The Epic WY/MT/CO Adventure!!
Discussion in 'Off-Roading & Trails' started by Blackdawg, Feb 10, 2013.
I will be attending...
  1. Leg 1 only
    20.0%
  2. Leg 2 only
    12.0%
  3. Leg 3 only
    20.0%
  4. Legs 1 & 2
    16.0%
  5. Legs 2 & 3
    0 vote(s)
    0.0%
  6. Legs 1 & 3
    0 vote(s)
    0.0%
  7. All 3!!
    32.0%
  1. Mar 21, 2013 at 10:37 PM
    #461
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    NO! GOD, WRONG! :smack:
    for the price of a re gear you can come to moab. You cant bitch about wanting to go then pull that crap haha. your god tier manual does just fine. no need to regear.
  2. Mar 21, 2013 at 10:44 PM
    #462
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    No. pics of the wheels on his truck to show proof they are his.
    Is your speedometer and odometer correct? After I regeared, mine was way off. I ended up changing the little plastic speedo gear to get it pretty close so now the speedo and odo are correct.
    My scangauge also now gets correct information from the ecu.
  3. Mar 21, 2013 at 10:45 PM
    #463
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I think i need it man. My rig is a PIG. Super freaking heavy. And even in 4lo 1st gear i feel i moves too fast sometimes. I espceally felt this way after Lander. Its sooooo rocky that you can just cruise through it. An auto will be nice there. But my truck weights so much and the air drag from the lights is killer.
    i do want to come to moab very badly. But..it'll always be there.
    besides i want a locker next time i go there for the meaner trails. i don't want to do all the smooth trails again.
  4. Mar 21, 2013 at 10:48 PM
    #464
    Blackdawg
    Monte
    Wyoming/St. Louis
    yes we did haha
  5. Mar 21, 2013 at 10:54 PM
    #465
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    but anyway. Monte I understand you want to regear and make your truck perfect now, and that it can be a pig due to the weight...but come on, do the expensive mods in the winter when its not prime wheeling time. Im sure you are a capable enough driver you can manage one more summer with your gears.
  6. Mar 21, 2013 at 10:59 PM
    #466
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh yes i could.
    but i don't have a job in the winter haha summer man.
    Moab still isn't totally out of the question for me..it could stilll happen if i land a few more gigs here and there.
    But i really want to give the re gearing a go. my truck is more sluggish then ever. I doubt i could even over take you again :laugh:
    I have some welding to do and other then the re gearing. Only thing im gonna add is the frame reinforcement plates. And i have a lot of just maintenance to do on it.
  7. Mar 21, 2013 at 11:01 PM
    #467
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    well thats good to hear :thumbsup:
    :laugh:the race is on then!
  8. Mar 21, 2013 at 11:01 PM
    #468
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    No, they aren't correct. I keep the numbers for the GPS and Speedometer MPH difference displayed on the app. Where does one obtain such a speedo gear contraption?
    :rofl:
  9. Mar 21, 2013 at 11:02 PM
    #469
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    wow you fuck wad! was expecting a little green box but NOPE!
    douche level ben
    hey jon! :wave:
  10. Mar 21, 2013 at 11:05 PM
    #470
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    delt with it
  11. Mar 21, 2013 at 11:07 PM
    #471
    Blackdawg
    Monte
    Wyoming/St. Louis
  12. Mar 21, 2013 at 11:09 PM
    #472
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
  13. Mar 22, 2013 at 3:39 AM
    #473
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Thanks bud!
    I voted for the 12th BTW. The later, the better. Not sure how long I can take off from work (I'm only considered part-time), but either way I probably wouldn't be able to make the MT part of the trip.:( Also my sister wants me to take her on a week long hiking trip through the Wind River range around the same time, so I'm trying to figure out if I can somehow fit that in as well. :facepalm:
    Quite honestly, I'm not so keen on the idea of those switchbacks on the Morrison trail either.:eek: Especially with the crappy turn radius I have now that I'm not running wheel spacers up front.
  14. Mar 22, 2013 at 7:56 AM
    #474
    MTgirl
    Weesa
    Bob's secret mod lair
    I voted either weekend. It doesn't really matter to me when it is but the sooner the decision is made the sooner I can turn in a vacation request to make sure I get the time off. I'm planning on taking a Mon-Wed off for this.
  15. Mar 22, 2013 at 8:12 AM
    #475
    BradyT88
    BradyT88 Well-Known Member
    You have to calibrate it. Calibrating the mileage is easy if you know the percentage it is off. Calibrating the fuel is harder though. I switched to an ultraguage since it is always there and plugged in making it easier to calibrate.
  16. Mar 22, 2013 at 8:26 AM
    #476
    Digiratus
    Roaming the PNW
    The RedHead
    That most likely explains why you might be getting odd info from your torque app. The ecu is not getting correct info from the speedo sensor so it is sending that incorrect info on to the app.
    I ended up ordering one of those little gears from my dealer. It was the 33 tooth one. My truck had the 31 tooth in it.
    It snowed here last night. :eek: I have a feeling you guys are going to get a lot more snow before its over.
  17. Mar 22, 2013 at 8:26 AM
    #477
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    snowed here too, are you sending that stuff just straight across the PNW?
  18. Mar 22, 2013 at 8:27 AM
    #478
    BradyT88
    Hopefully this doesn't fuck up my spring break...
  19. Mar 22, 2013 at 8:50 AM
    #479
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    you too eh!!!! my garage door is has snow 3/4 of the up it atm with my truck stuck on the inside
  20. Mar 22, 2013 at 8:59 AM
    #480
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, to the eastern PNW
    <-------:D
