The Epic WY/MT/CO Adventure!!
Discussion in 'Off-Roading & Trails' started by Blackdawg, Feb 10, 2013.
I will be attending...
  1. Leg 1 only
    20.0%
  2. Leg 2 only
    12.0%
  3. Leg 3 only
    20.0%
  4. Legs 1 & 2
    16.0%
  5. Legs 2 & 3
    0 vote(s)
    0.0%
  6. Legs 1 & 3
    0 vote(s)
    0.0%
  7. All 3!!
    32.0%
  1. Apr 13, 2013 at 7:31 PM
    #941
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I miss Tony. :pout:
  2. Apr 13, 2013 at 7:32 PM
    #942
    MTgirl
    Weesa
    Bob's secret mod lair
    Well then come to more MT meets! Tony has the 2nd best attendance record after me
  3. Apr 13, 2013 at 7:43 PM
    #943
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    LIES
  4. Apr 13, 2013 at 8:27 PM
    #944
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Of course you didn't..:facepalm:
  5. Apr 13, 2013 at 9:35 PM
    #945
    Digiratus
    Roaming the PNW
    The RedHead
    Oh stop
  6. Apr 14, 2013 at 12:45 AM
    #946
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    u're an idiot
  7. Apr 14, 2013 at 5:50 AM
    #947
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    *you're
  8. Apr 14, 2013 at 6:28 AM
    #948
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
  9. Apr 14, 2013 at 11:21 AM
    #949
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yep have seen that one. Should add it to the OP.
  10. Apr 14, 2013 at 1:02 PM
    #950
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    My bad. :p
    Does anyone have these or maxtrax?
  11. Apr 14, 2013 at 1:11 PM
    #951
    BradyT88
    BradyT88 Well-Known Member
    We all would like some, but no none of us have them. A little on the pricey side...
  12. Apr 14, 2013 at 1:12 PM
    #952
    MTgirl
    Weesa
    The XO guys were giving some away at their last premier party...I didn't win :pout:
    Maybe, if the next premier is before this trip, I can win some in time
  13. Apr 14, 2013 at 6:13 PM
    #953
    bigred07
    bigred07 Member
    Matthew
    Sierra Vista AZ
    05 offroad
    3 inch revtec lift, 285 75 16 bfg at's.
    Sounds good. If i can make I definitely will. I've been wanting to do something like this since I got my first truck, and 89 nissan pathfinder (still have it, typicaly just do small day rides when I get time, and dates!). But Ill have the tacoma with me at school, plus its more set up. How much are those sand tracks or whatever they're called anyway?
  14. Apr 14, 2013 at 6:15 PM
    #954
    Blackdawg
    Monte
    Wyoming/St. Louis
    Maxxtracks.
    About 240 a pair I think.
    I'd like some for this trip too..
  15. Apr 14, 2013 at 6:23 PM
    #955
    bigred07
    bigred07 Member
    Matthew
    Sierra Vista AZ
    05 offroad
    that's not too bad, less than a minimum wage part time job pay check.
  16. Apr 14, 2013 at 6:23 PM
    #956
    Blackdawg
    Monte
    Wyoming/St. Louis
    Or 3 tanks of gas...haha
  17. Apr 14, 2013 at 7:09 PM
    #957
    farmerjon
    farmerjon Hailing from the land of bucking broncos...
    farmerjon
    Rugged Rockies
    '98 4Runner SR5, 4WD, V6, 3.4L.
    ARB, sleeping platform, Husky liners.
    $240ish is three tanks of gas?? :eek:
    That's about 4 tanks of gas for me!
  18. Apr 14, 2013 at 7:11 PM
    #958
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well..idk. Maybe it is 4 haha
  19. Apr 14, 2013 at 9:16 PM
    #959
    Digiratus
    Roaming the PNW
    The RedHead
    240/3.55 (todays price)= 67.6 gallons. 67.6/4= 16.9 gallons.
    4 tanks=maxxtracs
  20. Apr 14, 2013 at 9:36 PM
    #960
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha well thanks..haha
