The Epic WY/MT/CO Adventure!!
Discussion in 'Off-Roading & Trails' started by Blackdawg, Feb 10, 2013.
I will be attending...
  1. Leg 1 only
    20.0%
  2. Leg 2 only
    12.0%
  3. Leg 3 only
    20.0%
  4. Legs 1 & 2
    16.0%
  5. Legs 2 & 3
    0 vote(s)
    0.0%
  6. Legs 1 & 3
    0 vote(s)
    0.0%
  7. All 3!!
    32.0%
  1. Mar 22, 2013 at 9:13 AM
    #481
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :eek: Its snowing again
    edit: I drove the wrong vehicle to work today. :rant:
  2. Mar 22, 2013 at 9:17 AM
    #482
    MTgirl
    Weesa
    Bob's secret mod lair
    :sadviolin:
  3. Mar 22, 2013 at 9:44 AM
    #483
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    I am considering parts 1 and 2 of this trip. The only thing that will get in the way is dates or funds. I am new to wheeling but by the time this trip happens I will have Moab and a few other trips under my belt.
    I only read the first couple pages hope I didn't miss anything in the other 27 pages!
  4. Mar 22, 2013 at 9:53 AM
    #484
    Digiratus
    Roaming the PNW
    The RedHead
    This ^^^
  5. Mar 22, 2013 at 9:59 AM
    #485
    BVCOTaco
    BVCOTaco Well-Known Member
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    I have been wanting to do the Alpine Loop for the past couple of years since I moved to CO. So as the trip gets closer, I should know if I will be in town or not. I live in Buena Vista, CO and would like to meet up for that leg.
    Once you get the dates for that leg figured out, I should know better. If it is a weekend, it will make it easier for me!
  6. Mar 22, 2013 at 10:59 AM
    #486
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Bring her to lander with us :D
    And whhhhaaatt??? Common! And your turning radius would be worse with the spacers...it's not gonna be as bad as mine haha
    Cool thanks lisa!
    Sweet man!!
    You have armor?? 33s?? Are you a long bed or short?
  7. Mar 22, 2013 at 10:59 AM
    #487
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    How much is the elevation going to play into my trucks power? I am from Illinois so I might need a tune before I start to wheel?
    BAMF Sliders, Short bed, Pelfreybilt Plate bumper, Warn VR 10,000. Might have bigger tires by the time this happens.
  8. Mar 22, 2013 at 11:01 AM
    #488
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hopefully you'll have the bigger tires.
    No I wouldn't worry about tuning the truck.
  9. Mar 22, 2013 at 11:05 AM
    #489
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes eh should adjust accordingly. Whole point of MAF. The lack of oxygen could impair it. Nothing just disconnecting the battery won't fix
  10. Mar 22, 2013 at 11:14 AM
    #490
    rockgecko03
    rockgecko03 Well-Known Member
    Ben
    Rockwall, TX
    1999 Tacoma - Perpetual Project
    No, you don't need a tune and you'll be just fine. I drove my truck up over 14,000 feet without issue on 35's and stock gearing. Only people that need to worry about altitude are those with carbs.
  11. Mar 22, 2013 at 11:28 AM
    #491
    Digiratus
    Roaming the PNW
    The RedHead
    You can go 25 mph in 4lo? :eek:
    I would be bouncing off the rev limiter going that fast in 4lo. :laugh:
  12. Mar 22, 2013 at 11:47 AM
    #492
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    I voted August 5th start
  13. Mar 22, 2013 at 12:01 PM
    #493
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Well I guess I need to buy some bigger tires then! This is the perfect excuse! I have 265/70/16 BFG A/T right now I plan on getting 285/75/16 BFG A/T and doing a cab mount chop during the summer. My guess is I will be fine with that set up.
    If I do the whole thing I would be looking at over $1000 in just gas. I should ship my truck to the start and fly. It might be cheaper. :cool:
  14. Mar 22, 2013 at 12:27 PM
    #494
    farmerjon
    farmerjon Hailing from the land of bucking broncos...
    farmerjon
    Rugged Rockies
    '98 4Runner SR5, 4WD, V6, 3.4L.
    ARB, sleeping platform, Husky liners.
    How would that be cheaper? though you would save on mileage.
    Plane ticket might be ~$400 roundtrip. I have no clue what shipping will be. You'll still need lots of gas on this end, Wyoming & Montana are HUGE. like, HUGE man. :p
    You can fly into Billings, or Bozeman, or Cody, Wyoming. Cody is much more expensive than BIL...
  15. Mar 22, 2013 at 12:38 PM
    #495
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    this. its not like we are going to break speed records. itll be slow enough driving in low enough gears it wont matter.
  16. Mar 22, 2013 at 12:40 PM
    #496
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    what legs will you be going on?
    ya thats what kills everyone on these trips. gas is a bitch and out west you measure distance on hours.
  17. Mar 22, 2013 at 12:42 PM
    #497
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    I wasn't really serious. lol I think the ride there is part of the adventure.
  18. Mar 22, 2013 at 12:43 PM
    #498
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    just going to quote this so we all know what we are in for...
  19. Mar 22, 2013 at 12:55 PM
    #499
    Infra
    Az
    More than likely I would be down for legs 2 & 3 if I did attend. Only reason I voted for August 5th start is because I will be ending my month long Montana road trip near the end of July or 1st week of August so I could take an extra week or so off and just tack this onto the end of my trip.
  20. Mar 22, 2013 at 12:59 PM
    #500
    Digiratus
    Roaming the PNW
    The RedHead
    An H3 that was locked front and rear. just sayin. :p
