The Epic WY/MT/CO Adventure!!
Discussion in 'Off-Roading & Trails' started by Blackdawg, Feb 10, 2013.
I will be attending...
  1. Leg 1 only
    20.0%
  2. Leg 2 only
    12.0%
  3. Leg 3 only
    20.0%
  4. Legs 1 & 2
    16.0%
  5. Legs 2 & 3
    0 vote(s)
    0.0%
  6. Legs 1 & 3
    0 vote(s)
    0.0%
  7. All 3!!
    32.0%
  1. Feb 15, 2013 at 9:34 PM
    #281
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Only one way to find out :D
    Thanks Gage :cool:
  2. Feb 15, 2013 at 10:03 PM
    #282
    farmerjon
    farmerjon Hailing from the land of bucking broncos...
    farmerjon
    Rugged Rockies
    '98 4Runner SR5, 4WD, V6, 3.4L.
    ARB, sleeping platform, Husky liners.
    You haven't met me... You don't know... what... things... I'm capable...of....
  3. Feb 15, 2013 at 10:09 PM
    #283
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    This makes some sense to me but I suspect it will be difficult to implement. Overall, we will only be as fast as the slowest rig.
    :laughing:
  4. Feb 15, 2013 at 10:35 PM
    #284
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
  5. Feb 16, 2013 at 6:37 AM
    #285
    MTgirl
    Weesa
    Bob's secret mod lair
    Are you telling me not to come? :rolleyes:
    I did watch the videos and yes it was rough but there seemed to be plenty of clearance :notsure:
    :cool: Only if they're mean or if bad things happen to my truck
  6. Feb 16, 2013 at 7:03 AM
    #286
    C2T
    C2T Well-Known Member
    Richard
    Helena Montana
    Yes...it's a JEEP!
    35" Tires, AEV front recovery bumper, 2.5" AEV lift, Certified Mall Crawler sticker, Warn 9500 winch, Hi-Lift, Air compressor.
    It has been a little bit since we went down and then back up so I am no longer sure on just how long. I think it was about 1.5-2 hours down and about 1or 1.5 hours up. That was with two experienced wheelers with true trail rigs.Shorter (tighter turning) rigs definitely have an edge. I was really wishing for a two door jeep on that trail. lol
    If I may offer some other advice on this trail: I never found a need for lockers on this trail and would recommend people only use them if needed. They will make doing the switchbacks a nightmare. Much of it can be done in two wheel drive actually, though I don’t recommend that. The real challenge is not a "reallyrough" trail but is about the thinness of the road and the view over theedge affecting the heart rate and other bodily functions. J
    The switchbacks are a buggar as they are so sharp that my buddy with a Suzuki Samurai had to jog quite a few times on many of them. The scariest part for me was when I came across boulders which had rolled down and caused me to have to get closer to the edge than I like to get around them. Those same boulders are also the only reason you might need much lift or big tires so hope fully they will be cleared when you go. Rock rails helped me a few times though. This also means there is little need and even less ability to use a winch on this section unless something goes really wrong.
    If you get a large turnout, remember there are very few places to even get around an ATV, on the switches, let alone a full size rig. Nobody gets to come down until you are up and nobody goes up until you are off the switchbacks when you come back down. The remainder of the trail out to Long Lake is very scenic but not hard at all…just a great ride. Hope some of this helps.
  7. Feb 16, 2013 at 7:16 AM
    #287
    C2T
    Richard
    Helena Montana
    Yes...it's a JEEP!
    A graphic example of meeting someone going the other way on the switchbacks. hahaha!! :D
  8. Feb 16, 2013 at 12:55 PM
    #288
    Madjik_Man
    Colorado Front Range
    I'm definitely making it a goal. I would love to hang out and meet everyone too.
  9. Feb 16, 2013 at 2:55 PM
    #289
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    I'm seriously contemplating this. I will be up in Montana slaying cut throat and bull trout all month long in July....I could just tack this onto the end of my trip.
  10. Feb 16, 2013 at 4:00 PM
    #290
    MTgirl
    Weesa
    :quickdraw::quickdraw:
  11. Feb 16, 2013 at 8:59 PM
    #291
    Mudsaucecoma
    Mudsaucecoma Marks fucking mechanic
    Andy
    boise, idaho
    06 tacoma trd off road dcsb
    265/75r16 cooper discoverer st maxx ome 3" with 885 coils w/ an aal anytime locker mod sway bar delete Storm trooper mods custom hybrid sliders w/ kickout BHLM uniden 520xlpro w/ 4' firestck firewire and a B.A.M.F antenna mount
    Count me in as a lurker...if i can convince Mark to goto the same leg as I want to go I think it will be set in stone.
  12. Feb 16, 2013 at 9:44 PM
    #292
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thanks a lot man. Marlo's your more then welcome to join is :cool:
    No I am totally confident that toy can make it. But I want to make sure your prepared for it. As I said I don't want you out if your comfort zone..unless I'm there to help haha
    Do it!! It's all headed down south toward home anyways :cool:
    Sweet man!
  13. Feb 16, 2013 at 10:09 PM
    #293
    Digiratus
    Roaming the PNW
    The RedHead
    Wut :confused:
  14. Feb 16, 2013 at 10:13 PM
    #294
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lol was supposed to me also your more then welcome to join us Rich
  15. Feb 17, 2013 at 6:04 AM
    #295
    C2T
    Richard
    Helena Montana
    Yes...it's a JEEP!
    Thanks... I appriciate the invite.
  16. Feb 26, 2013 at 3:28 PM
    #296
    Rellikcro
    Rellikcro Active Member
    Western Washington
    2013 Tacoma SR5 4x4 4.0 V6
    Remote start with alarm
    I am interested in joining some of these events, I just have not been off road for a good 20 years and the truck is my DD and brand new... I think I would be too worried about it.
    If anyone ever does a more "leisure", for lack of better term, off roading please let me know. I need to learn to crawl before I sprint.
  17. Feb 26, 2013 at 3:46 PM
    #297
    MTgirl
    Weesa
    You could come along for the first part....I'm trying to plan a less exciting adventure at the beginning of the trip.
    Or I'll put you on my contact list for the MT meets. I like to keep things a little tamer and always plan for the most stock vehicle and least experienced driver.
  18. Feb 26, 2013 at 3:53 PM
    #298
    Rellikcro
    Western Washington
    Yeah my truck is 100% stock, even the tires. That would be cool if you could put me on your list and let me know.
  19. Feb 26, 2013 at 8:05 PM
    #299
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea what Lisa said. There will be an option for leg 1 for stock rigs. Although I'm pretty sure goose lake will be doable while stock. I'm going to go scout it in July.
  20. Feb 26, 2013 at 9:31 PM
    #300
    Digiratus
    Roaming the PNW
    The RedHead
    Whereabouts in Wa are you?
