side slider is dragging along the rocks on the inside of the turn, :D
