The Epic WY/MT/CO Adventure!!
Discussion in 'Off-Roading & Trails' started by Blackdawg, Feb 10, 2013.
I will be attending...
  1. Leg 1 only
    20.0%
  2. Leg 2 only
    12.0%
  3. Leg 3 only
    20.0%
  4. Legs 1 & 2
    16.0%
  5. Legs 2 & 3
    0 vote(s)
    0.0%
  6. Legs 1 & 3
    0 vote(s)
    0.0%
  7. All 3!!
    32.0%
  1. Jul 22, 2013 at 8:31 PM
    #3061
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Be on a computer in 3 days!!! :woot:
  2. Jul 22, 2013 at 8:34 PM
    #3062
    MTgirl
    Weesa
    Bob's secret mod lair
    Yup!
  3. Jul 22, 2013 at 9:06 PM
    #3063
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    And you spew this why? :confused: I didn't realize you had so much experience driving both in all kinds of offroad conditions. :cool:
    Black Bear is very well documented, literally 100s od videos. By comparison, morrison has hardly ever had anyone on it. If morrison was as well documented as BB is, you would be skird shittless right now. :D
  4. Jul 22, 2013 at 9:12 PM
    #3064
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have experience with both..manual is more fun usually. But autos are super nice in their own ways. Idk which ill like more in the long run
    And exactly..after being to morriosn. I just think it'll be harder to drive.
  5. Jul 22, 2013 at 10:54 PM
    #3065
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    i dunno. i have seen enough pics and vids to know what morrison looks like. can only see so much of the same place. but everything from black bear just looks more intimidating
  6. Jul 22, 2013 at 10:56 PM
    #3066
    Blackdawg
    Monte
    Wyoming/St. Louis
    You'll never know :p
  7. Jul 22, 2013 at 10:59 PM
    #3067
    Blackdawg
    Monte
    Wyoming/St. Louis
    Askhole
    Tellhole
  8. Jul 22, 2013 at 10:59 PM
    #3068
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Well you keep coming here saying how badly you want to go but at the same time you keep saying how there is NOOOO way you could POSSIBLY get everything done. If that's the case then just don't go. If you really can't fit all into the next 30 days then that's your call. But for all of our sakes just make a call and stick to it. Better to weigh the pros and cons now then scramble to get it all worked out 3 days before the decision needs to be made.
  9. Jul 22, 2013 at 11:00 PM
    #3069
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    neat
  10. Jul 23, 2013 at 1:12 AM
    #3070
    Blackdawg
    Monte
    Wyoming/St. Louis
  11. Jul 23, 2013 at 6:04 AM
    #3071
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    All fire restrictions for San Juan and surrounding counties have been lifted.
    BB has only 1 tight switchback, maybe 2 if you don't pay attention. The most technical spot is not even on the main trail. It's an optional chute about 75 yds long that plops you right back on the trail. It is obvious, about 200 yds before the summit. Look for a small gulley on the right with a waterfall at the end.
    You will get a kick out of the "4wd tour" trucks. Most are full size trucks with some sort of flat bed and rows of bench seats. They look like the Beverly Hillbillies truck.
  12. Jul 23, 2013 at 1:54 PM
    #3072
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea. Didn't think there were that many bad corners. Morrison..pretty much every one is horrible. There are only 3-4 or so with space to back up all the way..ish on.
    And awesome!! :laugh: tour trucks. Bet they make a killing haha
    Yay camp fires!!
  13. Jul 23, 2013 at 8:33 PM
    #3073
    Digiratus
    Roaming the PNW
    The RedHead
    :D
    :cookiemonster:
    :ohsnap:
  14. Jul 23, 2013 at 8:35 PM
    #3074
    Digiratus
    Roaming the PNW
    The RedHead
    Besides iniweb, any other good sites for monitoring conditions?
  15. Jul 23, 2013 at 8:56 PM
    #3075
    MTgirl
    Weesa
  16. Jul 23, 2013 at 8:58 PM
    #3076
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Guys, I might have to cut the second leg short, and leave the 8th or just cut out the second leg. My best friend is getting married on the 9th at 6pm and I want to be there for him
  17. Jul 23, 2013 at 9:22 PM
    #3077
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
  18. Jul 23, 2013 at 9:26 PM
    #3078
    farmerjon
    farmerjon Hailing from the land of bucking broncos...
    farmerjon
    Rugged Rockies
    '98 4Runner SR5, 4WD, V6, 3.4L.
    ARB, sleeping platform, Husky liners.
    It's official fellas: I'm out. I hate to say it, I'm really sorry. I REALLY wanted to make it, but I can't. Even if I got enough done, I only have several days, and I need those to close up shop, say my goodbyes, hang out with and help my family, and etc.
    Monte has graciously agreed to help me with my valve cover gaskets and my long awaited surprise... and I might come to the Wed nite BBQ to meet some of you... It is MUCH easier for me, at this point, to get away for a few hours here and there, than 5-6 days as a block.
    Again, I'm REALLY sad that I can't make it - I really wanted to chop firewood for you all and take tons of photos of sick Toyotas in breathtaking scenery and lots of photo stops with Lisa...
    Sometimes I gotta do what I gotta do.
    Lisa: any chance you're making the BBQ?
  19. Jul 23, 2013 at 9:27 PM
    #3079
    Digiratus
    Roaming the PNW
    The RedHead
    I sure hope you are joking around
  20. Jul 23, 2013 at 9:31 PM
    #3080
    NativeTaco
    NativeTaco Mountain Man
    Travis
    Fort Collins, CO
    '08 DCLB
    ARB, OME, BAMF, ATO, Rigid, more... Mountain Man Limousine
    Holy shit, it's a repeat of last year! Except I will be in lander this time. :cool:
