The Fellowship of PNW Tacomas | PDX Area Wheeling
Discussion in 'North West' started by C41n, Feb 5, 2020.
  1. Oct 13, 2020 at 7:57 PM
    #1221
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    I’m looking into them now. Well more like the last year, but now it’s going to happen.
  2. Oct 13, 2020 at 8:02 PM
    #1222
    Nito
    Nito Well-Known Member
    Portland, OR
    ‘20 Cement Off-road DCLB
    Is there information out there regarding airing down? What my wheels/tires can handle. I used the search function but couldn’t find specific numbers.
    I’m on 2020 Tacoma pro wheels and 275/65/16 wildpeaks.
  3. Oct 13, 2020 at 8:10 PM
    #1223
    Superhulk LB
    Josh
    Oregon
    I’m sure there is something more scientific out there; but you should be okay down to around 15lbs for slower speed off roading.
    Nito[QUOTED] and .劉煒 like this.
  4. Oct 13, 2020 at 8:12 PM
    #1224
    .劉煒
    .劉煒 Well-Known Member
    2016 Inferno DCSBTRDORMT
    How comfortable are you with fixing a bead that went out of place?
    MFGs have minimums for a reason, so... going beyond that is 'at your own risk'.
    https://www.discounttire.com/blog/airing-tires-down and https://www.treadmagazine.com/how-tos/airing-down-and-back/ looks like useful, though.
    But the lower you go, the more careful you ought to be about losing a bead.
    Nito[QUOTED] and Superhulk LB like this.
  5. Oct 13, 2020 at 8:14 PM
    #1225
    .劉煒
    Yeah. My pucker goes way up past 20psi, I normally run at road (30-35) unless I'm starting to slip or other issues.
  6. Oct 13, 2020 at 8:20 PM
    #1226
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    The answer to this question is always yes
    TacoTim85[QUOTED] likes this.
  7. Oct 13, 2020 at 8:20 PM
    #1227
    Superhulk LB
    Josh
    Oregon
    True!
  8. Oct 13, 2020 at 8:21 PM
    #1228
    El Duderino
    Jeremy
    HI->PNW
    Oregon makes a great set up for an battery operated one.
    .劉煒 and Superhulk LB[QUOTED] like this.
  9. Oct 13, 2020 at 8:21 PM
    #1229
    Superhulk LB
    Josh
    Oregon
    YES!
  10. Oct 13, 2020 at 8:26 PM
    #1230
    Hiker trash
    Hiker trash Happy Trails
    Shane
    Oregon
    2018 TRD OR DCSB Quicksand MT
    simple things for now
    let me know. Live over near the Hillsboro area but travel is always fun
  11. Oct 13, 2020 at 8:26 PM
    #1231
    Superhulk LB
    Josh
    Oregon
    El Duderino[QUOTED] likes this.
  12. Oct 13, 2020 at 8:30 PM
    #1232
    Toywoodsguy82
    Toywoodsguy82 Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    El Duderino likes this.
  13. Oct 13, 2020 at 8:34 PM
    #1233
    El Duderino
    Jeremy
    HI->PNW
    Superhulk LB[QUOTED] likes this.
  14. Oct 13, 2020 at 8:36 PM
    #1234
    Superhulk LB
    Josh
    Oregon
    Well that makes it spendy:spending:
  15. Oct 13, 2020 at 8:36 PM
    #1235
    Toywoodsguy82
    Patrick
    Oregon
    less having to recharge...
  16. Oct 13, 2020 at 8:43 PM
    #1236
    Superhulk LB
    Josh
    Oregon
    That’s important.
  17. Oct 13, 2020 at 8:57 PM
    #1237
    Nito
    Portland, OR
    Thanks. I’ll read up on this. I was planning on 20 just because I didn’t want to deal with fixing a bead al I’d rather avoid it altogether. Have only seen how to videos.
    thanks for the quick answers. @.劉煒 and @Superhulk LB
  18. Oct 13, 2020 at 9:19 PM
    #1238
    Superhulk LB
    Josh
    Oregon
    I’m lazy, so 19-20 is about as low as I go. That’s with a 10ply tire. Makes a nice ride and good traction.
    Nito[QUOTED] likes this.
  19. Oct 14, 2020 at 1:14 AM
    #1239
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    You'd be surprised how low you can actually go on your pressures when you need to go lower to get unstuck. If you are smart about your driving, and not rely on just generic "settings" that you read about, you can travel on full highway pressures all the way down to just about flat. The limitations are ride quality felt in the cab, required traction, and side loads applied to the tire.
    Example:
    In sand, I don't care what the tire pressure is for a given tire. My rule of tire deflation works like this. While still on a hard surface (or parked on a piece of plywood, MaxTrax, or even floor mat), measure the distance that the lowest part of the wheel is from the actual ground. Say it is 6". Now, deflate the tire until you have decreased this distance by 25%, so now your rim is 4.5" off the ground. This will increase your foot print by 200% per tire. Depending on what you are loaded down with (or not), the contact patch will be the same, but the pressure may very well be completely different between all 4 tires.
    So, if you just pick 20psi for all 4 tires, your tires could effectively all have a different contact patch completely dependant on the weight that the tire is carrying. You may actually need to air down much further in the rear if the truck is completely unloaded. Where as you may have to air down much less if your rear cargo is getting close to or more than what the fronts are seeing.
    With that, each tire brand, height, width, and wheel size will give you a completely different contact patch at a given % of deflation than a different tire/wheel combo. So, going with a prescribed "just lower it to 20psi and you're good", may work but won't be as optimal as just taking each of YOUR tires down by rim to ground %. You can experiment with what % you like on various terrain. 25% is my goto for soft sand. 10-15% works for me on washboard roads. I don't rock crawl, but I would guess it could be 20-25%.
    pdxtrdtaco1874 likes this.
  20. Oct 14, 2020 at 5:20 AM
    #1240
    Toywoodsguy82
    Patrick
    Oregon
    Never have I had to fix a bead but the lowest I’ve been is 15
