The Fellowship of PNW Tacomas | PDX Area Wheeling
Discussion in 'North West' started by C41n, Feb 5, 2020.
  1. Feb 22, 2021 at 7:47 PM
    #2581
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    So you essentially get the roof support already built in, and a way to secure things down. Sounds like you are set!
  2. Feb 22, 2021 at 7:49 PM
    #2582
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    Sorry. I thought you were referring to additional weight support. Yes, I have that being installed. Thanks.
  3. Feb 22, 2021 at 7:50 PM
    #2583
    TacoTim85
    TacoTim85 Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    Nah dude. I'm laughing at the mumbled comment at the end.
    Superhulk LB[QUOTED] likes this.
  4. Feb 22, 2021 at 7:52 PM
    #2584
    C41n
    C41n [OP] KDMax Pro Authorized Tuner | Portland, OR
    Anthony
    Portland, OR
    2020 DCSB OR MT
    I sealed the front of my bed with butyl tape. Closed up the gaps up there. I would hope that if you bought new the canopy dealer would do that for you. I bought mine used, so I did it myself. Don't have any pictures of that right now.
    Haven't had any leaks in the front. The rear was another story. I sealed up the openings around the cubby and light locations. Pictures here:
    https://www.tacomaworld.com/threads/gandalf-da-grey-slow-build.679736/#post-23943852
    Only place I get leaks now is right by the rear canopy window. There are some gaps at each side. Haven't fixed those yet. Everything else I did worked great though.
    FashTaco, TacoTim85 and Superhulk LB like this.
  5. Feb 22, 2021 at 7:53 PM
    #2585
    Superhulk LB
    Josh
    Oregon
    Thanks. I just saw you have a canopy now. Looks good!
    C41n[QUOTED][OP] likes this.
  6. Feb 22, 2021 at 8:11 PM
    #2586
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Back when I bought my 1997 Taco new, I immediately ordered a paint matched Leer canopy.
    Had that on from 1997 till about 2008. Killed a set of shocks over that span.
    And all the while owning it, I came to realize that nothing under the canopy was secure, as anyone could easily just use a large screw driver or crowbar and pry the rear door open, drop the tailgate and take it. So I gave it away.
    When I was looking at bed covering options for my 2017 Taco (prior to purchasing it), I found the SoftTopper idea. Wasn't entirely sure what I was going to do regarding having support above it to carry my kayaks, but figured I would just make a rack when I had the truck and topper in my posession.
    Went through about a year and a half designing the rack in my head and finally settled on aluminum for being light and don't have to paint it.
    My stuff that I keep back there now is no more or less secure than my heavy Leer canopy on my 1997. Not sure what your new canopy weighs but my old Leer was 150+ lbs and not designed to support any loads on top.
    My Soft Topper is 16lbs, my aluminum rack is 26lbs, and my ARB awning is about 25lbs. The rack has the Yakima tracks on top for modularity of cargo install. No idea what my rack could be rated to, but I've had nearly 600lbs static load in top of the rack and it didn't flinch a bit. The most I would ever have secured up there would be a RTT (130lb - 200lbs).
    I chose this combo for several reasons. It is super light, yet super strong. I can change up how I run the Soft Topper....ie closed up, safari style, completely removed with just the rack in place, just the Soft topper without rack, or nether.
    I can remove the ST in minutes by myself and stow in the bed folded down, or in the garage. I can also remove and install the rack myself and stow in the garage in minutes.
    I learned a lot with my heavy Leer canopy as to my limitations of install and removal. I only removed it twice over all the years I had it. Once to replace the foam gasket seal along the bed rails and once to get rid of it.
    I've taken my ST and rack on and off several times in the short time I've had them.
    This combo really has no affect on my rear spring load capacity as they are. This has worked out awesomerly (<----new word ) over my previous Leer experience.
  7. Feb 22, 2021 at 8:15 PM
    #2587
    CascadianAngler
    CascadianAngler Send It & Mend It
    Brad
    Washington
    2018 DCLB
    I’m going with butyl this time around. I took mine in a month after install and they tried caulking again. A moth later I called and they said to bring it in again (that was the damn Tacoma’s) comment. At that point I didn’t want to drive a half hour to get the same result.
    After I did some silicone myself I got it down to a very, very small leak in just the two front corners (that’s only place I’ve ever had water come in). I also drilled a small relief hole in each corner, the Toyota bed mat covers them but pooled up water can escape.
    I feel like the occasional person that gets their canopy 100% waterproof is lucky (or very patient & skilled)
    FashTaco, .劉煒 and Superhulk LB like this.
  8. Feb 22, 2021 at 8:21 PM
    #2588
    Superhulk LB
    Josh
    Oregon
    Thanks guys for the advise!
  9. Feb 22, 2021 at 8:21 PM
    #2589
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    Wouldn’t a locking tailgate have solved that whole dilemma? I installed a pop and lock with my wedge camper for the same reason.
    FashTaco likes this.
  10. Feb 22, 2021 at 8:28 PM
    #2590
    C41n
    Anthony
    Portland, OR
    2020 DCSB OR MT
    I just looked and I cannot find any pics of my butyl sealing unfortunately. I used a lot up front, too much I thought. The black trim on the front of the bed sat a bit higher than the sides when I was done. Thought it might be a problem. Worked out well though. Frankly amazed how well it worked. Wish I could find the pics..
    Superhulk LB likes this.
  11. Feb 22, 2021 at 8:31 PM
    #2591
    TacoTim85
    Sounds like you did it right. Haha. For reference, the bulkhead of my bed sits slightly higher than the bed sides (stock).
  12. Feb 22, 2021 at 8:33 PM
    #2592
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    On the fiberglass canopies a locking tailgate won't stop a crowbar from opening the rear hatch very easily. Granted, with a locking tailgate, they now have to climb over the gate to retrieve stuff.
    On a metal canopy that has better structure in the rear hatch above the tailgate, prying it open might be much harder to do.
    Back before 2008, I don't recall there being a locking tailgate retrofit available for the 1st gen.
    FashTaco and C41n[OP] like this.
  13. Feb 22, 2021 at 9:31 PM
    #2593
    TacoTim85
    Look what the mail lady brought today.
  14. Feb 22, 2021 at 9:38 PM
    #2594
    CascadianAngler
    Brad
    Washington
    2018 DCLB
    I have some At The Helms too! They are quality for sure. Going to paint them up when I paint my sliders and get them slapped in before reinstalling the topper.
  15. Feb 22, 2021 at 9:39 PM
    #2595
    TacoTim85
    I blame @FashTaco for this one.
  16. Feb 22, 2021 at 10:00 PM
    #2596
    .劉煒
    .劉煒 Well-Known Member
    2016 Inferno DCSBTRDORMT
    All locks only stop honest people, tbh.
    Astr0Aar0n likes this.
  17. Feb 22, 2021 at 10:26 PM
    #2597
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Exactly!
    I had no expectations of actual security with my Leer canopy with a non locking tailgate. And I still have no expectation of actual security with a Soft Topper and a locking tailgate.
    I just maintained a huge amount of available cargo weight capacity all while having an easy to configure, remove and install over the bed covering that can support equal or more weight than a traditional fiberglass reinforced canopy.
    I fully realize and respect that my setup may or may not fit the look or function for everyone. Nor would it be financially fiscal to have to purchase a fully welded aluminum rack. Can't even imagine what that would cost. :eek:
    The ST is costly enough for basically a bimini.
    What does one of these ARE canopies run price wise nowadays? My Leer was about $800 back in 1997.
  18. Feb 22, 2021 at 10:31 PM
    #2598
    gpdx
    gpdx Well-Known Member
    Portland
    13 DCSB TRD Offroad
    5100/887, topper, rack, 265/75/16
    Did you run butyl on the seam on the outside?
    I’m getting a slight leak in the front corners. I can see a little daylight when I’m in the topper. I tried getting some silicone in the gaps from the inside. It slowed the leaks a little.
    But strips of butyl sound like a good addition. Better than removing the whole thing and trying to re seal.
  19. Feb 22, 2021 at 11:25 PM
    #2599
    C41n
    Anthony
    Portland, OR
    2020 DCSB OR MT
    Under the black trim and filled the gaps. I cannot see any light from inside. It didn't look so great before the topper was on there. Now I never notice.
    Those gaps are a big part of the problem so many people have getting a seal up front.
    FashTaco and gpdx[QUOTED] like this.
  20. Feb 22, 2021 at 11:38 PM
    #2600
    .劉煒
    IIRC the ARE on my rig was about 1500 (2016)
