The Epic WY/MT/CO Adventure!!
Discussion in 'Off-Roading & Trails' started by Blackdawg, Feb 10, 2013.
I will be attending...
  1. Leg 1 only
    20.0%
  2. Leg 2 only
    12.0%
  3. Leg 3 only
    20.0%
  4. Legs 1 & 2
    16.0%
  5. Legs 2 & 3
    0 vote(s)
    0.0%
  6. Legs 1 & 3
    0 vote(s)
    0.0%
  7. All 3!!
    32.0%
  1. Mar 11, 2013 at 4:17 PM
    #401
    BradyT88
    BradyT88 Well-Known Member
    Til you slide off of the side of the mountain on the Switchbacks;)
    Why is it always Mark that gets picked on? haha
  2. Mar 11, 2013 at 4:19 PM
    #402
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    easy target, I think if Aleks posted more wed pick on him, but I think hes clinically depressed so Marks the better choice he might not kill himself or others
    RIGHT DERP
  3. Mar 11, 2013 at 4:23 PM
    #403
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    It'll be fun no doubt! Probably be a bit tame after cliff hanger haha but you'll still enjoy it. Like i said before. Totally different way of wheeling. Avoiding hundreds of mini diff crunching boulders haha
  4. Mar 11, 2013 at 8:49 PM
    #404
    farmerjon
    farmerjon Hailing from the land of bucking broncos...
    farmerjon
    Rugged Rockies
    '98 4Runner SR5, 4WD, V6, 3.4L.
    ARB, sleeping platform, Husky liners.
    Not to mention with the snowpack, the hillsides will be a little looser :p
    I was just about to post on here and ask for any updates. So far either the 5th or the 12th (or the few days before works for me - depends on when we get a start in MTgirl's group).
    Looking forward to it.
  5. Mar 11, 2013 at 8:51 PM
    #405
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lisa's group will meet in the bear tooths on either Saturday or Sunday.
  6. Mar 11, 2013 at 8:52 PM
    #406
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :eek:
    Is that 90% above normal?
  7. Mar 11, 2013 at 8:54 PM
    #407
    Blackdawg
    Monte
    Wyoming/St. Louis
    No..anything over 100% would be. But that was a few weeks ago. S could get over
    But this area is very dry. Water is an issue always as we get it all mainly from snow pack. So anything above 80% is epic really.
  8. Mar 11, 2013 at 8:58 PM
    #408
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    I could add this on to the end of my Montana trip if you guys start on the 5th. Will not be able to attend if you start on the 12th. If I did make it, I would be attending legs 2 & 3.
  9. Mar 11, 2013 at 9:03 PM
    #409
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sweet man. Those will be some of the coolest ones :D actually they all will be.
    But would be cool for you to join! Get a wy fishing license to fish at Shoshone.
  10. Mar 11, 2013 at 9:24 PM
    #410
    Digiratus
    Roaming the PNW
    The RedHead
    Ah, so still a little below normal as of now. Could still see another big storm before full spring kicks in.
  11. Mar 11, 2013 at 9:27 PM
    #411
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well..actually above normal..like I said. The last 15 years we have been in drought. So anything above 80 is amazing. But yes. Winter is not done here in the mountains..hell even done here in the desert valley we get a flash snow storm. I remember my sophomore year of high school in April it just up and decided to dumb 2-2.5' of snow haha was a fun soccer practice that day! Haha
  12. Mar 12, 2013 at 10:19 AM
    #412
    MTgirl
    Weesa
    Bob's secret mod lair
    It would work better for me to make it a Saturday - Tuesday trip, then I'm only missing 2 days of work.
    That means that my group would start in Red Lodge on Saturday and mess around along the side roads until sometime Sunday, then get in the north end of Morrison on Sunday afternoon and wait for you guys to start on Monday morning. Back track along the Morrison together and either camp there or start Goose, finishing on Tuesday and heading for home. Gonna make Tuesday a really long day but hopefully it will be worth it. I can rest up when I get back to the office :cool: :eek:
    :laugh: no. historical averge snowpack is considered as 100% so 90% is 10% less than average. And from what I've seen in the northern portions of yellowstone and in the west end of the park my guess is that overall snowpack is even lower than 90%...I was in West Yellowstone this last weekend and usually the city has more snow than they know what to do with. On an average year the snowplows bury the stop signs along the city streets and a crew has to come back out to chisel the snow back from the signs. This year the snow isn't even waist deep in town and less than 3' in the park where I snowshoe.
    My suspicion is that its going to be a dry summer
  13. Mar 12, 2013 at 10:52 AM
    #413
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea i think its gonna be a dry year again too :eek: hopefully there aren't as many fires this year so we can have a fire as we won't be on any real camp grounds :pray:
  14. Mar 12, 2013 at 12:04 PM
    #414
    MTgirl
    Weesa
    I already have a backup plan :cool:
    But, yes, camping without a campfire is pretty crummy
  15. Mar 12, 2013 at 1:25 PM
    #415
    Blackdawg
    Monte
    Wyoming/St. Louis
    Would totally suck. So hopefully that doesn't happen.
  16. Mar 12, 2013 at 4:08 PM
    #416
    farmerjon
    farmerjon
    Rugged Rockies
    This works well for me too. Add my vote to this schedule idea.
    I'm thinking it will be a dry summer too. With the effects of the federal sequestration on the budget, firefighting is gonna be a nightmare. Who knows what's gonna happen.
  17. Mar 12, 2013 at 6:56 PM
    #417
    Blackdawg
    Monte
    Wyoming/St. Louis
    Okay ill add something to the OP talking about the "dumbed down" version.
    Lisa im assuming this will also just be a MT meet..
  18. Mar 12, 2013 at 7:01 PM
    #418
    MTgirl
    Weesa
    :( :mad: :pout: :brianr: :angrygirl:
  19. Mar 12, 2013 at 7:02 PM
    #419
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha oh come on..what else would it be?? simplified?
  20. Mar 12, 2013 at 7:07 PM
    #420
    MTgirl
    Weesa
    I don't wanna go if you're gonna be mean like that :(
