The Epic WY/MT/CO Adventure!!
Discussion in 'Off-Roading & Trails' started by Blackdawg, Feb 10, 2013.
I will be attending...
  1. Leg 1 only
    20.0%
  2. Leg 2 only
    12.0%
  3. Leg 3 only
    20.0%
  4. Legs 1 & 2
    16.0%
  5. Legs 2 & 3
    0 vote(s)
    0.0%
  6. Legs 1 & 3
    0 vote(s)
    0.0%
  7. All 3!!
    32.0%
  1. Mar 22, 2013 at 1:42 PM
    #501
    BradyT88
    BradyT88 Well-Known Member
    I think he means that without the spacers his tires rub the frame so he can't turn lock to lock.
    No way! In 4Lo I hit my rev limiter at just over 40mph and that is without overdrive (4Lo won't let the tranny shift into 5th) 1st gen's Tcases are geared higher too so you can go faster than me I'm sure. If you and I could use overdrive in 4Lo you would really go faster than me. And you guys redline at 6000 instead of 5500n don't you?
  2. Mar 22, 2013 at 2:58 PM
    #502
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Sorry I didn't mean like full out. It'll impact performance like you said. But not noticeable. Not till I go to 16-17,000 feet in Chile :cool:
    5th gear in 4 low...is stupid haha
    I never go higher then 2nd and early into 3rd. If it's that fast..I just pop it back I to 4h
    Yes do it!!
    Seriously tho you will be grateful of the extra clearance. These trails are just a road of mini diff crunching boulders. Every inch counts.
    And I doubt you could ship it anywhere near by lol maybe billings..but that's still 100ish miles away haha
    Yep. And on 33s...and it still got high centered. Twice I think.
    I don't think it's a hardcore trail in the sense you have to know how to drive up a 4' wall or trench.
    Like I said, it's not a place that has 2-4 big obstacles and the rest you can just roll over. It's a constant pounding of rocks and the slightest wrong line and your bashing your diff. Takes a lot of concentration and constant changing of your line. John and I last year literally took breaks it was so monotonous on Shoshone.
    It'll be different then what I think most will be used to. But fun. I don't think it'll kill anyone's rig at all. But there is the potential there. Just in different ways.
    I don't want to talk it up like its rubicon. Cause it's not. But it's not a trail for an armor less rig.
  3. Mar 22, 2013 at 3:02 PM
    #503
    BradyT88
    Sounds lame then... I'm out... Have fun guys:rolleyes:
    :rofl: Just Kidding. I hope I am in.
  4. Mar 22, 2013 at 3:04 PM
    #504
    Blackdawg
    Monte
    Wyoming/St. Louis
    You better be in..there is a part on Christina that is a much harder line I wanna see those locker walk up haha
  5. Mar 22, 2013 at 6:57 PM
    #505
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :notsure: I cannot imaging a need for ever having to go faster than 15 mph when in 4lo. In the spot the Ben refferenced on White Rim there was no way we were in 4lo. There was no reason on the whole trail to be in 4lo. I'm gonna stand by what I said. About 25 max in 4lo.
    Your tcase is vulnerable.
    I start breathing heavy over 10K feet, can't imaging what it'll be like at 12 or 13K.
  6. Mar 22, 2013 at 7:04 PM
    #506
    BradyT88
    I use it to accelerate harder. Like when I am playing in the dunes. I don't think I ever even break 35 when I am out there but I sure accelerate and brake hard the whole time.
    When I went wheeling the other day there was a stretch towards the end of the trail where I was trying to keep up with a UTV and was braking and accelerating hard again because I had to slow down for obstacles that the UTV could just weave around. I can just accelerate a lot harder in 4Lo. Now if I am just going to be maintaining a high speed for a while then I will shift into 4Hi so my rpms aren't clear up there.
  7. Mar 22, 2013 at 7:04 PM
    #507
    BradyT88
    My y-pipe protects mine:rolleyes:
  8. Mar 22, 2013 at 7:49 PM
    #508
    farmerjon
    farmerjon Hailing from the land of bucking broncos...
    farmerjon
    Rugged Rockies
    '98 4Runner SR5, 4WD, V6, 3.4L.
    ARB, sleeping platform, Husky liners.
    Gonna be interesting to meet some of you and put faces to all the stuff said on these forums.
  9. Mar 22, 2013 at 8:17 PM
    #509
    Digiratus
    Roaming the PNW
    The RedHead
    As has been pointed out in previous discussions, my MO is not to go fast. In most of the wheeling I do, that is only possible on FS roads anyway and I would definitely not be in 4lo for those.
    My budbuilt protects mine, shame if you crush your y-pipe
    I never have to shift either. :p
  10. Mar 22, 2013 at 10:11 PM
    #510
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    I may be in that AO depending on when my block leave is, if I am I will make sure to join up.
    My current trip plan is to drive from home (Fort Leonard Wood, MO) to Colorado Offroad Extreme Park and spend a night there. It looks to have a killer track that is perfect for my mild LT truck to stretch its legs and get some safe / reasonable air.
    From there, Estes Park and some rock climbing / hiking.
    Then I'll move on to Moab and spend a few days exploring there.
    Then swing up to Wyoming, hit some trails and camping there, and drive home through South Dakota, stopping at Mt. Rushmore.
    Planning about 10-15 days.
  11. Mar 22, 2013 at 10:12 PM
    #511
    Blackdawg
    Monte
    Wyoming/St. Louis
    Cool man! Just let me know
  12. Mar 23, 2013 at 10:11 AM
    #512
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    ^ thank you for the morning chuckle :)
  13. Mar 24, 2013 at 8:55 PM
    #513
    ttora4runner
    ttora4runner Member
    Colorado Springs, Co
    2002 Toyota 4runner
    I'm out. Got some other plans.
  14. Mar 24, 2013 at 8:59 PM
    #514
    Blackdawg
    Monte
    Wyoming/St. Louis
    Damn :(
    No worries :D thanks for letting me know.
    And the drop outs begin...haha
  15. Mar 24, 2013 at 9:03 PM
    #515
    ttora4runner
    ttora4runner Member
    2002 Toyota 4runner
    Plans can always change. :D I'll just be coming back from Glacier NP at the end of July and will have to let the gas funds recover some.
  16. Mar 24, 2013 at 9:06 PM
    #516
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh nice man. That place is supposed to be great!
    I feel you on the gas..
  17. Apr 1, 2013 at 9:39 PM
    #517
    farmerjon
    farmerjon
    Rugged Rockies
    Sooo... any updates?
    Would it help, if I brought a chainsaw and my axe/splitting maul, assuming no fire restrictions by then? I'm assuming we're gonna want some campfires, I'd be happy to maintain a supply of wood :D
  18. Apr 1, 2013 at 9:42 PM
    #518
    Digiratus
    Roaming the PNW
    The RedHead
    Yes, please....for all 8-9 campfires. That'll keep ya busy. :D
  19. Apr 1, 2013 at 9:43 PM
    #519
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ill have a big spiting axe and hatchet. Idk if a Chainsaw will be needed..
    can't hurt i guess.
    And not much to update really. Just waiting...waiting..waiting..
  20. Apr 1, 2013 at 9:44 PM
    #520
    Digiratus
    Roaming the PNW
    The RedHead
    4 months away...
