The Fellowship of PNW Tacomas | PDX Area Wheeling
Discussion in 'North West' started by C41n, Feb 5, 2020.
  1. Dec 14, 2020 at 10:23 PM
    #1841
    dclbYak
    dclbYak Well-Known Member
    19ssmDCLBtrdOR
    FashTaco, Superhulk LB and bryflies like this.
  2. Dec 14, 2020 at 10:34 PM
    #1842
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    An solid air compressor is one of best investments for off roading. Took me years to really figure that out.
    NW-Taco, FashTaco, Astr0Aar0n and 2 others like this.
  3. Dec 15, 2020 at 7:33 AM
    #1843
    lightnfast
    lightnfast Well-Known Member
    PDX
    2001 TRD SR5 XCLB
    Stuff and things
    GMRS here.
    Astr0Aar0n likes this.
  4. Dec 15, 2020 at 7:43 AM
    #1844
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    I recently went through this question myself. Asked around a bit and found that GMRS is the primary form of communication with HAM and CB a close second each for different reasons.
    With that, I decided on the Midland MXT275 for my truck, and for smaller FRS/GMRS handheld units for when out of the truck.
    I want to completely hide the head unit remotely inside the innards of my center console, or under the rear seats somewhere. Then have a flush mount plug in jack for the Mic somewhere upfront.
    Should be fun.
    Astr0Aar0n and Toywoodsguy82 like this.
  5. Dec 15, 2020 at 9:07 AM
    #1845
    Astr0Aar0n
    Astr0Aar0n Well-Known Member
    Portland, OR
    19' Tacoma TRD OR V6 4x4 DCSB cavalry blue
    Quite a few things at this point..
    Only reason I didn't go this route was the extra cost over handhelds and extra work to install. And don't you have to purchase an antenna? With my handhelds, I put a metal piece on the back so it can go on my magnetic mount when out adventuring with others.
    FashTaco and TacoTim85 like this.
  6. Dec 15, 2020 at 9:29 AM
    #1846
    TacoTim85
    TacoTim85 Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    I really need to do this. :rolleyes:
  7. Dec 15, 2020 at 9:33 AM
    #1847
    Toywoodsguy82
    Toywoodsguy82 Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    @Superhulk LB do you have an antenna for your radio? If so where is it mounted... if not that radio check that we did in Portland seems even better
  8. Dec 15, 2020 at 9:41 AM
    #1848
    Superhulk LB
    Josh
    Oregon
    It came with a tiny antenna, I have it on the roof. It’s magnetic. Probably figure a better option at some point and maybe a larger antenna, but it works for now.
    One thing to keep in mind is, I still needed a handheld when I jumped out to help spot the few times.
  9. Dec 15, 2020 at 9:42 AM
    #1849
    Superhulk LB
    Josh
    Oregon
  10. Dec 15, 2020 at 9:51 AM
    #1850
    Astr0Aar0n
    Portland, OR
    That right there is another reason I chose handheld, I use my radios outside of my vehicle often too, spotting, hiking, camping, etc.
  11. Dec 15, 2020 at 5:25 PM
    #1851
    NW-Taco
    NW-Taco Well-Known Member
    Josh
    Oregon City
    2020 Ram Power wagon
    Had to sell my 17 Tacoma for a tow rig in order to pull my new home. Still here for a bit to keep in touch.
    Im just a gadget geek that likes to tinker. So I'm going with the midland micro-mobile and the larger "32 inch" 6dB midland antenna. Tucking the head unit away, and mounting the antenna at the rear of the bed. Cause you know, chicks dig a guy with a big antenna. And since learning my talkabout died, Im going to grab the 50 channel midland handhelds for spotting and spares.
  12. Dec 15, 2020 at 7:31 PM
    #1852
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    The Midland did come with a small antenna (I think magnetic). However, I did go ahead and purchase the 6dB gain whip and the lip mount. I was also going to grab the tiny 3dB dong as well, but they were out of stock at the time.
