The Epic WY/MT/CO Adventure!!
Discussion in 'Off-Roading & Trails' started by Blackdawg, Feb 10, 2013.
I will be attending...
  1. Leg 1 only
    20.0%
  2. Leg 2 only
    12.0%
  3. Leg 3 only
    20.0%
  4. Legs 1 & 2
    16.0%
  5. Legs 2 & 3
    0 vote(s)
    0.0%
  6. Legs 1 & 3
    0 vote(s)
    0.0%
  7. All 3!!
    32.0%
  1. Jul 13, 2013 at 10:58 PM
    #2781
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What the hell, it has its own built in bed rack. :rofl:
  2. Jul 13, 2013 at 10:59 PM
    #2782
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    If it's like the one I'm thinking of..I'm not sure it'll fit. I think the angled part might hit the roof..
    And would be funny.
  3. Jul 13, 2013 at 11:01 PM
    #2783
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    my parents have the same kind! almost wanted to bring it but it weighs so much. was a minute away from passing out in it this evening it was so comfy!
  4. Jul 13, 2013 at 11:04 PM
    #2784
    Blackdawg
    Monte
    Wyoming/St. Louis
  5. Jul 14, 2013 at 5:57 AM
    #2785
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    Captain Sparrow I'll have my Warbonnet blackbird hammock with under quilt and top quilt with me. Since I'll most likely be in the RTT most of the time, you are welcome to use it.
  6. Jul 14, 2013 at 6:51 AM
    #2786
    wheresmikeys
    wheresmikeys Get Some
    Michael
    Red Lodge, Montana
    08 Tacoma SR5 V6 TRD Off Road
    ARB Bumper. Old Man Emu Suspension Dont leave home without it
    I think I am meeting up with the others in Red Lodge before heading up the pass on Sunday? Is that right, Lisa? What is going on Friday?
    I know the Round Lake jeep trail road well, but some of the other routes on the map I am not familiar with.
  7. Jul 14, 2013 at 6:59 AM
    #2787
    wheresmikeys
    Michael
    Red Lodge, Montana
    Is it cool if I tow my howitzer along? Just to be safe.
  8. Jul 14, 2013 at 7:55 AM
    #2788
    Blackdawg
    Monte
    Wyoming/St. Louis
    Think lisa is starting on Friday..or Saturday. Ding a bit if a photo trip with Zane. Then mike and Ben and jason are to meet up with them on Sunday for the first part of Morrison. Monday morning you, Lisa, Zane, mike, Ben and Jason will continue down Morrison to the top of the switchbacks where you will meet andy, mark, Joey and I as we drive up the switchbacks.
    You bet haha
  9. Jul 14, 2013 at 7:58 AM
    #2789
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Ya dude I'm probably going to bring along some proximity mines to lay around camp. Bears want to sniff around our food? BOOM no more legs. That should keep us safe. Just watch out for em we you go to relieve yourself
  10. Jul 14, 2013 at 8:04 AM
    #2790
    MTgirl
    Weesa
    Bob's secret mod lair
    why else do we go out other than to take pictures?
    you're going. that's final. I have spoken. :angrygirl:
    this. we had some trouble with drinking and driving last year. i wasn't aware of hte situation until we were done for the day. its just stupid and unacceptable and really is putting the whole group at risk.
    bear spray and common sense is all I rely on. keep a clean camp and take what precautions you can.
    Jason's thinking of going with my group on Saturday now. So Satruday, passing through Red Lodge will be:
    Me
    Zane
    Jason (Mike)
    Jon - yes, you're going. don't argue with me
    Mike (maybe?)
    Sunday our group will add in Ben and Mike...
    We have too many Mike's on this trip! :goingcrazy:
  11. Jul 14, 2013 at 8:05 AM
    #2791
    MTgirl
    Weesa
    imma get one of these...
  12. Jul 14, 2013 at 9:07 AM
    #2792
    wheresmikeys
    Michael
    Red Lodge, Montana
    Yeah, its been a problem my whole life. A crew I was on in Yosemite had 7 mikes. We all went by our last name. So, most of my friends know me as Keys. I recommend you all just start calling me Keys.:cool: Maybe I will join up with you guys on Saturday.
  13. Jul 14, 2013 at 9:18 AM
    #2793
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    YES! :laugh:
    lisa you is genius! get me one
  14. Jul 14, 2013 at 9:21 AM
    #2794
    MTgirl
    Weesa
    if we all get one and park in a circle with the tailgates pointing out we won't have anything to worry about :cool:
    just like pioneers circling the wagons...
  15. Jul 14, 2013 at 9:23 AM
    #2795
    MTgirl
    Weesa
    :thumbsup: could lead to a lot of confusion...
    but I totally understand - my family had a lot of Bills...dad, g-pa, uncle, uncle's dad, cousin. made family get togethers very confusing until we established a bill, billy, will, willy, william system
  16. Jul 14, 2013 at 1:32 PM
    #2796
    Blackdawg
    Monte
    Wyoming/St. Louis
    We go to break shit duh :p
    Or at least to enjoy the vehicles we have dumped way to much money into :p
    And what?? Who was drinking??
    Deal :cool: keys it is.
    Just stay in contact with Lisa then. She is coordinating ll of that.
    :laugh:
    My tent??
  17. Jul 14, 2013 at 3:22 PM
    #2797
    MTgirl
    Weesa
    No one is breaking anything! :mad: Not negotiable!
    I enjoy my truck everyday :cool:
    I think Ben's saying he wants to cuddle with you in your tent... :notsure:
  18. Jul 14, 2013 at 5:00 PM
    #2798
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    HOLY FUCK. thats epic. OMG thats so sick!
  19. Jul 14, 2013 at 5:33 PM
    #2799
    Mudsaucecoma
    Mudsaucecoma Marks fucking mechanic
    Andy
    boise, idaho
    06 tacoma trd off road dcsb
    265/75r16 cooper discoverer st maxx ome 3" with 885 coils w/ an aal anytime locker mod sway bar delete Storm trooper mods custom hybrid sliders w/ kickout BHLM uniden 520xlpro w/ 4' firestck firewire and a B.A.M.F antenna mount
    That is truely amazing!...well done sir!
  20. Jul 14, 2013 at 7:02 PM
    #2800
    ZKuhl
    ZKuhl Expedition Montana
    zane
    MT
    2015 tacoma trd off road
    Iconstg 2, aal, 285/70/17 bfg's ko2 on 17x9 methods stampede deflector, auto vent visors, delta black diamond plate tool box pelfreybilt front bumper......?????
    there sweet sliders im pertty stoked too
