The Fellowship of PNW Tacomas | PDX Area Wheeling
Discussion in 'North West' started by C41n, Feb 5, 2020.
  1. Feb 23, 2021 at 7:06 PM
    #2621
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Spot on!
    What is really nice is having options, and lots of them with Tacomas. Try that with the Honda "van/truck" thingy called the Ridgeline. :facepalm:
  2. Feb 23, 2021 at 7:07 PM
    #2622
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    That's not horrible. :cheers:
  3. Feb 23, 2021 at 7:18 PM
    #2623
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Speaking of sliders....
    I have a Protools HD manual tube bender with a few dies I've used for building sandrail and baja bug cages with. I will be ordering another die soon that I can bend 1.75" tube with so I can build myself some sliders with.
    To offset the cost of the die, I may offer up some limited prep work for anyone in the PNW that likes to fabricate, but doesn't have or need to purchase a tube bender, but would like to design and build their own sliders.
    What I was thinking, is sourcing some mild steel 1.75" DOM tube and bend to spec what you need to trim down and build your own sliders from.
    This would be a really economic way to build your own sliders. All the other parts are plate and straight pieces of round or square tube.
    So if you have or have access to some fabrication tools but not a bender, this might be of help to you.
    Again, I am just tossing this around right now as an idea and have no plans to start a business. I just like to have my tools pay for themselves over time.
  4. Feb 23, 2021 at 7:27 PM
    #2624
    .劉煒
    .劉煒 Well-Known Member
    2016 Inferno DCSBTRDORMT
    Worse if you've got antennas and awnings and shit on yours. Unless, obv, you take the time to unbolt everything in which case it's just a pain, not an off balance pain. :p
  5. Feb 23, 2021 at 7:39 PM
    #2625
    Astr0Aar0n
    Astr0Aar0n Well-Known Member
    Portland, OR
    19' Tacoma TRD OR V6 4x4 DCSB cavalry blue
    Quite a few things at this point..
    Got the new wheels and tires on, even took them out to dirty them up! 255/85r16 Yokohama Geolandar M/T G003's (skinny 33's, these measure 33.2"). Loving it :D
  6. Feb 23, 2021 at 7:44 PM
    #2626
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    You can build some horses that are a few inches taller than your bedside rails. Then unbolt everything and get in an pop the grip on current seals.
    Lift the front side and have someone slide a 2x4 in and across the bed rail, and then set the canopy front back down on it. Do the same for the rear end.
    Move your horses into position and lift the 2x4s on the front and slide your horses under the 2x4s. Repeat on the rear. Carefully drive out from under the canopy.
    The other option I've seen done is to back another Tacoma up straight behind the one getting new seals. Do the 2x4 thing to support the canopy on. Then with 4 dudes, walk the canopy back and temporarily stage it on the other truck rails while getting the new seals in place on the original truck.
    .劉煒[QUOTED] and C41n[OP] like this.
  7. Feb 23, 2021 at 7:46 PM
    #2627
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Go skinnies!
    :101010::mudding:
    C41n[OP] and Astr0Aar0n[QUOTED] like this.
  8. Feb 23, 2021 at 7:50 PM
    #2628
    CascadianAngler
    CascadianAngler Send It & Mend It
    Brad
    Washington
    2018 DCLB
    Looks awesome man!
    Astr0Aar0n[QUOTED] likes this.
  9. Feb 23, 2021 at 9:22 PM
    #2629
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    Nice man!
  10. Feb 24, 2021 at 8:41 AM
    #2630
    astonb86
    astonb86 Well-Known Member
    Aston
    2011 Tacoma TRD Off-Road
    Those look slick!
    I was torn on buying the Geolanders or a new set of Toyo Open Country ATIII, ultimately the price and the fact that I previously owned the Toyos made my decision. The Geolander looks very aggressive. I like the sidewalls.
  11. Feb 24, 2021 at 9:06 AM
    #2631
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    kinda apples and oranges there. One is a MT and the other is an AT.
    Astr0Aar0n likes this.
  12. Feb 24, 2021 at 9:13 AM
    #2632
    astonb86
    Aston
    True. I was looking at the ATs in both. I primary drive highway. I was just saying I was considering the Geolanders as well.
    Superhulk LB and Astr0Aar0n like this.
  13. Feb 24, 2021 at 9:21 AM
    #2633
    Astr0Aar0n
    Portland, OR
    I decided to go MT this time for a couple reasons, 1) PNW is mostly wet and muddy out on trails 9 months of the year (This is my DD but I do a lot of adventuring), 2) Kind of forced with the 255/85r16 options all being MT's and no ATs :rofl:
  14. Feb 24, 2021 at 10:30 AM
    #2634
    dabbinuguay
    dabbinuguay Well-Known Member
    PDX, Oregon
    2017 Tacoma TRD OR DCSB
    Cooper ST Maxx is the only AT available in that size that I have considered, and having CMC done for 285's is pretty cheap compared to most of our other accessories.
    I've been on the fence about going to 33's. Still on the fence about 255 vs 285 if I ever do. I'd probably want to regear to 4.88 if so.
    I'm on dirt or snow as much as possible, but it's still a ton of highway driving to get to where I want to be.
    I'd be curious as to what your studies show with regards to pavement performance and MPG.
  15. Feb 24, 2021 at 11:35 AM
    #2635
    Astr0Aar0n
    Portland, OR
    I was on the fence for a long time too between 255 and 285. My final deciding point was mostly for the experimentation and science I'll get to do knowing most my Taco friends run 285 33s. I'm a physicist/engineer so I love this shit lol, especially when I get to do it with a hobby of mine. I'll definitely be keeping track of data and writing something up after I get some good mileage down on them.
    FashTaco and TimberTiger like this.
  16. Feb 24, 2021 at 7:11 PM
    #2636
    .劉煒
    Yeah. I think I'm gonna need to rig some 2x4s and build something and just use a floor jack to raise it up a bit.
  17. Feb 24, 2021 at 7:25 PM
    #2637
    Superhulk LB
    Josh
    Oregon
    Anyone know if Triangulation Point is accessible this time a year? I’ve never been and need to get out and about.
    lightnfast, Astr0Aar0n and TacoTim85 like this.
  18. Feb 24, 2021 at 7:40 PM
    #2638
    Toywoodsguy82
    Toywoodsguy82 Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
  19. Feb 24, 2021 at 7:47 PM
    #2639
    Superhulk LB
    Josh
    Oregon
  20. Feb 24, 2021 at 7:50 PM
    #2640
    C41n
    C41n [OP] KDMax Pro Authorized Tuner | Portland, OR
    Anthony
    Portland, OR
    2020 DCSB OR MT
    Made it almost all the way there this past week. Ironically turned around because of a fallen tree. Not much snow. If you can clear the tree you shouldn't have a problem making it there.
