The favorite TW lift! The 3' inch Spacer lift!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Caperoots, Jul 27, 2011.
  1. Jul 28, 2011 at 12:17 PM
    #41
    Ronin
    Ronin iTaco
    Al
    Rockwall, Texas
    2008 Tacoma Sport 4x4
    low range leveling kit
    Pugga,
    I did not think of that.
    Thank you.
  2. Jul 28, 2011 at 12:39 PM
    #42
    93civEJ1
    93civEJ1 Well-Known Member
    09 DC TRD OR
    Procomp 6" Stage 1, Bilstein 5100's in front, flowmaster 40 series
    i think there needs to be clarification on this. The ones that preload are the ones that compress the springs...I dont see any issue on the ones that sit on top of the whole strut / coil housing??
  3. Jul 28, 2011 at 12:44 PM
    #43
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The ones that preload the spring do exactly what the 5100's do at settings higher than 0. It just preloads the spring, the amount of travel allowed by the strut does not change. The spacers that sit on top of the strut could potentially cause problems. If you bottom out the front end, the coil bottoms out before the lower control arm hits the bump stops. This forces the strut to take the shock of bottoming out rather than the rubber bump stop. If you do it hard enough, the strut can snap.
  4. Jul 28, 2011 at 1:05 PM
    #44
    bailerc
    bailerc Well-Known Member
    Cody
    Fayetteville, NC
    16' MGM Limited
    this thread scares me about running spacers... along with every other thread like this
  5. Jul 28, 2011 at 1:54 PM
    #45
    Bradw3451
    Bradw3451 Member
    Brad Wrubel
    Denver, CO
    I'm very new to the lifted truck scene and was originally thinking about going with the OME 3", UCA and Dakkar rear. With that said, if I'm only going to be on dirt roads from time to time and not wheeling would the above mentioned lift be safe? Also, would it be worth my time to add UCA's to this set up? Finally, would I be able to run 285's with minor trimming?
    Thanks for your help and sorry for all the questions.
  6. Jul 28, 2011 at 6:30 PM
    #46
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    safe for wheeling - YES
    Add UCA's - YES if set at 2.5" in the front
    285's - YES with trimming, and maybe body mount chop. (I'm getting my body mount chopped next week.)
  7. Jul 28, 2011 at 7:59 PM
    #47
    iRepLONGBEACH
    iRepLONGBEACH SoCal Reppin
    SoCal
    10 MgM dcsb TRD Sport
    spacers and blocks may been fine for awhile..its just the future you may have to worry about since u'll definitely fuck something up in the long run, well to my friends truck atleast. but your truck looks good OP!
  8. Jul 30, 2011 at 4:46 AM
    #48
    478jason01
    478jason01 Member
    ga
    03 prerunner sr5
    tint,spray n bedliner,nerf bars,bull bar,tool box,2 in lift,clear corner lights
    whats the difference in billys and spacers?your doing the same thing.preloading your coil spring.what type of shocks were broke in those pictures?
  9. Jul 30, 2011 at 5:00 AM
    #49
    98tacoma27
    Ben
    Not Beech Creek
    You may be doing the same thing, but they're not the same shock. One is designed for a lifted application, the other isn't.
  10. Jul 30, 2011 at 5:53 AM
    #50
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I've got a spacer lift for sale if anybody is interested.
  11. Jul 30, 2011 at 7:26 AM
    #51
    478jason01
    478jason01 Member
    ga
    03 prerunner sr5
    with a top spacer the shock travel should be the same.any time you raise or lower you could run into problems.
  12. Jul 30, 2011 at 7:44 AM
    #52
    478jason01
    478jason01 Member
    ga
    03 prerunner sr5
    if you look at the billys that broke they at the bottom of the shock has a long neck on it.this is the weak point.wouldnt blame the spacer its more the shock.
  13. Jul 30, 2011 at 8:01 AM
    #53
    478jason01
    478jason01 Member
    ga
    03 prerunner sr5
    can you point out the spacer in the picture cause i cant see it
  14. Jul 30, 2011 at 8:17 AM
    #54
    478jason01
    478jason01 Member
    ga
    03 prerunner sr5
    so we both agree its the billys not the spacer.thats awsome chevy man
  15. Jul 30, 2011 at 8:20 AM
    #55
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The spacer causes the shock to be effectivly lengthend. Thus it will break when over extended. All the shocks for the second gens are designed with the small extension on the bottom. Even aftermarket coilovers. It gives clearance for the sway bar.
  16. Jul 30, 2011 at 8:24 AM
    #56
    478jason01
    478jason01 Member
    ga
    03 prerunner sr5
    right.so its not so much a spacer problem.its these shocks and a spacer
  17. Jul 30, 2011 at 8:26 AM
    #57
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. Its the top plate spacers. Any shock with the top plate spacer will break.
  18. Jul 30, 2011 at 8:46 AM
    #58
    478jason01
    478jason01 Member
    ga
    03 prerunner sr5
    does anybody have pictures of other broken shocks besides this type.and this isnt the only shock that comes on tacomas.
  19. Jul 30, 2011 at 8:56 AM
    #59
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This is the only type of lift that causes this kind of breakage.
  20. Jul 30, 2011 at 8:56 AM
    #60
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Isn't it a bit strange that alot of the dealerships install spacer lifts on the brand new trucks on the lot and will back up the warrenty if a problem arises with them? You'd think if they were that bad it wouldn't be cost effective to install them. My dealership uses rev-tec spacers on the lifted trucks they sell and say as long as they don't go over 2 1/2" there's been very little issues. I'm guessing most of the trucks don't see much offroading. :confused:
