The Flashlight Nerd Thread
Discussion in 'Off-Topic Discussion' started by KB Voodoo, Oct 14, 2015.
  1. Oct 23, 2015 at 6:36 AM
    #81
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    I have the original 3 emitter version. since it came out, all sorts of clones came out.
    it is in the cheap chinese junk category so all bets are off on what you get with this.
    but I have the first version, and almost immediately clones appeared (or is mine a clone no one knows)
    a) it's fuggin bright on max, starts on max, untwist it to kill power (anodized)
    so I like that feature (no standby current when untwisted)
    b) on 300 lumens it whines a bit (cheap pwm)
    c) it drains batteries pretty quick on high. but it does light up a huge huge space
    I just keep it in the kitchen if the power goes out or there
    is a boogeyman about I'll grab it. otherwise I use the quark mini in the kitchen
  2. Oct 23, 2015 at 6:59 AM
    #82
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    If I was @addicus24 I'd get two of these: http://www.ebay.com/itm/201423820117?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
    #82
  3. Oct 23, 2015 at 7:04 AM
    #83
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    From the other Flashlight thread my EC20
    And my 2D Mag
  4. Oct 23, 2015 at 7:28 AM
    #84
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    with many smaller reflectors, you get more flood than throw
    also 15000 lumens is not possible in a 9xml, 4x18650 light unless you use IMR cells
    I am of the belief that the 4x18650, 3 xml is about the best combo. the three xml's
    can all be driven hard and you get decent throw since the reflectors are bigger. adding more emitters yet keeping
    the same 4x18650 you get diminishing returns and flatter and flatter reflectors
    [also...my sky ray 3 emitter is a real measured 2186 lumens]
    from BLF on skyray 4x18650
    3 led you get 7.5 / 3 = 2.5 amp per emitter
    4 led = 1.9 amp per emitter
    6 led = 1.25 amp per emitter
    If you look at the Cree data sheets most leds are more efficient at lower currents. This means in total more LEDs while they will have more losses (more wire, etc).
    Should in theory produce more lumens in total. It certainly won’t be less. Not at this number of LEDs anyhow. Driving the emitters less hard will also produce less heat. So you’ll probably get a more stable output assuming your batteries are up to the task. that is the issue, 4x18650 pushing 9 leds...it's a stretch
    #84
  5. Oct 23, 2015 at 7:35 AM
    #85
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    So maybe he'd be better off with this one: http://www.amazon.com/SecurityIng®-...F8&qid=1445610896&sr=8-1&keywords=skyray+king
    Same one you have I think.
  6. Oct 23, 2015 at 7:59 AM
    #86
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    yup. looks the same
    can't tell for sure unless you open-it-up but that is 'the original skyray king, kung, whatever brand on it' bigasslight
  7. Oct 23, 2015 at 8:01 AM
    #87
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I'm ordering one. I'll report back.
    XCDave likes this.
  8. Oct 23, 2015 at 8:35 AM
    #88
    XCDave
    XCDave Well-Known Member
    David
    2015 TRD 4X4 long bed dbl cab
    None at this time.
    So with a light like the skyway, you can't just put regular over the counter batteries in it ? Or is it just convenient to have rechargeables. My job supply's me with all the batts I need.
  9. Oct 23, 2015 at 8:48 AM
    #89
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    It uses four 18650 batteries.
    XCDave[QUOTED] likes this.
  10. Oct 23, 2015 at 8:56 AM
    #90
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    This is my EDC light. It's a Zebralight SC600 MKII that puts out 1100 lumen on high. I've beat the snot out of it, and except for the lense popping out once or twice it's held up like a champ.
    I am however in the market for a light with a little better cooling. This thing gets hot if left on high for too long.
    Single 18650
  11. Oct 23, 2015 at 9:00 AM
    #91
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    almost all 'high powered' lights and devices use 3.7-4.2 volt lithium 18650's
    most all these high powered led lights do
    all your laptop packs use them
    even Tesla cars packs are made from hundreds of individual 18650's
    the lithium 3.7-4.2 volt 18650 is 'the standard' for most high powered systems
    there are others of course, like the tiny 10180 or huge 26650 but li-ion 18650 is ten times as popular than any other form factor
  12. Oct 23, 2015 at 9:02 AM
    #92
    XCDave
    David
    None at this time.
    Thanks for that answer. I have zero info on this I've always used big ass mag lights.
  13. Oct 23, 2015 at 9:04 AM
    #93
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    All of the newer LED lights will make your old Mag lites look like candles.
    95 taco and XCDave[QUOTED] like this.
  14. Oct 23, 2015 at 9:04 AM
    #94
    XCDave
    David
    None at this time.
    Yeah pretty impressive number. Actually looking at the voodoo set up with mount.
  15. Oct 23, 2015 at 9:05 AM
    #95
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Problem solved: http://www.kbvoodoo.com/shop/flashlight-mount-with-900-lumen-flashlight
    SMKYTXN[QUOTED] and XCDave like this.
  16. Oct 23, 2015 at 10:38 AM
    #96
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
  17. Oct 23, 2015 at 10:53 AM
    #97
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  18. Oct 23, 2015 at 11:08 AM
    #98
    jethro
    Geoff
    Southern NH
    Exactly, only it's a pre-order deal. I'm going to call and find out how long until it ships. Be back shortly...
  19. Oct 23, 2015 at 11:35 AM
    #99
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    lights that can sub 2xcr123's for 18650 are pretty useful as you can store cr123 forever they barely lose a charge
    I carry a thrunite tn11 in trucky and 4 loose cr123 in the cubby
    you can buy them in bulk from battery junction for less than a dollar each (titanium innovations brand)
    OR in an emergency pharmacies and camera stores carry them, but they are ultra expensive if you get them in a store
    so, keep an 18650 light and charge the 18650's when needed
    and if you are in the boonies and deplete the 18650's, go fetch your
    pile of cr123's you stashed and they will be good to go when needed
    full disclosure on what I roll with:
    in trucky I carry 7 lights
    -thrunite tn11 with 2xcr123, and 4 spare cr123
    -fenix e11
    -some cheap plastic headlamp with 3xaaa
    -my keychain Helix Zi
    -a red light built into my mini swiss army knife
    -my phone has a build in led light
    -a homemade 12v XML floodlight with two big clamps for the truck battery power, hard drive magnet base, and 50 feet of speaker wire.
  20. Oct 23, 2015 at 12:53 PM
    #100
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I love it!!
    In my 4Runner I carry:
    Nitecore MH25 and NDF40 diffuser with kbvoodoo mount in center console.
    Nitecore MT40 with one-off kbvoodoo mount in rear cargo area.
    Nitecore HC30 headlamp in center console.
    Nitecore Tube keychain light.
    Two extra Nitecore 18650's in center console.
    Two generic CR123's in center console.
    And a cheap USB charger in the glovebox.
