The Epic WY/MT/CO Adventure!!
Discussion in 'Off-Roading & Trails' started by Blackdawg, Feb 10, 2013.
I will be attending...
  1. Leg 1 only
    20.0%
  2. Leg 2 only
    12.0%
  3. Leg 3 only
    20.0%
  4. Legs 1 & 2
    16.0%
  5. Legs 2 & 3
    0 vote(s)
    0.0%
  6. Legs 1 & 3
    0 vote(s)
    0.0%
  7. All 3!!
    32.0%
  1. Apr 4, 2013 at 10:29 PM
    #561
    NativeTaco
    NativeTaco Mountain Man
    Travis
    Fort Collins, CO
    '08 DCLB
    ARB, OME, BAMF, ATO, Rigid, more... Mountain Man Limousine
    And that is why the first leg is not for me.
  2. Apr 4, 2013 at 10:56 PM
    #562
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    21 changes of direction, counted them. The hairpin with the "fence" is turn 11, the halfway point.
  3. Apr 4, 2013 at 11:03 PM
    #563
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No more then that..think it's 26..but maybe not..a lot either way
  4. Apr 4, 2013 at 11:12 PM
    #564
    Blackdawg
    Monte
    Wyoming/St. Louis
    36!
    22!
    10!
    47!
  5. Apr 4, 2013 at 11:15 PM
    #565
    Digiratus
    Roaming the PNW
    The RedHead
  6. Apr 4, 2013 at 11:19 PM
    #566
    Blackdawg
    Monte
    Wyoming/St. Louis
    Already did that..
    Only way up this time is driving up!
  7. Apr 4, 2013 at 11:20 PM
    #567
    Digiratus
    Roaming the PNW
    The RedHead
    :D
    edit: btw, I did not say hike it. :rofl:
  8. Apr 5, 2013 at 8:24 AM
    #568
    BradyT88
    BradyT88 Well-Known Member
    That's just how your 4 cylinder feels;)
    You and I are pretty close length wise. I basically traded a foot of my bed for a foot of cab space and you're wider than me! At least I think that is what we decided wasn't it?
    I'm not too worried about being in a double cab. It's the DCLB that I would be worried about.
  9. Apr 5, 2013 at 8:28 AM
    #569
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea i was wider by 1'' at the tires. But now that i think about it...i be we are the same as your tires sit inside your fenders. mine dont
  10. Apr 5, 2013 at 8:31 AM
    #570
    BradyT88
    Yeah. I can fully stuff mine without touching the fenders or flairs.
  11. Apr 5, 2013 at 8:53 AM
    #571
    Blackdawg
    Monte
    Wyoming/St. Louis
    so i bet your actual truck is about the same width..or a tad more.
  12. Apr 5, 2013 at 8:55 AM
    #572
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    ya. tire and wing span (sliders) don't really count
  13. Apr 5, 2013 at 8:58 AM
    #573
    BradyT88
    He was talking fenders. Monte has fiberglass up front now that probably makes his fenders the same.width as mine. Plus that land cruiser. Pulling the trailer is even wider than a 2nd gen and it.had a trailer!
  14. Apr 5, 2013 at 9:01 AM
    #574
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    YOU'RE TRUCK IS A BOAT! JUST ADMIT IT!!!!!:D
    so you pretty confident you will be comming on this one?
    diff drop has also been ordered...hopefully I don't blow a cv driving to moab any Wyoming..
  15. Apr 5, 2013 at 9:11 AM
    #575
    MTgirl
    Weesa
    Bob's secret mod lair
    because you're supposed to go OVER teh rocks :rolleyes:
    oh hush
    WOuld you like to join my group starting a day before and going in from the north end, skipping the switchbacks?
  16. Apr 5, 2013 at 9:38 AM
    #576
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    Starting from further north? I'm not sure the first leg worked out with my schedule anyway. Lander is already a far drive for me (farther than Moab). But if I decide to come out to make that trip, I will definitely contact you for details.
  17. Apr 5, 2013 at 10:43 AM
    #577
    BradyT88
    :rofl: It definitely looks bigger that's for sure! And factory to factory yeah 2nd gens are a little bigger. But while I have made mine a little skinnier, Monte has made his a lot wider. haha
    I probably won't know for sure whether I can go or not until like the week before... Welcome to the Army...
  18. Apr 5, 2013 at 10:45 AM
    #578
    Blackdawg
    Monte
    Wyoming/St. Louis
    Keeping it exciting Brady haha
    And yea..mine is quite wide..and tall now..
  19. Apr 5, 2013 at 10:53 AM
    #579
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    oh, is this a dick measuring contest now?:p
  20. Apr 5, 2013 at 10:55 AM
    #580
    Blackdawg
    Monte
    Wyoming/St. Louis
    :laugh: no
    Tall isn't such a good thing for off camber stuff..
    But the roof rack and RTT make it a bit tall..haha
