The Epic WY/MT/CO Adventure!!
Discussion in 'Off-Roading & Trails' started by Blackdawg, Feb 10, 2013.
I will be attending...
  1. Leg 1 only
    20.0%
  2. Leg 2 only
    12.0%
  3. Leg 3 only
    20.0%
  4. Legs 1 & 2
    16.0%
  5. Legs 2 & 3
    0 vote(s)
    0.0%
  6. Legs 1 & 3
    0 vote(s)
    0.0%
  7. All 3!!
    32.0%
  1. Dec 24, 2013 at 6:50 PM
    #3701
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :popcorn:
  2. Dec 24, 2013 at 6:52 PM
    #3702
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    I dont recall what the creek trail is.
  3. Dec 24, 2013 at 7:06 PM
    #3703
    Digiratus
    Roaming the PNW
    The RedHead
    Compressor. I believe its near I90 between CDA and the Montana border
  4. Dec 24, 2013 at 11:45 PM
    #3704
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea compressor! Looks Gnarly.
  5. Dec 27, 2013 at 1:23 PM
    #3705
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    oohhhhh
    could be fun!!
  6. Jan 21, 2014 at 7:34 AM
    #3706
    MTgirl
    Weesa
    Bob's secret mod lair
  7. Jan 21, 2014 at 10:02 AM
    #3707
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nice! crazy!
  8. Jan 21, 2014 at 11:39 AM
    #3708
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    So who's up for Goose Lake again this coming summer? I want to spend at least 3 days up in that area this time, doing some hiking and also spending some time at the other lakes we pass on the way in.
    What dates would be good for everyone that wants to go? I'll be up in Montana for most of July and August so whatever dates are best for you guys, are good for me.
  9. Jan 21, 2014 at 12:48 PM
    #3709
    Blackdawg
    Monte
    Wyoming/St. Louis
    probably play it by ear. Wait till June for that id guess or late may. Way to early right now.
  10. Jan 21, 2014 at 1:53 PM
    #3710
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea. but it was a 2week adventure and nothing was known about 80% of it haha
    we all know where it is now and what to expect. And just like last year, dates won't be set anyways till May. so again..i see no point in planning anything yet.
  11. Jan 21, 2014 at 2:06 PM
    #3711
    Infra
    Az
    Well I gotta plan all my other activities while I'll be up there, so I'm trying to figure where I should go and what I should do at what times. I know for fact I'm going to spend a week in Glacier National Park, hopefully baby taco and I will be spending about 8 - 10 days fly fishing and packrafting through the Bob...
  12. Jan 21, 2014 at 2:17 PM
    #3712
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well shit. I live less then an hour from there..haha im really not worried.
    You obviously need to make big plans. Im going up there again at least twice i bet and i live right there so..yea..im not worried about plans to meet you haha just make it a weekend and you'll be fine. If ya want my dad to come there will need to be a bit of coordination but nothing bad.
  13. Jan 21, 2014 at 2:17 PM
    #3713
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I'm definitely in for checkin out some of the trails up there this summer!
  14. Jan 21, 2014 at 2:19 PM
    #3714
    Blackdawg
    Monte
    Wyoming/St. Louis
    Damn..
    haha
    okay..maybe ill do a meet there then..
    Alright..Jason. You come up with a rough road plan and layout for your shenanigans and let me know. Ill figure out the rest.
  15. Jan 21, 2014 at 2:48 PM
    #3715
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    #gettingachubalready....
  16. Jan 21, 2014 at 2:51 PM
    #3716
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Is this from the Goose section? Cause this is pure badassery, and I want to spend the whole summer in places like this. Still got a lot of CO to see, but I know wyo has got the goods too.
  17. Jan 21, 2014 at 3:01 PM
    #3717
    Infra
    Az
    Yes, actually that's our camp right below Goose Lake. Simply awe inspiring scenery :cool:
  18. Jan 21, 2014 at 3:05 PM
    #3718
    PS78
    PS78 I like beer, I brew beer!
    Rancher
    2011 DCSB TRD OR
    to many to list, check the build thread
    that might be the best looking camp ive ever seen!!
  19. Jan 21, 2014 at 3:08 PM
    #3719
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes that is the end of goose lake trail.
    Pretty much awesome. up there.
  20. Jan 21, 2014 at 3:26 PM
    #3720
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
