The feel of a first gen manual transmission?
Discussion in '1st Gen. Tacomas (1995-2004)' started by eon_blue, Apr 7, 2016.
  1. Apr 7, 2016 at 7:03 PM
    eon_blue
    eon_blue [OP] If I would, could you
    Azusa, CA
    Would you guys describe the first gen manual transmission as being kind of a "rough" shift?
    I don't know really how to describe it other than that it isn't smooth, certainly not as buttery smooth as my previous scion tC was (I don't expect it to be, it's a 12 year old truck) but I'm a little concerned that it might be an issue related to the transmission.
    It's more clunky, if that's a good way to describe it. I don't hear or feel any clunking coming from beneath me in the transmission, it's felt more in the shifter itself going from gear to gear. First to second, sometimes to third takes a bit of concentrated effort. I don't ever have to force it into gear, but at times it doesn't feel like I'm far off from having to do that.
    '04 4x4 5speed with 25k miles so the tranny is still a youngin' mileage-wise. Dealer did all the general maintenance prior to putting it up for sale, oil change and fluid check.
    I could just be over-thinking it but since I have no experience driving a manual Tacoma prior to this one, I wanted to get some opinions if I could.
    :burnrubber:
  2. Apr 7, 2016 at 7:06 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    An 04' with 25k ??? The whole truck or just trans ??.... you MAY be over thinking issue
    04tacoadobo likes this.
  3. Apr 7, 2016 at 7:07 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    But def. not a "rough" shifter
  4. Apr 7, 2016 at 7:08 PM
    eon_blue
    Azusa, CA
    Truck mileage is 25k....she's a unicorn
  5. Apr 7, 2016 at 7:10 PM
    eon_blue
    Azusa, CA
    I probably am....been driving manuals exclusively for the last 12 years but they've all been coupes, just getting used to the feel of the Tacoma. "Rough" is probably the wrong word.
  6. Apr 7, 2016 at 7:13 PM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    Lets see pics of this unicorn! And you could try replacing the shift bushing and replace the shifter ball with some oil on it, would help!
    MasterYota1992 and eon_blue[OP] like this.
  7. Apr 7, 2016 at 7:13 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Probably is since your comparing it to cars w/manual trans you've had... Now a "hard" shifter would be my old 72' power wagon....haha
    Chinle and eon_blue[QUOTED][OP] like this.
  8. Apr 7, 2016 at 7:17 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    This is a pretty good idea, check all points of connection shift linkage wise & replace hardware as necessary..
  9. Apr 7, 2016 at 7:17 PM
    eon_blue
    Azusa, CA
  10. Apr 7, 2016 at 7:19 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    I had a 2000 tacoma that was a 5-speed. Having driven other manual vehicles (cars, not trucks), the transmission on the Tacoma was certainly more "notchy" feeling. A fluid swap for a GL-4 fluid, such as Redline MT might be in order. I did that and it helped smooth things out nicely. Though, to be fair, I had far more miles on my truck than 25k haha!
    EDIT: Congrats on the truck, by the way! Awesome rig. I read through your other thread...
    eon_blue[OP] likes this.
  11. Apr 7, 2016 at 7:25 PM
    2stroketrush
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    WOW what a beautiful truck, I would venture to say one of the lowest mile first gens on the site. And all the right add ons! And yeah looks like your rubbing on your pinch weld weld you turn, new struts would fix this, but add lift. If your really really worried about it take it to a shop and add a 10mm spacer to the top plate. Cheap no hassle problem solved.
  12. Apr 7, 2016 at 7:26 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Kinda notchy but very solid, you know when your in gear.
  13. Apr 7, 2016 at 7:30 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I went from a Tc to a manual taco. It's most likely just the transition between car and truck tranny. I was wondering the same thing on a brand new 15!
  14. Apr 7, 2016 at 8:15 PM
    eon_blue
    Azusa, CA
    Thanks! Yeah I believe the pinch weld is what it's called, it's the flimsy, plastic "flap" part inside the wheel well. When I make a hard turn the tire pushes past that and makes a real loud rubbing sound; sound a lot worse than it is lol.
    I was thinking for the time being I might just trim that part back, it's not visible from the outside anyway. A lift is definitely in the future, but not for awhile
  15. Apr 7, 2016 at 8:27 PM
    Madjik_Man
    Colorado Front Range
    25,000 miles?
    I hate you already.
    My manual has always been a bit notchy, but nothing "rough" ever.
    I might switch back to Toyota recommended tranny fluid. I hear it's thicker than synthetics and it might help with the notchiness.
  16. Apr 8, 2016 at 6:03 AM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    Redline MT 90 - trans fluid. I found it made a very big improvement in shifting. Much more smooooooth.....
    nh_yota and JPinFL like this.
  17. Apr 8, 2016 at 6:11 AM
    Madjik_Man
    That's what I'm running now.
    Made a little difference at first and now, over time, it's feeling pretty notchy.
  18. Apr 8, 2016 at 8:55 AM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    have you checked your clutch fluid level
  19. Apr 8, 2016 at 8:57 AM
    Speedytech7
    I've had a similar experience with it. It still goes into first and second better when cold which is nice. But the overall feel of all the gears has remained notchy.
  20. Apr 8, 2016 at 9:10 AM
    Tacomang
    Tacomang Well-Known Member
    Norcal
    Trd Taco
    Mine shifts like butter... strange /shrug
    Notchy was my jdm spec c 6speed in the wrx. Do you have decent clutch travel? Maybe youre shifting too fast remember we have hydraulic clutches they are going to feel different than a brand new coupe.