    I'm probably going to weld a corner gusset somewhere in the front area of my aluminum bed rack to attach the lip mount to. It's designed to clamp on to the hood up below the front windshield, but it will be easy peasy to just run the antenna cable from either the center console, or from under the rear seats, out a body grommet under the cab, and up between the cab and bed to the rack. I already have fused (red and black 10awg wire) 12v power routed from the battery to under the rear passenger seat to an ARB fridge plug. I put a junction terminal there so I can easily add additional low power items. Just need to get a Mic remote mount cable.
  13. Dec 15, 2020 at 8:03 PM
    #1853
    TheOnlyPajooned
    TheOnlyPajooned Well-Known Member
    Don
    The 'Couve, WA
    2012 DCLB Sport
    she got big shoes bro
    So I tried to look over the site to determine where I should drop my first post...
    A pack of nerds with tacos that advertise as noob friendly - sounds like my kinda group :D
    So hello, I am brand new to TacomaWorld (minus some lurking for a while) and I bought my Tacoma about 3 months ago; it's a lovely red 2nd gen TRD sport with a lift that came with the truck from the dealer; she's Canadian; but not a spot of rust on her belly, so I'm happy!
    I live and work in Vancouver, WA and I'm really hoping to get some mods going, and some overlanding trips.
    I read this blog recently: https://www.trailsoffroad.com/blog/overlanding-across-washington and it has got me REALLY itching for some adventure... COVID hasn't helped with this itch at all either hahaha
    Anyways, I work at a bank, so typical banker hours 9-5 m-f with the semi-frequent saturday rotation.
    I'm an extrovert at the core and love to hang out, whether its for games, food or adventures!
    I would enjoy nothing less than to make some new friends and some new experiences :)
    EDIT: I've attached an image of my taco
    YF_Ryan, AH09, C41n[OP] and 10 others like this.
  14. Dec 15, 2020 at 8:13 PM
    #1854
    503MIKE
    503MIKE Well-Known Member
    Oregon
    2021 AG TRAIL
    Hey I’m Mike. Born and raised in Portland, moved down to Salem a few years ago but I’ll definitely try and make it to a PDX meet. Sold my 09 a few years ago and just picked this beauty up last Friday. 79C0133F-59E2-4676-A130-F9A3479E400A.jpg
    AH09, C41n[OP], redsloth and 10 others like this.
  15. Dec 15, 2020 at 8:16 PM
    #1855
    TheOnlyPajooned
    Don
    The 'Couve, WA
    2012 DCLB Sport
    Hi Mike!
    I love the green man, looks really nice! I'm glad Toyota is offering some different colors :)
  16. Dec 15, 2020 at 8:27 PM
    #1856
    Superhulk LB
    Josh
    Oregon
    Hey welcome guys! Nice trucks!
    Hang here enough and you will find some play days. Lots to explore in the PNW and these trucks are awesome!
    FashTaco likes this.
  17. Dec 15, 2020 at 8:29 PM
    #1857
    TacoTim85
    Welcome in and congrats on the recently purchased Tacos.
  18. Dec 15, 2020 at 8:36 PM
    #1858
    TheOnlyPajooned
    Don
    The 'Couve, WA
    2012 DCLB Sport
    Thanks guys! I have a small handful of mod ideas in mind, but wife keeps me grounded and asks that I don't sell the house to trick out the truck :D
    That said, I've got some rock sliders/steps arriving Dec 24th, cannot wait to get them put on, gonna look slick imo
  19. Dec 15, 2020 at 9:04 PM
    #1859
    .劉煒
    .劉煒 Well-Known Member
    2016 Inferno DCSBTRDORMT
    The army green looks pretty nice.
    FashTaco, 503MIKE and Superhulk LB like this.
  20. Dec 15, 2020 at 9:06 PM
    #1860
    Superhulk LB
    Josh
    Oregon
    The color is sure growing on me...makes me wish I had waited a few more years.
    503MIKE likes this.
