The Florida kinda, sorta, somewhat, semi annual Citrus meet.
Discussion in 'Florida' started by Toyota Tech31, Sep 11, 2013.
  1. Dec 10, 2013 at 11:40 AM
    #601
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    I'm bringing two jeeps.
  2. Dec 10, 2013 at 12:08 PM
    #602
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Updated list (if Fink is still coming and brings the Toy P/U)
    # of vehicles currently on list: 27
    # of 1st Gens: 1 (guess I'll be the sole rep for 1st Gens [​IMG])
    # of 2nd Gens: 16
    # of DCs: 12
    # of XC/ACs: 5
    # of SC: 2
    # of SUVs: 7
    # of Tacos: 18
    # of Non-Tacos: 10 (2 4runners, 4 Jeeps, 1 Ram, 1 Xterra, FS Bronco, Toy P/U)
    # of 2WDs: 9
    # of 4WDs: 18
    1. 2WD -- Toyota Tech31 + 1 -- 2 nights
    2. 2WD -- k9 + 1 -- 2 nights
    3. 2WD -- TAC1 + 3 -- 1 night
    4. 2WD -- Alfuh -- 2 nights
    5. 2WD -- FearNothing321 + 1 -- 2 nights
    6. 2WD -- DirtyMike + 1 -- 2 nights
    7. 2WD -- PMK + 1-- 1 or 2 nights (sat night, maybe friday night)
    8. 2WD -- Michaelrussell -- 1 night sat/sun
    9. 2WD -- Nammer -- Saturday (day only)
    10. 4WD -- Taco no Baka -- 1 night (Saturday)
    11. 4WD -- Finks99Taco + 1 -- Tentative 2 nights
    12. 4WD -- Nicko + 1 -- sat-sun- 2nights
    13. 4WD -- xmadcowx + 1 -- 2 nights
    14. 4WD -- Trdagule +2 -- 2 nights fri-sun
    15. 4WD -- The End+2 or 3 -- 2 nights.
    16. 4WD -- GuyHuey + 4 -- 2 nights
    17. 4WD (CJ7) -- The Duck + 1 child -- 2 nights
    18. 4WD -- Alfuh's Dodge guest -- 2 nights (broke, possibly unable to attend)
    19. 4WD -- The End's Jeep guest (#1) -- 2 nights
    20. 4WD -- The End's Jeep guest (#2) -- 2 Nights
    21. 4WD -- Nicko's Jeep guest -- 2 nights
    22. 4WD -- xweslingx -- 2 nights
    23. 4WD -- Leandra -- 2 nights
    24. 4WD -- JesseW (former member) 4WD Xterra (possibly coming)
    25. 4WD -- Austin07 -- 1 Day?
    26. 4WD -- Nd4Spd86 -- Local, no nights.
    27. 4WD -- ANGELO (Bronco) -- 1 Day?
    Took Aworthyopponent off the list. Highlighted the tentatives in orange and the day trippers in green.
  3. Dec 10, 2013 at 12:10 PM
    #603
    dirtymike
    dirtymike Well-Known Member
    mike
    orlando fl
    2nd gen
    Fiberglass,spindles, coils, 4"leafs, gears&locker, no skids :-/
    Well I'm just going to do it this way it'll be easier and less of a pain. $20 per member if you are camping. The fee dosent change if its one night or two.
  4. Dec 10, 2013 at 12:13 PM
    #604
    michaelrussell
    michaelrussell Well-Known Member
    Michael
    belleview,FL
    09 prerunner sr5 2.7 / 5 speed
    lots of stuff done more to do
    My brother will probably come out for the day in his jeep
  5. Dec 10, 2013 at 12:15 PM
    #605
    Toyota Tech31
    Toyota Tech31 [OP] Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    That sounds like the easiest thing to do. Thanks again for taking care of this for us.
  6. Dec 10, 2013 at 12:18 PM
    #606
    dirtymike
    mike
    orlando fl
    2nd gen
    That's what I'm thinking also. Jason did you get my text? And y'all are welcome
  7. Dec 10, 2013 at 12:31 PM
    #607
    Toyota Tech31
    Debary, Florida
    I did, haven't had a chance as of yet. Been busy at work. I check TW between jobs.
