THE FEW THE PROUD THE SASed
Discussion in 'Solid Axle Suspension' started by 802YOTA, May 25, 2012.
  1. May 25, 2012 at 10:04 PM
    802YOTA
    802YOTA [OP] Well-Known Member
    Scotty
    Vermont
    03 Tacoma SR5 TRD
    LEAF SPRUNG SAS, 5" inch springs 5" shackles. Tacoma HIGH STEER, CHERRY BOMB 3" Straight pipe, TRIPLE CASES, 5.29s, (yeah she crawls) LOCKED FRONT AND REAR, Custom square stock front driveshaft 13" slip(been there for a year and hasnt failed yet.), Ruff Stuff 8 inch Perches, 2" RB body lift, K&N intake, Zoom high performance Kevlar clutch, herculined flares and rockers, trail gear rock sliders, rock lights.
    Its been awhile since i've been on here. But heres some stats. 03 Tacoma ext TRD. Elocker. Welded front. 5.29s, Triple Transfers, SASed, 5 inch springs 5 inch shackles, 2 in body, 39.5 13.5 15 IROK bias (no I dont rub) (nope not at all) Check her out i like it alot.
  2. May 25, 2012 at 10:15 PM
    802YOTA
    Scotty
    Vermont
    03 Tacoma SR5 TRD
    BY THE WAY ITS BUILT NOT BOUGHT. I did all the work myself. Its not hard. You will learn how to weld real fuckin fast if you take on a job like this.
  3. May 26, 2012 at 6:48 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    More than likely a D44, looks good. It's SAS, rubbing should be out of the question. IFS rubs cuz its retarded and pushed so far back into the FW
  4. May 28, 2012 at 12:27 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    yes
  5. May 28, 2012 at 12:38 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    CO
    2011 Mall Crawler/84'
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Sick truck!
  6. Jun 1, 2012 at 8:06 AM
    awsumdc
    awsumdc Well-Known Member
    O.C. Cali
    SASED '05 Taco
    SAS, crawler box, 14" coilover shocks, 39.5 tires,dual batteries, and a bunch of other stuff
    Nice job.
  7. Jun 5, 2012 at 9:24 PM
    randombob
    randombob Well-Known Member
    Eureka, CA
    2013 TRD OR
    stuffs
    Hoe much trimming in the rear to bring up 39's with no rub??
    I had to muck around the front of the rear wheel wells and still rub a hair with 37's
  8. Jun 7, 2012 at 12:44 PM
    802YOTA
    Scotty
    Vermont
    03 Tacoma SR5 TRD
    No trimming
  9. Jun 7, 2012 at 3:57 PM
    Supra TT
    Eric
    Indiana
    No trimming? You aren't wheeling hard enough. I rubbed on 37's out the ass.
  10. Jun 8, 2012 at 11:29 AM
    802YOTA
    Scotty
    Vermont
    03 Tacoma SR5 TRD
    I know if gonna get burned for this. But I got a 2" bl. But whatever. I have rubbed last weekend front and rear but not enough to start hacking shit up.
  11. Jun 8, 2012 at 11:32 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    what the fuck?
