The Epic WY/MT/CO Adventure!!
Discussion in 'Off-Roading & Trails' started by Blackdawg, Feb 10, 2013.
I will be attending...
  1. Leg 1 only
    20.0%
  2. Leg 2 only
    12.0%
  3. Leg 3 only
    20.0%
  4. Legs 1 & 2
    16.0%
  5. Legs 2 & 3
    0 vote(s)
    0.0%
  6. Legs 1 & 3
    0 vote(s)
    0.0%
  7. All 3!!
    32.0%
  1. Aug 16, 2013 at 6:37 PM
    #3661
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    at the rate you add weight to your truck, neither will you
  2. Aug 16, 2013 at 6:37 PM
    #3662
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    :wave:
    Bought one of them there coffee presses you gots old man :cool:
  3. Aug 16, 2013 at 6:38 PM
    #3663
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    you can go buy my old truck...
  4. Aug 16, 2013 at 6:42 PM
    #3664
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :D You must have enjoyed the coffee. Personally, I think those make the best cup ever.
  5. Aug 16, 2013 at 6:44 PM
    #3665
    Infra
    Az
    Yes, it was damned good coffee! Much better than my instant stuff, plus it got raving reviews all over the interwebs
  6. Aug 16, 2013 at 6:49 PM
    #3666
    T0xikTak0
    T0xikTak0 Active Member
    Todd
    Glendora
    08 Sport
    Cold Air intake + 50 horses!!
    Wow nice trails out there ! I gotta make it out there one day
  7. Aug 16, 2013 at 7:44 PM
    #3667
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    V8 will solve that
    Hasn't even seen half of it..
  8. Aug 17, 2013 at 11:08 AM
    #3668
    wheresmikeys
    wheresmikeys Get Some
    Michael
    Red Lodge, Montana
    08 Tacoma SR5 V6 TRD Off Road
    ARB Bumper. Old Man Emu Suspension Dont leave home without it
    Broke what? Replace what? :eek:
  9. Aug 17, 2013 at 11:26 AM
    #3669
    Infra
    Az
    Mike...what kind of fridge/freezer was it that you had? I'm looking at the Whynter 85qt and found it at a local Home Depot for under 5 bills, I'm assuming that's a good price?
  10. Aug 17, 2013 at 1:03 PM
    #3670
    Tonto27
    Tonto27 We came, we saw, we kicked its ass!
    Joey
    Denver, CO
    2004 double cab
    A bumper here, some tires there..... you know, stuff.
    yeah, its a whynter.........
    i was going to buy one too, but apparently my actual fridge took a shit while i was gone so i have to get that one first
  11. Aug 17, 2013 at 1:36 PM
    #3671
    Infra
    Az
    Great plan :thumbsup:
  12. Aug 17, 2013 at 1:39 PM
    #3672
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    you wouldn't be homeless man! Home can mean many things :cool:
  13. Aug 17, 2013 at 1:49 PM
    #3673
    Tonto27
    Joey
    Denver, CO
    2004 double cab
    na, i mean, i like pretending i'm homeless for a couple weeks but not that long.
  14. Aug 17, 2013 at 4:30 PM
    #3674
    SconnieHailer
    Marc
  15. Aug 17, 2013 at 9:48 PM
    #3675
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes it was a whynter.
    That's a pretty good price. Is it dual zone?? I'd want the freezer and fridge personally. But like Mike said they are on back order..or have been.
  16. Aug 17, 2013 at 10:28 PM
    #3676
    Infra
    Az
    No, not dual zone. Cheapest I found dual zone was around $700 on the interwebs
  17. Aug 17, 2013 at 10:33 PM
    #3677
    Blackdawg
    Monte
    Wyoming/St. Louis
    Do the dual!!!
  18. Aug 17, 2013 at 10:38 PM
    #3678
    Digiratus
    Roaming the PNW
    The RedHead
    Just got home. :woot: 12 hours straight thru from Ogden
    Mine is the 65 qt whynter and yeah, an 85 qt for $500 is a pretty good deal.
  19. Aug 18, 2013 at 2:58 AM
    #3679
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    Glad you guys made it home safe!
  20. Aug 18, 2013 at 5:30 AM
    #3680
    Blackdawg
    Monte
    Wyoming/St. Louis
    Glad you all made it home