  8. Dec 10, 2013 at 3:27 PM
    #608
    ANGELO
    ANGELO Well-Known Member
    Angelo
    BRADENTON FL
    1995 ford bronco
    k$n cold air intake, 33" goodyear duratracs, pacesetter shortys, bassani y pipe, flowmaster 44, custom duals, front recovery points
    I just bought a dual cb antenna kit (it was 10$ more then a single) im only going to use one antenna and sell the other one. do any of you know if i can use the dual coax cable that came with it and just cut one side off? getting the max distance doesn't matter i plan on using it on trails. thank
  9. Dec 10, 2013 at 7:02 PM
    #609
    Taco No Baka
    Lee
    Tampa, FL
    I don't think you can use the cable. It has a different resistance than a single antenna coax, IIRC. It may not matter if you're not concerned with getting out very far, but then again, it might fry your radio, so better safe than sorry.
    Look up Right channel radios. They have a pretty good how-to and what-for section.
  10. Dec 15, 2013 at 5:48 AM
    #610
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    As far as I know, Leandra isn't going. It's just me and possibly 1+
  11. Dec 15, 2013 at 6:48 AM
    #611
    Toyota Tech31
    Debary, Florida
    Unless she's changed her mind in the past day or 2 she's planning on going.
  12. Dec 15, 2013 at 7:46 AM
    #612
    xweslingx
    Wes
    Durham, NC
    Oh my bad
  13. Dec 15, 2013 at 7:55 AM
    #613
    Toyota Tech31
    Debary, Florida
    It's all good. 18 more days till we wheel!!! I'm getting really anxious to get out there. I might have to hit the lake Mary spot to curve the itch.
  14. Dec 16, 2013 at 10:59 AM
    #614
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    lookin forward to this, cant wait!!!
  15. Dec 16, 2013 at 11:12 AM
    #615
    kriskross
    kriskross Shits & Giggles
    Monterey
    Former 2ndGen Owner, in the market for another
    See Build Thread
    Me and my wife have been looking for a nice camping/wheeling trip since we moved from Oregon in October. Count us as a tentative and I'll update when we know for sure.
    7. 2WD -- PMK + 1-- 1 or 2 nights (sat night, <font color="DarkOrange">maybe friday night)
    9. 2WD -- <font color="DarkOliveGreen">Nammer -- Saturday (day only)
    11. <font color="DarkOrange">4WD -- Finks99Taco + 1 -- Tentative 2 nights
    18. 4WD -- <font color="DarkOrange">Alfuh's Dodge guest -- 2 nights (broke, possibly unable to attend)
    24. <font color="DarkOrange">4WD -- JesseW (former member) 4WD Xterra (possibly coming)
    25. 4WD -- <font color="DarkOliveGreen">Austin07 -- 1 Day?
    26. 4WD -- <font color="DarkOliveGreen">Nd4Spd86 -- Local, no nights.
    27. 4WD -- <font color="DarkOliveGreen">ANGELO (Bronco) -- 1 Day?
    28. 4WD -- kriskross -- 2 nights
  16. Dec 16, 2013 at 2:39 PM
    #616
    Taco No Baka
    Lee
    Tampa, FL
    Hope you're not too disappointed. I doubt we have anything as cool as Oregon does here...at least as far as wheeling goes. :p
    Updated list & stats (if Fink is still coming and brings the Toy P/U)
    # of vehicles currently on list: 28
    # of 2nd Gens: 17
    # of DCs: 12
    # of XC/ACs: 6
    # of SC: 2
    # of SUVs: 7
    # of Tacos: 18
    # of 2WDs: 9
    # of 4WDs: 19
    28. 4WD -- Kriskross -- 2 nights
  17. Dec 16, 2013 at 4:16 PM
    #617
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Knoxville, TN
    2019 Audi S3
    Do we need to bring water or will there be potable water available?
  18. Dec 16, 2013 at 4:23 PM
    #618
    Toyota Tech31
    Debary, Florida
    There are water spickets at every sight, plus the bathrooms.
  19. Dec 16, 2013 at 4:28 PM
    #619
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
  20. Dec 16, 2013 at 4:36 PM
    #620
    Toyota Tech31
    Debary, Florida
    This is my new drink of choice. Adult apple juice. It's awesome.
